[Pywps-dev] Can't get XML output's execution ( pyWPS + Owslib )
Jachym Cepicky jachym.cepicky at gmail.com
Thu Jan 7 00:46:32 PST 2016
Mariano,
yes, the target XML shoule be updated (and always was) ... to debug assync
mode, it was always little bit tricky. First step is to make sure, your
process is really running in sync mode - is that your case or are you
facing some logs in error.log?
út 5. 1. 2016 v 15:56 odesílatel Mariano Kaimakamian <
marianokaimakamian at suremptec.com.ar> napsal:
> Thanks Luis for your reply!
> That's correct, the process is being executed in assynchronous mode, and
> the xml that I was talking about is the one which is accessed by the url
> http://myDomain/wps/outputs/pywps-145199989796.xml (in this case, of
> course).
> I was expecting to get -eventually- the xml updated with the output and to
> get the state updated... but the xml remains the same.
> Maybe I'm misunderstanding how owslib and pywps work together, and the xml
> only change if I do another thing (which clearly, I'm not doing)  :/
> Regards and thanks again!
> Mariano
> 2016-01-05 11:08 GMT-03:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
>> Hi Mariano,
>> The process is being executed in assynchronous mode. To access the
>> results you must visit the statusLocation URL, in this case:
>> Regards,
>> Luís
>> On 5 January 2016 at 14:41, Mariano Kaimakamian
>> <marianokaimakamian at suremptec.com.ar> wrote:
>> > Hello guys:
>> > My name is Mariano and bothering you because I need some guidance; I
>> did a
>> > research but I didn't find any solution.
>> > I'm using pyWPS 3.2.1 (on Ubuntu 12.04.5 LTS) together with Owslib
>> 0.8.9 as
>> > a client, and I'm experiencing some issues when I try to get the
>> response's
>> > xml after pyWPS executes a process; I'm not pretty sure if the problem
>> is
>> > Owslib related but if someone knows something about it, please, let me
>> know.
>> > The process works as it is expected and I can get the output's object
>> that
>> > pyWPS returns (WPSExecution, an owslib's object) if I send the request
>> > omitting the output parameter; however, when I explicitly include that
>> > parameter to get xml generated, the xml is created but without the
>> output.
>> > Take a look, please:
>> > # Setting service and some values
>> > wps = WebProcessingService('http://myDomain/wps', verbose=True)
>> > input_parameters = [
>> >     ("exe_uuid_input", "uuid"), ("pla_uuid_input", "uuid2"),
>> >     ("literal_input", "foobar"), ("sleep", "2"),
>> >     ("sender_address_input", "info at somewhere.com.ar"),
>> >     ("sender_psw_input", "Some input"),
>> >     ("mail_to_input", "info at somewhere.com.ar")
>> > # Execution...
>> > # Accordingly to owslib documentation, "output" is optional identifier
>> which
>> > makes owslib to return the process output as a hyperlink reference...
>> that
>> > means that an xml is generated.
>> > execution = wps.execute(
>> "proceso_test_2015122_version_test_2015122_4f5a18d2-dfee-4167-a427-ab2e5d7d0bea",
>> >     input_parameters,
>> output="proceso_test_2015122_version_test_2015122_4f5a18d2-dfee-4167-a427-ab2e5d7d0bea"
>> > Here is the xml created:
>> > <?xml version="1.0" encoding="utf-8"?>
>> > <wps:ExecuteResponse xmlns:wps="http://www.opengis.net/wps/1.0.0"
>> > xmlns:ows="http://www.opengis.net/ows/1.1"
>> > xmlns:xlink="http://www.w3.org/1999/xlink"
>> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> > xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
>> > http://schemas.opengis.net/wps/1.0.0/wpsExecute_response.xsd"
>> service="WPS"
>> > version="1.0.0" xml:lang="en-CA"
>> serviceInstance="?service=WPS&request=GetCapabilities&version=1.0.0"
>> > statusLocation="http://myDomain/wps/outputs/pywps-145199989796.xml">
>> >     <wps:Process wps:processVersion="Version Test
>> 20151221122542.106532">
>> <ows:Identifier>proceso_test_2015122_version_test_2015122_4f5a18d2-dfee-4167-a427-ab2e5d7d0bea</ows:Identifier>
>> >         <ows:Title>Process: dddee3ad-ebf5-42f0-96b9-48011067ef9f -
>> Version:
>> > Version Test 20151221122542.106532</ows:Title>
>> >         <ows:Abstract><![CDATA[
>> > User: 1
>> > Version: Prueba de eventos y planner]]></ows:Abstract>
>> >     </wps:Process>
>> >     <wps:Status creationTime="2016-01-05T10:18:17Z">
>> >         <wps:ProcessAccepted>Process
>> > accepted</wps:ProcessAccepted>
>> >     </wps:Status>
>> > </wps:ExecuteResponse>
>> > As you can see, there is no output and the status is ProcessAccepted,
>> when
>> > the owslib's object -if I omit the output parameters- confirms the
>> success
>> > of the operation.
>> > That's all guys.
>> > Thanks in advance for your time and for any comment; let me know if you
>> need
>> > more information.
>> > Reagrds,
>> > Mariano
>> > _______________________________________________
>> > pywps-dev mailing list
>> > pywps-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/pywps-dev
> *Mariano Kaimakamian Carrau*
> SUR emprendimientos tecnológicos
> Av. Rivadavia 611 Piso 11º  (C1002AAE)
> Ciudad de Buenos Aires, Argentina
> Tel. +54 (11) 4342-2976/84
> www.suremptec.com
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160107/2cff6743/attachment.html>
More information about the pywps-dev mailing list
