[Pywps-dev] GSoC 2016: Weekly report 2
Jachym Cepicky jachym.cepicky at gmail.com
Tue Jun 7 13:08:16 PDT 2016
Hi if this is possible,
share file
limited links ... again, I have no problem with this - it's intended to be
in place when the calculation is done - not for ever IMHO. You would end up
with terabytes of data soon
J
út 7. 6. 2016 v 13:36 odesílatel Vikas Mishra <vikasmishra95 at gmail.com>
napsal:
> Hi,
> I think sharing a file can be done, How does this look?
> https://www.dropbox.com/developers-v1/core/docs/python#DropboxClient.share
> Also please note that the links created here are time-limited, does it
> make any difference?
> Thanks and regards,
> Vikas Mishra
> MSc(Hons) Economics + B.E. Electronics and Electrical Engineering
> *Birla Institute of Technology & Science,* Pilani
> KK Birla Goa Campus
> 8412898899|vikasmishra95 at gmail.com
> On Tue, Jun 7, 2016 at 4:53 PM, Jonas Eberle <jonas.eberle at gmx.de> wrote:
>> Hi Vikas,
>> >> I planned on setting up the workflow on how to give these options to
>> the user but I couldn’t decide and hence proceeded with implementing
>> dropbox storage API
>> I believe, the way we should approach is the same, we planed to use for
>> FTP storage: configuration of dropbox account should be in handsof server
>> administrator. Client should get access to dropbox directory OR file stored
>> in dropbox directory directly. Returning folder is ok for now - DropBox
>> does not currently fit in the OWS and GIS world seamlessly - that is the
>> price we need to pay.
>> Using the Python API you are able to share the file directly. Any reason
>> against it? Sharing a folder could be a good option if there is one folder
>> for each process that is running, but only useful if there are more than
>> one output file. But the WPS client need to handle accessing a shared
>> dropbox folder. Personally I would share the each file directly.
>> Cheers,
>> Jonas
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160607/62f6dcac/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160607/62f6dcac/attachment.jpg>
More information about the pywps-dev mailing list
