[Pywps-dev] Running the unit tests
Jorge de Jesus
jorge.mendesdejesus at wur.nl
Fri Jun 21 00:54:34 PDT 2013
Hi to all
Some unitttest fail due to incorrect configuration or real problems, the
unnittest are very diverse from FTP testing, XML parsing to simple WPS
request.
Alex, INMHO try to cherry pick some simple uniitttest from
PyWPS/tests/schema_validation.py or PyWPS/tests/perform_requests.py and
run them and then port to Tox/Travi
The majority of the unitttest should run on python2.7 using a local
implementation in the latest code
I think that Tox/Travis is a great idea !!!! Never done it like that but
want to see it working with PyWPS
Cheers
Jorge
On 06/20/2013 11:07 PM, Alex Morega wrote:
> Hello!
> There's a nice testing tool, called tox[1], that automates running unit tests against multiple Python versions and configurations. Also, since the project is on Github, we can set up Travis[2] to run the unit tests for every commit and pull request.
> I can set up both, but so far I've not been able to run the test suite successfully, either on Python 2.7 or 3.3. Are all the tests up-to-date with the latest commits?
> Cheers,
> -- Alex
> [1] http://testrun.org/tox/latest/
> [2] https://travis-ci.org/
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
ISRIC - World Soil Information Post: PO box 353, 6700 AJ, Wageningen,
The Netherlands Visiting Address: Droevendaalsesteeg 3, 6708 PB
Wageningen (Bdg. 101), Office: C.013 Office Phone: +31 (0) 317 4 83715
Mobile Phone: +31 (0) 613 9 06950 OpenPGPKey: 0xA3D0065A
More information about the pywps-dev
