[Pywps-dev] GitHub pages
Jachym Cepicky jachym.cepicky at gmail.com
Fri Jul 17 00:48:07 PDT 2015
I'm working on getting the pywps.org domain. It's now registered by my
former employer - but it should be ok, they are just not much responsive
much.
Thank you Luis for diging into this and thanks Tom for the hints
Jachym
pá 17. 7. 2015 v 0:47 odesílatel Tom Kralidis <tomkralidis at gmail.com>
napsal:
> Luis: thanks for the info -- great work!  Comments/suggestions based
> on our pycsw-workshop [1] experiences:
> - it might be cleaner to have a single repository called, say,
> pywps.org in which the master branch is the source and the output is
> in branch gh-pages.  A build step would build the docs in master and
> commit the output to gh-pages [2]
> - consider adding a CNAME file which contains pywps.org (I think
> someone in PyWPS has this domain already?)
> - given PyWPS is itself within the geopython GitHub organization [2],
> you're more than welcome to setup shop there for pywps.org repo
> Cheers
> ..Tom
> [1] https://github.com/geopython/pycsw-workshop
> [2] https://github.com/geopython/pycsw-workshop/blob/master/Makefile#L163
> [3] https://github.com/geopython/PyWPS
> On Thu, Jul 16, 2015 at 11:55 AM, Luís de Sousa
> <luis.a.de.sousa at gmail.com> wrote:
> > So we have a web page working on GitHub (sort of):
> > https://pywps.github.io/
> > There is no styling, and at this stage I am not sure why. Should
> > sphinx also generate some css?
> > This is what I did:
> > 1. Created a new project to contain the source (on which sphinx runs)
> > called pywps.github.io.source
> > 2. The project pywps.github.io now only contains the output from sphinx
> (html)
> > 3. pywps.github.io is now a submodule of pywps.github.io.source, under
> > the build folder
> > 4. Updated the README with new compile instructions.
> > Cheers,
> > Luís
> > pywps-dev mailing list
> > pywps-dev at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20150717/a78a9b2b/attachment.html>
More information about the pywps-dev mailing list
