[Pywps-dev] Problem calling a WPS service from another WPS service
Lorenzo Bottaccioli lorenzo.bottaccioli at gmail.com
Fri Jun 10 07:26:55 PDT 2016
Hi list,
I'm having a problem with a service when I call another service inside the
process.
   def _handler(self, request, response):
         df = self.get_real_sky(geodf,start,end,model)
    def get_real_sky(self,geodf,start,end,model):
        #print 'eccolo dentro'
        import requests
        url = "http://130.192.5.114:8080/wps"
        payload = "<wps:Execute service=\"WPS\" version=\"1.0.0\"
xmlns:wps=\"http://www.opengis.net/wps/1.0.0\" xmlns:ows=\"
http://www.opengis.net/ows/1.1\" xmlns:xlink=\"http://www.w3.org/1999/xlink\"
xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"
xsi:schemaLocation=\"
http://www.opengis.net/wps/1.0.0\n../wpsExecute_request.xsd\">\n
<ows:Identifier>real_sky</ows:Identifier>\n  <wps:DataInputs>\n
 <wps:Input>\n      <ows:Identifier>layer_in</ows:Identifier>\n
 <wps:Data>\n    <wps:ComplexData>"+geodf.to_json()+"</wps:ComplexData>\n
 </wps:Data>\n    </wps:Input>\n    <wps:Input>\n
 <ows:Identifier>start</ows:Identifier>\n        <wps:Data>\n
 <wps:LiteralData dataType=\"xs:string\">"+start+"</wps:LiteralData>\n
 <ows:Identifier>end</ows:Identifier>\n        <wps:Data>\n
 <wps:LiteralData dataType=\"xs:string\">"+end+"</wps:LiteralData>\n
 <ows:Identifier>model</ows:Identifier>\n        <wps:Data>\n
 <wps:LiteralData dataType=\"xs:string\">"+model+"</wps:LiteralData>\n
   </wps:Data>\n    </wps:Input>\n  </wps:DataInputs>\n
 <wps:ResponseForm>\n    <wps:RawDataOutput>\n
 <ows:Identifier>layer_out</ows:Identifier>\n    </wps:RawDataOutput>\n
 </wps:ResponseForm>\n</wps:Execute>"
        headers = {
            'content-type': "application/xml",
            'cache-control': "no-cache",
            'postman-token': "78829681-df08-3317-2e0e-90a31ea4f2a6"
        response = requests.request("POST", url, data=payload,
headers=headers)
        return response.text
The process inside def get_real_sky works if I call it by it self, but if I
call inside another process dosent work, it simply blocks and do not go
forward. I have tried to run only the service real_sky in another port not
in 8080 like the one who calls it but in 8082. In this way it works. I dont
understand if the problem is Flask or the problem is PyWPS.
If I press crtl+c to stop the process I get this:
Exception happened during processing of request from ('130.192.5.114',
49246)
  File "/usr/lib/python2.7/SocketServer.py", line 295, in
_handle_request_noblock
    self.process_request(request, client_address)
  File "/usr/lib/python2.7/SocketServer.py", line 321, in process_request
    self.finish_request(request, client_address)
  File "/usr/lib/python2.7/SocketServer.py", line 334, in finish_request
    self.RequestHandlerClass(request, client_address, self)
  File "/usr/lib/python2.7/SocketServer.py", line 649, in __init__
    self.handle()
  File
"/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/serving.py",
line 216, in handle
    rv = BaseHTTPRequestHandler.handle(self)
  File "/usr/lib/python2.7/BaseHTTPServer.py", line 340, in handle
    self.handle_one_request()
  File
line 251, in handle_one_request
    return self.run_wsgi()
  File
line 193, in run_wsgi
    execute(self.server.app)
  File
line 181, in execute
    application_iter = app(environ, start_response)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1836, in
__call__
    return self.wsgi_app(environ, start_response)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1817, in
wsgi_app
    response = self.full_dispatch_request()
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1478, in
    response = self.make_response(rv)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1577, in
make_response
    rv = self.response_class.force_type(rv, request.environ)
  File
"/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/wrappers.py",
line 847, in force_type
    response = BaseResponse(*_run_wsgi_app(response, environ))
  File
line 57, in _run_wsgi_app
    return _run_wsgi_app(*args)
  File
"/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/test.py",
line 871, in run_wsgi_app
    app_rv = app(environ, start_response)
  File
line 291, in application
    return f(*args[:-2] + (request,))(*args[-2:])
  File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Service.py",
line 529, in __call__
    request_uuid
  File
line 296, in execute
    response = self._parse_and_execute(process, wps_request, uuid)
  File
line 358, in _parse_and_execute
    wps_response = process.execute(wps_request, uuid)
  File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Process.py",
line 145, in execute
    wps_response = self._run_process(wps_request, wps_response)
  File
line 151, in _run_process
    wps_response = self.handler(wps_request, wps_response)
  File
"/home/lorenzo/tools/pywps-4/pywps-4-demo/processes/solar/PV_NOCT.py", line
45, in _handler
  File
101, in get_real_sky
    response = requests.request("POST", url, data=payload, headers=headers)
  File "/usr/lib/python2.7/dist-packages/requests/api.py", line 44, in
request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 455,
in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 558,
in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python2.7/dist-packages/requests/adapters.py", line 330,
in send
    timeout=timeout
  File "/usr/lib/python2.7/dist-packages/urllib3/connectionpool.py", line
562, in urlopen
    body=body, headers=headers)
414, in _make_request
    httplib_response = conn.getresponse(buffering=True)
  File "/usr/lib/python2.7/httplib.py", line 1051, in getresponse
    response.begin()
  File "/usr/lib/python2.7/httplib.py", line 415, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python2.7/httplib.py", line 371, in _read_status
    line = self.fp.readline(_MAXLINE + 1)
  File "/usr/lib/python2.7/socket.py", line 476, in readline
    data = self._sock.recv(self._rbufsize)
KeyboardInterrupt
130.192.5.114 - - [10/Jun/2016 16:25:45] "POST /wps HTTP/1.1" 200 -
INFO:werkzeug:130.192.5.114 - - [10/Jun/2016 16:25:45] "POST /wps HTTP/1.1"
200 -
49248)
  File "/usr/lib/python2.7/SocketServer.py", line 651, in __init__
    self.finish()
  File "/usr/lib/python2.7/SocketServer.py", line 710, in finish
    self.wfile.close()
  File "/usr/lib/python2.7/socket.py", line 279, in close
    self.flush()
  File "/usr/lib/python2.7/socket.py", line 303, in flush
    self._sock.sendall(view[write_offset:write_offset+buffer_size])
error: [Errno 32] Broken pipe
Any suggestion?
Best,
Lorenzo
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160610/1807933b/attachment-0001.html>
More information about the pywps-dev mailing list
