[Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Robin Skahjem-Eriksen skahjem-eriksen at stcorp.no
Wed Apr 20 03:38:38 PDT 2016
I am wondering if I have stumbled upon a bug, if not, I find the response
quite cryptic:
request:
localhost/wps/?service=WPS&request=Execute&Identifier=ipf&version=
1.0.0&DataInputs=processor_name=ST_IPF_TESTER;processor_version=01.13;inpu
t_selector=time-range;muninn_query=validity_stop > 1980-07-03 and
validity_start < 1980-07-05&status=true&storeExecuteResponse=true
reponse:
<!-- PyWPS 4.0.0-alpha2 -->
<wps:ExecuteResponse xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
http://schemas.opengis.net/wps/1.0.0/wpsExecute_response.xsd" service="WPS"
version="1.0.0" xml:lang="en-US"
serviceInstance="http://localhost/wps?service=WPS&request=GetCapabilities"
statusLocation="http://localhost/wps/3c7e38b6-06e0-11e6-8f17-0242ac190008.xml"
<wps:Process wps:processVersion="0.1">
<ows:Identifier>ipf</ows:Identifier>
<ows:Title>Generic IPF processor</ows:Title>
<ows:Abstract>Processors for handling IPF products</ows:Abstract>
</wps:Process>
<wps:Status creationTime="2016-04-20T10:11:23Z">
<wps:ProcessAccepted>PyWPS Process ipf
accepted</wps:ProcessAccepted>
</wps:Status>
</wps:ExecuteResponse>
The document (http://localhost/wps?service=WPS&request=GetCapabilities):
<ows:ExceptionReport xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
version="1.0.0">
<ows:Exception exceptionCode="MissingParameterValue" locator="service">
<ows:ExceptionText>service</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
I am wondering why the exception is raised, when my Execute request contains
the service attribute.
Is this a bug, or am I missing something?
Med vennlig hilsen / With kind regards,
Software developer
Science [&] Technology AS
Reg. nr.: 996 229 009 MVA
[E]: [skahjem-eriksen at stcorp.no](mailto:skahjem-eriksen at stcorp.no)
[Address]:
Forskningsparken
Gaustadalléen 21
0349 Oslo
Norway
[W]: <http://www.stcorp.no>
[P]:+47 45 911 694
[E]: [info at stcorp.no](mailto:info at stcorp.no)
> On Apr 20 2016, at 12:01 pm, Robin Skahjem-Eriksen <skahjem-
eriksen at stcorp.no> wrote:
Thank you so much for catching that and sharing it with me.
Software developer
[Address]:
Forskningsparken
Gaustadalléen 21
0349 Oslo
Norway
[P]:+47 45 911 694
>> On Apr 20 2016, at 11:57 am, Jonas Eberle <jonas.eberle at gmx.de>
wrote:
>> You have an error in the request, storeExecuteResponse=true and status=true
are individual attributes of the request, in your example these are data
inputs! Please use **&**storeExecuteResponse=true**&**status=true at
the end instead using the semicolon. Using the "old" PyWPS I also embraced the
data inputs with brackets, this leads to less errors in my opinion:
DataInputs=**[**processor_name=ST_IPF_;processor_version=01.13**]**
>> Cheers,
>> Jonas
>> \----- Am 20. Apr 2016 um 10:05 schrieb Robin Skahjem-Eriksen <skahjem-
eriksen at stcorp.no>:
>>> Jonas, thank you for your clarification on the request attributes and the
changes to the WPS spec.
>>> I have added `status=true`to the execution request in addition to the
aforementioned attributes, and I still don't get a reponse with any URL to the
ResponseDocument.
>>> My request looks like this:
>>> http://localhost/wps/?service=WPS&request=Execute&Identifier=ipf&a
mp;version=1.0.0&DataInputs=processor_name=ST_IPF_TESTER;processor_version
=01.13;input_selector=time-range;muninn_query=validity_stop > 1980-07-03
and validity_start < 1980-07-05;storeExecuteResponse=true;status=true
>>> And the process is defines as such:
>>> class IPF(Process):
   def __init__(self):
       inputs = [
           LiteralInput(
               'processor_name',
               'IPF processor name',
               data_type='string'
           LiteralInput(
               'processor_version',
               'IPF processor version',
               data_type='string'
           LiteralInput(
               'input_selector',
               'SOL input selection',
               data_type='string'
           LiteralInput(
               'muninn_query',
               'Muninn product catalog query string',
               data_type='string'
       outputs = [
           LiteralOutput(
               'ipf_result',
               'SUCCESS/FAILURE',
               data_type='string'
       super(IPF, self).__init__(
           self._handler,
           identifier='ipf',
           version='0.1',
           title='Generic IPF processor',
           abstract='Processors for handling IPF products',
           inputs=inputs,
           outputs=outputs,
           store_supported=True,
           status_supported=True
(.. handler omitted ..)
>>> Am I missing something?
Software developer
[Address]:
Forskningsparken
Gaustadalléen 21
0349 Oslo
Norway
[P]:+47 45 911 694
>>>> On Apr 19 2016, at 9:26 pm, Jonas Eberle <jonas.eberle at gmx.de>
wrote:
>>>> Hi Robin,
>>>> I guess you're looking for the "statusLocation" attribute of the
ExecuteResponse tag. The value of this attribute is the URL to the response
document, especially needed when you use asynchronous execution (both,
status=true and storeExecuteResponse=true, needed in the execute request).
There is no executeResponseLocation element, please see the "Corrigendum for
OpenGIS Implementation Standard Web Processing Service (WPS) 1.0.0 (0.0.8)"
[1].
>>>> Best regards,
>>>> Jonas
>>>> [1] = <http://portal.opengeospatial.org/files/?artifact_id=32766>
\----- Am 19. Apr 2016 um 11:09 schrieb Robin Skahjem-Eriksen <skahjem-
>>>>> I am trying to get pywps working so that a ResponseDocument is used to
show the process status, by having the Execute response provide a URL to the
ResponseDocument, as specified in the WPS 1.0 standard.
>>>>> I am not sure if pywps actually supports this and if so, the feature is
not well documented. I see that pywps supports serving output files and
serving these, and I was hoping that this could be used to provide the
response document.
>>>>> I initialize a Process object with `store_supported` and
`status_supported` set to `True` and provide `storeExecuteResponse=true` in
the GET request. However, I haven't manged to receive a response containing
the `executeResponseLocation` element, and I cannot find any code in the
master branch code base that handles an `ExecuteResponseLocation`.
>>>>> Am I missing anything, or is this feature simply not supported by pywps?
Software developer
[Address]:
Forskningsparken
Gaustadalléen 21
0349 Oslo
Norway
[P]:+47 45 911 694
pywps-dev mailing list
pywps-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160420/4453e583/attachment-0001.html>
More information about the pywps-dev mailing list
