[pycsw-devel] Making Harvesting in a dedicated server PyCSW from catalogs CSW in GeoNode servers
Davi Custodio davicustodio at gmail.com
Tue Jun 23 09:57:20 PDT 2015
Tom, I was able to upgrade to version 1.10.1, but the problem continues. I
realized that I can point to any CSW that the error is the same. Below the
error I get to the point to http://demo.geonode.org/catalogue/csw
<! - Pycsw 1.10.1 ->
<Ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" xmlns:
inspire_common = "http://inspire.ec.europa.eu/schemas/common/1.0" xmlns:
atom = "http://www.w3.org/2005/Atom" xmlns: xs = "
http://www.w3.org/2001/XMLSchema" xmlns: dct = "http://purl.org/dc/ terms /
"xmlns: ows =" http://www.opengis.net/ows "xmlns: apiso ="
http://www.opengis.net/cat/csw/apiso/1.0 "xmlns: gml =" http: //
www.opengis.net/gml "xmlns: diff ="
http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/ "xmlns: xlink ="
http://www.w3.org/1999 / xlink "xmlns: gco ="
http://www.isotc211.org/2005/gco "xmlns: gmd =" ​​
http://www.isotc211.org/2005/gmd "xmlns: rdf =" http: //
www.w3.org/1999/02/22-rdf-syntax-ns# "xmlns: srv ="
http://www.isotc211.org/2005/srv "xmlns: ogc =" http: //www.opengis .net /
ogc "xmlns: FGDC =" http://www.opengis.net/cat/csw/csdgm "xmlns: inspire_ds
=" http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 "xmlns : csw = "
http://www.opengis.net/cat/csw/2.0.2" xmlns: xsi = "
http://www.w3.org/2001/XMLSchema-instance" xmlns: the = "http: //
a9.com/-/spec/opensearch/1.1/ "xmlns: soapenv ="
http://www.w3.org/2003/05/soap-envelope "xmlns: sitemap =" http:
//www.sitemaps .org / schemas / sitemap / 0.9 "language =" en-US "version
=" 1.2.0 "xsi: schemaLocation =" http://www.opengis.net/ows
http://schemas.opengis.net/ows
/1.0.0/owsExceptionReport.xsd"><ows:Exception ExceptionCode =
"NoApplicableCode" locator = "source"> <ows: ExceptionText> Harvest
(insert) failed: ERROR: null value in column "identifier" violates not-null
constraint
DETAIL: Failing row contains (null, csw: Record,
http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-23T13: 53: 57Z & lt;
ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" ...
Missing keyword: service, null, null, null, null, null, null, null, null,
null, null, null, null, null, null, null, null, null, null, null, null,
null, null, null, null, null, null, http://demo.geonode.org/catalogue/csw,
null, null, null, null, null, null, null, null, null, null, 'keyword': 2
'miss': 1 'servic': 3, null).
. </ Ows: ExceptionText> </ ows: Exception> </ ows: ExceptionReport>
In the apache logs also I found nothing. You suspect something?
thanks
On Mon, Jun 22, 2015 at 12:24 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
>  pycsw 1.10.1 has just been pushed in ubuntugis unstable. It will be
> available in ~2h
> On 06/22/2015 05:30 PM, Davi Custodio wrote:
> Hi Tom.
