[Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Jachym Cepicky jachym.cepicky at gmail.com
Wed Apr 20 02:50:52 PDT 2016
hi, just curious,
could you pass the server response as well?
thanks
st 20. 4. 2016 v 10:05 odesílatel Robin Skahjem-Eriksen <
skahjem-eriksen at stcorp.no> napsal:
> Jonas, thank you for your clarification on the request attributes and the
> changes to the WPS spec.
> I have added `status=true`to the execution request in addition to the
> aforementioned attributes, and I still don't get a reponse with any URL to
> the ResponseDocument.
> My request looks like this:
> http://localhost/wps/?service=WPS&request=Execute&Identifier=ipf&version=1.0.0&DataInputs=processor_name=ST_IPF_TESTER;processor_version=01.13;input_selector=time-range;muninn_query=validity_stop
> > 1980-07-03 and validity_start <
> 1980-07-05;storeExecuteResponse=true;status=true
> And the process is defines as such:
> class IPF(Process):
>    def __init__(self):
>        inputs = [
>            LiteralInput(
>                'processor_name',
>                'IPF processor name',
>                data_type='string'
>            LiteralInput(
>                'processor_version',
>                'IPF processor version',
>                data_type='string'
>            LiteralInput(
>                'input_selector',
>                'SOL input selection',
>                data_type='string'
>            LiteralInput(
>                'muninn_query',
>                'Muninn product catalog query string',
>                data_type='string'
>        outputs = [
>            LiteralOutput(
>                'ipf_result',
>                'SUCCESS/FAILURE',
>                data_type='string'
>        super(IPF, self).__init__(
>            self._handler,
>            identifier='ipf',
>            version='0.1',
>            title='Generic IPF processor',
>            abstract='Processors for handling IPF products',
>            inputs=inputs,
>            outputs=outputs,
>            store_supported=True,
>            status_supported=True
> (.. handler omitted ..)
> Am I missing something?
> Med vennlig hilsen / With kind regards,
> Software developer
> Science [&] Technology AS
> Reg. nr.: 996 229 009 MVA
> [E]: skahjem-eriksen at stcorp.no
> [Address]:
> Forskningsparken
> Gaustadalléen 21
> 0349 Oslo
> Norway
> [W]: http://www.stcorp.no
> [P]:+47 45 911 694
> [E]: info at stcorp.no
>> On Apr 19 2016, at 9:26 pm, Jonas Eberle <jonas.eberle at gmx.de> wrote:
>> Hi Robin,
>> I guess you're looking for the "statusLocation" attribute of the
>> ExecuteResponse tag. The value of this attribute is the URL to the response
>> document, especially needed when you use asynchronous execution (both,
>> status=true and storeExecuteResponse=true, needed in the execute request).
>> There is no executeResponseLocation element, please see the "Corrigendum
>> for OpenGIS Implementation Standard Web Processing Service (WPS) 1.0.0
>> (0.0.8)" [1].
>> Best regards,
>> Jonas
>> [1] = http://portal.opengeospatial.org/files/?artifact_id=32766
>> ----- Am 19. Apr 2016 um 11:09 schrieb Robin Skahjem-Eriksen <
>> skahjem-eriksen at stcorp.no>:
>> I am trying to get pywps working so that a ResponseDocument is used to
>> show the process status, by having the Execute response provide a URL to
>> the ResponseDocument, as specified in the WPS 1.0 standard.
>> I am not sure if pywps actually supports this and if so, the feature is
>> not well documented. I see that pywps supports serving output files and
>> serving these, and I was hoping that this could be used to provide the
>> response document.
>> I initialize a Process object with `store_supported` and
>> `status_supported` set to `True` and provide `storeExecuteResponse=true` in
>> the GET request. However, I haven't manged to receive a response containing
>> the `executeResponseLocation` element, and I cannot find any code in the
>> master branch code base that handles an `ExecuteResponseLocation`.
>> Am I missing anything, or is this feature simply not supported by pywps?
>> Software developer
>> [Address]:
>> Forskningsparken
>> Gaustadalléen 21
>> 0349 Oslo
>> Norway
>> [P]:+47 45 911 694
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160420/4dccbc70/attachment-0001.html>
More information about the pywps-dev mailing list
