[Pywps-dev] Deactivate sqlalchemy logging
Jáchym Čepický jachym.cepicky at gmail.com
Fri Dec 23 07:53:00 PST 2016
sorry for later response
in PyWPS configuration file, you can set log level to anything but INFO
- in that case, in dblog.py
172   engine = sqlalchemy.create_engine(database, echo=echo_level)
echo_level will be set to False
See
http://pywps.readthedocs.io/en/latest/configuration.html#logging
for how to set this in configuration file
Is that ok?
Jachym
Dne 16.12.2016 v 09:41 Sylvain Beorchia napsal(a):
> Hi all,
> Using my firsts pywps processes, i've got plenty of unwanted logs. Here's
> an extract :
> [Fri Dec 16 09:34:36.637934 2016] [:error] [pid 27598]
> INFO:sqlalchemy.engine.base.Engine:
> [Fri Dec 16 09:34:36.637937 2016] [:error] [pid 27598] CREATE TABLE
> pywps_stored_requests (
> [Fri Dec 16 09:34:36.637938 2016] [:error] [pid 27598] \tuuid VARCHAR(255)
> NOT NULL,
> [Fri Dec 16 09:34:36.637940 2016] [:error] [pid 27598] \trequest BLOB NOT
> NULL,
> [Fri Dec 16 09:34:36.637942 2016] [:error] [pid 27598] \tPRIMARY KEY (uuid)
> [Fri Dec 16 09:34:36.637944 2016] [:error] [pid 27598] )
> [Fri Dec 16 09:34:36.637946 2016] [:error] [pid 27598]
> [Fri Dec 16 09:34:36.637947 2016] [:error] [pid 27598]
> [Fri Dec 16 09:34:36.637998 2016] [:error] [pid 27598] 2016-12-16
> 09:34:36,637 INFO sqlalchemy.engine.base.Engine ()
> [Fri Dec 16 09:34:36.638017 2016] [:error] [pid 27598]
> INFO:sqlalchemy.engine.base.Engine:()
> [Fri Dec 16 09:34:36.638229 2016] [:error] [pid 27598] 2016
> I tried to deactivate the logging by doing :
> logging.basicConfig()
> logging.getLogger('sqlalchemy.engine').setLevel(logging.WARNING)
> in my wsgi file, but does no work.
> Am i missing something ?
> Thank you.
> Sylvain.
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
twitter: @jachymc
More information about the pywps-dev mailing list