> I do this having trouble accessing external urls in my server. Fix, and did
> the test again pointing to the xml you stated:
> https://github.com/geopython/pycsw/blob/master/tests/suites/harvesting/post/Harvest-csw-run1.xml
> .. But the error was the same:
> pycsw-admin.py -c -u post_xml http: //localhost/pycsw/csw.py -x / var / www
> / html / pycsw / bin / request .xml
> Initializing static context
> Executing HTTP POST request /var/www/html/pycsw/bin/request.xml on server
> <? Xml version = "1.0" encoding = "UTF-8" standalone = "no"?>
> <! - Pycsw 1.10.0 ->
> <Ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" <http://purl.org/dc/elements/1.1/> xmlns:
> inspire_common = "http://inspire.ec.europa.eu/schemas/common/1.0" <http://inspire.ec.europa.eu/schemas/common/1.0> xmlns:
> atom = "http://www.w3.org/2005/Atom" <http://www.w3.org/2005/Atom> xmlns: xs = "
> http://www.w3.org/2001/XMLSchema" <http://www.w3.org/2001/XMLSchema> xmlns: dct = "http://purl.org/dc/ terms /
> " <http://purl.org/dc/terms/>xmlns: ows =" http://www.opengis.net/ows " <http://www.opengis.net/ows>xmlns: apiso ="
> http://www.opengis.net/cat/csw/apiso/1.0 " <http://www.opengis.net/cat/csw/apiso/1.0>xmlns: gml =" http: //www.opengis.net/gml "xmlns: diff ="
> http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/ " <http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/>xmlns: xlink ="
> http://www.w3.org/1999 / xlink " <http://www.w3.org/1999/xlink>xmlns: gco ="
> http://www.isotc211.org/2005/gco " <http://www.isotc211.org/2005/gco>xmlns: gmd =" ​​http://www.isotc211.org/2005/gmd "xmlns: rdf =" http: //www.w3.org/1999/02/22-rdf-syntax-ns# "xmlns: srv ="
> http://www.isotc211.org/2005/srv " <http://www.isotc211.org/2005/srv>xmlns: ogc =" http: //www.opengis .net /
> ogc "xmlns: FGDC =" http://www.opengis.net/cat/csw/csdgm " <http://www.opengis.net/cat/csw/csdgm>xmlns: inspire_ds
> =" http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 " <http://inspire.ec.europa.eu/schemas/inspire_ds/1.0>xmlns : csw = "
> http://www.opengis.net/cat/csw/2.0.2" <http://www.opengis.net/cat/csw/2.0.2> xmlns: xsi = "
> http://www.w3.org/2001/XMLSchema-instance" <http://www.w3.org/2001/XMLSchema-instance> xmlns: the = "http: //a9.com/-/spec/opensearch/1.1/ "xmlns: soapenv ="
> http://www.w3.org/2003/05/soap-envelope " <http://www.w3.org/2003/05/soap-envelope>xmlns: sitemap =" http:
> //www.sitemaps .org / schemas / sitemap / 0.9 " <http://www.sitemaps.org/schemas/sitemap/0.9>language =" en-US "version
> /1.0.0/owsExceptionReport.xsd" <http://www.opengis.net/owshttp://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd>><ows:Exception ExceptionCode =
> constraint
> DETAIL: Failing row contains (null, csw: Record,http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-22T11: 23: 47Z & lt;
> ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" <http://purl.org/dc/elements/1.1/> ...
> Done
> Attached, I am sending the response for
> http://aguai.cnpm.embrapa.br/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary&maxrecords=1000
> in which you suggested.
> I am still using the 1.10.0 version. Could this being resolved by upgrading
> to 1.10.1? I'm using an Ubuntu 4.14 server. I tried to update the pycsw
> using apt-get update and then apt-get upgrade, but the pycsw remained in
> version 1.10.0. How do I upgrade using the Ubuntu packages?
> Thanks
> On Fri, Jun 19, 2015 at 4:28 PM, Tom Kralidis <tomkralidis at gmail.com> <tomkralidis at gmail.com> wrote:
>  Hi Davi: thanks for moving this discussion here from geonode-users.
> Comments interleaved.
> On Fri, Jun 19, 2015 at 3:09 PM, Davi Custodio <davicustodio at gmail.com> <davicustodio at gmail.com>
> wrote:
>  Hello. I have a scenario consists of 8 GeoNode servers with their
>  respective
>  PyCSW assets.
> To test, Getrecords use as:
>  http://localhost/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary
>  and receive the corresponding xml correctly.
> You can also configure the harvest within the Geonetwork using:
> http: // localhost / catalog / csw version = 2.0.2 & request =
> GetCapabilities & service = CSW
> and also the harvest runs properly.
> I created a dedicated server with the default installation of PyCSW
>  1.10.0,
>  and I'm trying to get this server collect all the metadata records of 8
> servers GeoNode.
> My intention is to have a PyCSW to gather all the metadata of my
> organization. I'm avoiding using "federatedcatalogues" because I do not
>  want
>  the user who will rep csw need to specify additional parameters.
> In a first test, I used the command:
> pycsw-admin.py -c -u post_xml http: -x //localhost/pycsw/csw.py
> where request.xml =
> <? Xml version = "1.0" encoding = "UTF-8"?>
> <Harvest xmlns = "http://www.opengis.net/cat/csw/2.0.2" <http://www.opengis.net/cat/csw/2.0.2> xmlns: ogc ="http://www.opengis.net/ogc" <http://www.opengis.net/ogc> xmlns: gmd = "http: // www .isotc211.org /
>  2005
>  / gmd "xmlns: ows =" http://www.opengis.net/ows " <http://www.opengis.net/ows>xmlns: xsd
> ="http://www.w3.org/2001/XMLSchema " <http://www.w3.org/2001/XMLSchema>xmlns: dc ="
> http://purl.org/dc/elements/1.1/ " <http://purl.org/dc/elements/1.1/>xmlns: dct ="
>  "xmlns: gml =" http://www.opengis.net/gml " <http://www.opengis.net/gml> xmlns: xsi ="http://www.w3.org/2001/XMLSchema-instance" <http://www.w3.org/2001/XMLSchema-instance> xsi: schemaLocation =
> "http://www.opengis.net/cat/csw/2.0.2 http: //schemas.opengis .net /
>  csw /
>  2.0.2 / CSW-publication.xsd "service =" CSW "version =" 2.0.2 ">
>   <Source>http://demo.geonode.org//catalogue/csw </ Source>
>   <ResourceType> http://www.opengis.net/cat/csw/2.0.2 </ ResourceType>
>   <ResourceFormat> application / xml </ ResourceFormat>
> </ Harvest>
> pointing to http://demo.geonode.org//catalogue/csw ..
