[pycsw-devel] Links Question
Tom Kralidis tomkralidis at gmail.com
Mon Sep 22 14:46:10 PDT 2014
That would be gmd:protocol, example snippet (slightly modified) [1]:
<gmd:CI_OnlineResource uuid="842068ED7ACB3919E040AC8C5AB45DED">
    <gmd:linkage>
        <gmd:URL>http://www.ngdc.noaa.gov/dmsp/index.html</gmd:URL>
    </gmd:linkage>
    <gmd:protocol>
        <gco:CharacterString
xmlns:gco="http://www.isotc211.org/2005/gco">WWW:LINK</gco:CharacterString>
    </gmd:protocol>
    <gmd:applicationProfile>
        <gco:CharacterString xmlns:gco="http://www.isotc211.org/2005/gco"/>
    </gmd:applicationProfile>
    <gmd:name>
    </gmd:name>
    <gmd:description>
xmlns:gco="http://www.isotc211.org/2005/gco">DMSP Satellites
Homepage</gco:CharacterString>
    </gmd:description>
    <gmd:function>
        <gmd:CI_OnLineFunctionCode
           codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_OnLineFunctionCode"
           codeListValue="information">information</gmd:CI_OnLineFunctionCode>
    </gmd:function>
</gmd:CI_OnlineResource>
[1] https://geo-ide.noaa.gov/wiki/index.php?title=ISO_Components#Identifying_Components_in_the_Repository
On Mon, Sep 22, 2014 at 4:43 PM,  <dan at inlet.geol.sc.edu> wrote:
> Ok, I now get what you guys are saying.
> What is the tag in that snippet that pycsw uses to add the service entry?
> Part of the section is valid, but missing the protocol.
> Thanks for the info, I want to get full use from the catalog.
> Dan
>> Exactly, Dan. ncISO is not generating a gmd:protocol entry for that
>> viewer.
>> It is not included in the ncISO XSLT. Feel free to add one to your copy of
>> the XSLT (UnidataDD2MI.xsl). But again, there's no valid gmd:protocol
>> entry
>> for such a viewer, really, so it would seem a moot point to me.
>> Cheers,
>> John
>> On Mon, Sep 22, 2014 at 9:21 AM, Dan Ramage <dan at inlet.geol.sc.edu> wrote:
>>> I think I am confused, the URL that is used for this None entry is only
>>> found in the section I posted below. I didn't see any <gmd:protocol>
>>> entries that had that URL.
>>> The ISO record in question is here:
>>> http://neptune.baruch.sc.edu/xenia/waf/ncsu_meas/thredds_dodsC_fmrc_sabgom_
>>> SABGOM_Forecast_Model_Run_Collection_best.ncd_META.xml
>>> On 9/22/14 3:15 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>>> >gmd:protocol is the actual element which triggers clients into binding
>>> >against
>>> >a given resource, which is usually based on a codelist item for
>>> >consistency.
>>> >gmd:name serves as more of a text label of a given link as opposed to
>>> >something a machine can action against.
>>> >Using gmd:protocol will yield huge value in many downstream tools like
>>> >pycsw.  And given tools are looking for gmd:protocol, this prevents
>>> >them from guessing what the link is.
>>> >..Tom
>>> >On Mon, 22 Sep 2014, Dan Ramage wrote:
>>> >> Date: Mon, 22 Sep 2014 15:12:26 -0400
>>> >> From: Dan Ramage <dan at inlet.geol.sc.edu>
>>> >> To: Tom Kralidis <tomkralidis at gmail.com>
>>> >> Cc: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
>>> >> Subject: Re: [pycsw-devel] Links Question
>>> >> What's the reasoning for not using the Viewer Information string?
>>> >> Dan
>>> >> On 9/22/14 3:06 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>>> >>> This should be fixed in the upsteam ncISO tools at this point:
>>> >>> https://github.com/ethanrd/threddsIso/issues/2
>>> >>> https://github.com/Unidata/threddsIso/pull/1
>>> >>> This should alleviate this issue for ncISO based outputs.
>>> >>> ..Tom
>>> >>>> Date: Mon, 22 Sep 2014 14:56:48 -0400
>>> >>>> To: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
>>> >>>> Subject: [pycsw-devel] Links Question
>>> >>>> I've gotten most of my services issues sorted out via ncISO and
>>> using
>>> >>>> an xsl
>>> >>>> file that handles the transforms correctly from Thredds endpoints.
>>> >>>> However I still have an entry of "None" with a link that only
>>> appears
>>> >>>> in the
>>> >>>> following metadata section:
>>> >>>>               <gmd:distributorTransferOptions>
>>> >>>>                  <gmd:MD_DigitalTransferOptions>
>>> >>>>                     <gmd:onLine>
>>> >>>>                        <gmd:CI_OnlineResource>
>>> >>>>                           <gmd:linkage>
>>> >>>><gmd:URL>
>>> http://www.ncdc.noaa.gov/oa/wct/wct-jnlp-beta.php?singlefile=h
>>> >>>>tt
>>> >>>> p:/
>>> omgsrv1.meas.ncsu.edu:8080/thredds/dodsC/fmrc/sabgom/SABGOM_Forecast_M
>>> >>>>od
>>> >>>> el_
>>> >>>> Run_Collection_best.ncd</gmd:URL>
>>> >>>>                           </gmd:linkage>
>>> >>>>                           <gmd:name>
>>> >>>>                              <gco:CharacterString>Viewer
>>> >>>> Information</gco:CharacterString>
>>> >>>>                           </gmd:name>
>>> >>>>                           <gmd:description>
>>> >>>>                              <gco:CharacterString>This URL provides
>>> an
>>> >>>> NCDC
>>> >>>> climate and weather toolkit view of an OPeNDAP
>>> >>>> resource.</gco:CharacterString>
>>> >>>>                           </gmd:description>
>>> >>>>                           <gmd:function>
>>> >>>>codeList="
>>> http://www.ngdc.noaa.gov/metadata/published/xsd/schema/resour
>>> >>>>ce
>>> >>>> s/C
>>> >>>> odelist/gmxCodelists.xml#CI_PresentationFormCode"
>>> >>>> codeListValue="mapDigital">mapDigital</gmd:CI_OnLineFunctionCode>
>>> >>>>                           </gmd:function>
>>> >>>>                     </gmd:onLine>
>>> >>>>                  </gmd:MD_DigitalTransferOptions>
>>> >>>>               </gmd:distributorTransferOptions>
>>> >>>> Should this be picked up at all? There is a similar section above
>>> it
>>> >>>>as
>>> >>>> well
>>> >>>> that is a gmd:name http. I am not sure if this one is getting
>>> handled
>>> >>>> since
>>> >>>> I do have an http entry in the links or if that was from a
>>> >>>>gmd:protocol
>>> >>>> section.
>>> >>>> Dan
>>> pycsw-devel mailing list
>>> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel mailing list
