[Pywps-dev] [GSoC] Pause/Resume/Kill process response - Web-based administration
Jachym Cepicky
jachym.cepicky at gmail.com
Sat Jun 18 14:46:16 PDT 2016
Guys, again: this all makes sense to me. @Jan: the proposal of attributes
looks good for now, this is research, we shall see, what we shall need. I
assume, this is the minium we need for now
thanks
J
pá 17. 6. 2016 v 15:49 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz> napsal:
> OK, so I am going to implement JSON responses for the new URL API for
> now, it's also easier for me.
> What information do you want to see in this response?
> My guess:
> 1) an identifier
> 2) time
> 3) the uuid
> 4) a message like status: "paused/killed/resumed"
> Jan
> On 2016-06-17 15:19, Jonas Eberle wrote:
> > Hi all,
> > I would recommend not to mix responses based on OGC WPS (equal to
> > XML-based responses) with requests that are not in line with "typical"
> > WPS requests.
> > I would assume the following:
> > 1) If the request is something like
> > /wps?service=WPS&request=Pause&jobid=<process_id> (this is a typical
> > WPS request) the response should be XML-based along with or based on
> > the XML defined by the WPS specification.
> > 2) If the request is something like /processes/pause/<process_id> (not
> > defined at all by OGC) the response, in my opinion, should be
> > JSON-based (because this is easier for every programming language!)
> > The first is OGC-like, the second is completely different from any OGC
> > specification.
> > Furthermore: Is it "good pratice" to include elements, such as
> > "wps:ProcessPaused", that are not in line with the XML schema of the
> > WPS specification?
> > Cheers,
> > Jonas
> > ----- Am 17. Jun 2016 um 14:50 schrieb Jan Rudolf
> > <rudolja1 at fit.cvut.cz>:
> >> Hi,
> >> I've implemented pause/resume/kill into PyWPS in a form, that you
> >> make
> >> HTTP request with /processes/pause/<process_id>, the process is
> >> paused
> >> and you will get just text response "<process_id> is paused". I
> >> think,
> >> that Jachym said, you want the response in an XML form like:
> >> <wps:ExecuteResponse ...>
> >> <wps:Process wps:processVersion="None">
> >> <ows:Identifier>sleep</ows:Identifier>
> >> <ows:Title>Sleep Process</ows:Title>
> >> <ows:Abstract>This process will sleep for a given delay or 10
> >> seconds if not a valid value</ows:Abstract>
> >> </wps:Process>
> >> <wps:Status creationTime="2016-06-16T22:13:25Z">
> >> <wps:ProcessAccepted>PyWPS Process sleep
> >> accepted</wps:ProcessAccepted>
> >> </wps:Status>
> >> </wps:ExecuteResponse>
> >> so for paused/killed/resumed processes is going to be similar
> >> response
> >> only with different status? <wps:ProcessPaused>PyWPS Process sleep
> >> paused</wps:ProcessPaused> for example.
> >> Thanks, Jan
> >> _______________________________________________
> >> pywps-dev mailing list
> >> pywps-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160618/f48ea085/attachment.html>
More information about the pywps-dev
