[Pywps-dev] REST interface
Tom Kralidis tomkralidis at gmail.com
Sun Jun 14 13:21:15 PDT 2015
Thanks for the info - sounds great! Are you implementing WPS REST based on an OGC profile or best practice?
Having said this, it might be valuable to investigate the degree of RESTful-ness one can achieve (i.e. using pure HTTP verbs instead, etc.). For example:
http://example.org/wps # capabilities
# config (needs auth)
http://example.org/wps/server/config
http://example.org/wps/server/instances
http://example.org/wps/server/processes
And so on.
Sent from my iPhone
> On Jun 14, 2015, at 15:55, Calin Ciociu <calin.ciociu at gmail.com> wrote:
> Hello everyone,
> As some may know I am working during the summer for Google Summer of Code 2015.
> My job is to implement a REST interface for PyWPS-4.
> So REST won't be much different than the actual way a client makes requests.
> Something along the lines of "http://localhost:5000/wps?SERVICE=wps&OPERATION=GetCapabilities"
> What I was thinking was to add additional operation for different tasks like for example get the server configuration or the list of running server instances and processes. Also be able to set some configuration, control processes etc. (Which might require also some kind of security otherwise anyone can just go ahead and stop or deploy servers/processes)
> What do you guys think?
> Does this sound like a plan or should I have something different like "http://localhost:5000/rest?operation=foo&..."?
> Best regards,
> Calin Ciociu
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