> I get the following error:
> Traceback (most recent call last):
>    File "/usr/bin/pycsw-admin.py", line 246, in <module>
>      print admin.post_xml (CSW_URL, XML, TIMEOUT)
>    File "/usr/lib/python2.7/dist-packages/pycsw/admin.py", line 495, in
> post_xml
>      raise RuntimeError (err)
> RuntimeError: timed out
>  I'm not getting any timeout when running here (using 1.10.1 -- any
> chance you can upgrade your single non-GeoNode pycsw instance to
> 1.10.1?) using the Harvest XML request like
> but substituting the Source with http://demo.geonode.org/catalogue/csw
> pycsw harvests 36 records (1 for the service and 35 metadata records).
> Are you able to see http://demo.geonode.org/catalogue/csw from the box
> on which you are running your harvests from?
>  when I point to one of my GeoNode-PyCSW servers using request.xml as:
>  2005
>  csw /
>   <Source> http://aguai.cnpm.embrapa.br/catalogue/csw </ Source>
> </ Harvest>
> pointing to my server: http://aguai.cnpm.embrapa.br/catalogue/csw
> I get the error:
>  xmlns:
> atom = "http://www.w3.org/2005/Atom" <http://www.w3.org/2005/Atom> xmlns: xs ="http://www.w3.org/2001/XMLSchema" <http://www.w3.org/2001/XMLSchema> xmlns: dct = "http://purl.org/dc/
>  terms /
>  "xmlns: ows =" http://www.opengis.net/ows " <http://www.opengis.net/ows>xmlns: apiso ="
> //www.opengis.net/gml " <http://www.opengis.net/gml>xmlns: diff
> ="http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/ " <http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/>xmlns: xlink ="
> http://www.isotc211.org/2005/gmd " <http://www.isotc211.org/2005/gmd>xmlns: rdf =" http:
> //www.w3.org/1999/02/22-rdf-syntax-ns# " <http://www.w3.org/1999/02/22-rdf-syntax-ns#>xmlns: srv ="
>  .net /
>  inspire_ds
>  ="http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 " <http://inspire.ec.europa.eu/schemas/inspire_ds/1.0>xmlns : csw ="http://www.opengis.net/cat/csw/2.0.2" <http://www.opengis.net/cat/csw/2.0.2> xmlns: xsi ="http://www.w3.org/2001/XMLSchema-instance" <http://www.w3.org/2001/XMLSchema-instance> xmlns: the = "http:
> //a9.com/-/spec/opensearch/1.1/ " <http://a9.com/-/spec/opensearch/1.1/>xmlns: soapenv ="
>  "version ="
>  (insert)
> constraint
> DETAIL: Failing row contains (null, csw: Record,http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-19T15: 19: 28Z &
>  lt;
> null, null, null, null, null, null,http://aguai.cnpm.embrapa.br/catalogue/csw, null, null, null, null,
>  null,
> null, null, null, null, null, 'keyword': 2 'miss': 1' servic '3, null).
> Done
> Can anyone help me explaining how to best implement it? And because of
> errors?
>  It looks like one of the layers in your pycsw serving GeoNode CSW does
> not have an identifier?  Can you turn on pycsw logging from your
> single pycsw to DEBUG and run the harvest again?  There might be
> valuable information in the log that can help.  Feel free to send me
> the log output offline.
> As well, wow many records doeshttp://aguai.cnpm.embrapa.br/catalogue/csw have?  Might be valuable to
> do a full GetRecords request, i.e.:
> http://aguai.cnpm.embrapa.br/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary&maxrecords=FOO
> to inspect the actual CSW output that pycsw is trying to harvest.
> Feel free to send me the result offline.
> Davi de O. Custódio
> pycsw-devel mailing listpycsw-devel at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pycsw-devel
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athenshttp://users.ntua.gr/tzotsos
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20150623/6bdd2c39/attachment-0001.html>
More information about the pycsw-devel mailing list
