[Pywps-dev] Raster Output error
Lorenzo Bottaccioli lorenzo.bottaccioli at gmail.com
Fri Jun 24 04:17:18 PDT 2016
Hi all,
Can you please show a simple PyWPS process that revice a geotiff and
returns it back and the url for requesting it?.
I'm not finding a way to do that.
Thanks in advantage,
Best
Lorenzo
2016-06-21 17:40 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> hi,
> if you are running pywps in apache2, it's usually
> /var/log/apache2/error.log
> if flask - it should be written to the command line
> look for some pythonish error
> po 20. 6. 2016 v 17:29 odesílatel Lorenzo Bottaccioli <
> lorenzo.bottaccioli at gmail.com> napsal:
>> Hi Jachym,
>> As I wrote in the previous mail I have changed
>> response.outputs['response'].file* = 'done' *in
>> response.outputs['response'].data = 'done'  .
>> But I stil get an error:
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
>> <title>500 Internal Server Error</title>
>> <h1>Internal Server Error</h1>
>> <p>The server encountered an internal error and was unable to complete
>> your request.  Either the server is overloaded or there is an error in the
>> application.</p>
>> Which is the HTTPD error.log file? The pywps.log file is always empty and
>> the log level is set to DEBUG
>> Best,
>> Lorenzo
>> 2016-06-18 23:39 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>> hi,
>>> as jonas was saying: response.outputs['response'].data = 'done' should
>>> work better
>>> Lorenzo:  do you get anything in the HTTPD server error.log file?
>>> pá 10. 6. 2016 v 15:30 odesílatel Lorenzo Bottaccioli <
>>>> Hi,
>>>> I'have changed from file to data in response.outputs['response'].data
>>>> = 'done', but bow I still get an error in the response.
>>>> application.</p>
>>>> The GET request is written like this:
>>>> http://130.192.5.114:8080/wps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
>>>> In the terminal I dont get any error report.
>>>> Tnx,
>>>> Lorenzo
>>>> 2016-06-10 10:20 GMT+02:00 Jonas Eberle <jonas.eberle at gmx.de>:
>>>>> The error "no such file or directory" comes from the following line:
>>>>> response.outputs['response'].file = 'done'
>>>>> As response is a LiteralOutput I guess it is not correct to use
>>>>> the file attribute, better use the data attribute:
>>>>> Cheers,
>>>>> Jonas
>>>>> ----- Am 10. Jun 2016 um 10:13 schrieb Jachym Cepicky <
>>>>> Hi Lorenzo,
>>>>> There are two bugs as I understand. The first one:
>>>>> IOError: [Errno 2] No such file or directory:
>>>>> '/tmp/pywps/pypws_process_lQqN_6/done'
>>>>> do you have /tmp/pywps/ directory in you system (and is it writeable?)
>>>>> The second bug is about attempt to write log to database
>>>>> nice report btw, with the process I believe, we can fix it (both) once
>>>>> we find out what the problem could be
>>>>> Jachym
>>>>> st 8. 6. 2016 v 11:50 odesílatel Lorenzo Bottaccioli <
>>>>>> Hi List,
>>>>>> I'm trying to run a process that recives a GeoTIFF as input and
>>>>>> response a GeoTIFF as output. But I'm having an error. The process is this:
>>>>>> from pywps import Process, ComplexInput, ComplexOutput,
>>>>>> get_format,LiteralOutput, Format
>>>>>> class Raster(Process):
>>>>>>     def __init__(self):
>>>>>>         inputs = [ComplexInput('raster','Raster
>>>>>> input',[Format('GEOTIFF')])]
>>>>>>         outputs = [ComplexOutput('raster_out', 'Raster
>>>>>> output',[Format('GEOJSON')]),LiteralOutput('response', 'Output response',
>>>>>> data_type='string')]
>>>>>>         super(Raster, self).__init__(
>>>>>>             self._handler,
>>>>>>             identifier='rast_try',
>>>>>>             title='Raster try',
>>>>>>             inputs=inputs,
>>>>>>             outputs=outputs,
>>>>>>             store_supported=True,
>>>>>>             status_supported=True
>>>>>>     def _handler(self, request, response):
>>>>>>         from osgeo import gdal
>>>>>>         app=request.inputs['raster'][0].file
>>>>>>         inds = gdal.Open(app)
>>>>>>         outdriver = gdal.GetDriverByName('GTiff')
>>>>>>         outds = outdriver.CreateCopy('output.tiff', inds)
>>>>>>         outds.FlushCache()
>>>>>>         response.outputs['raster_out'].output_format =
>>>>>> Format('GEOTIFF')
>>>>>>         response.outputs['raster_out'].file = 'output.tiff'
>>>>>>         return response
>>>>>> The error that I recive is this one:
>>>>>> Traceback (most recent call last):
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Process.py",
>>>>>> line 156, in _run_process
>>>>>>     wps_response.update_status('PyWPS Process finished', 100)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/WPSResponse.py",
>>>>>> line 41, in update_status
>>>>>>     self.doc = self._construct_doc()
>>>>>>   File
>>>>>> line 171, in _construct_doc
>>>>>>     output_elements = [self.outputs[o].execute_xml() for o in
>>>>>> self.outputs]
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/outputs.py",
>>>>>> line 276, in execute_xml
>>>>>>     literal_data_doc = WPS.LiteralData(text_type(self.data))
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/basic.py",
>>>>>> line 231, in get_data
>>>>>>     return IOHandler.get_data(self)
>>>>>>   File
>>>>>> line 173, in get_data
>>>>>>     file_handler = open(self.source, mode='r')
>>>>>> ERROR:root:Service error: near "''": syntax error
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Service.py",
>>>>>> line 358, in _parse_and_execute
>>>>>>     wps_response = process.execute(wps_request, uuid)
>>>>>>   File
>>>>>> line 145, in execute
>>>>>>     wps_response = self._run_process(wps_request, wps_response)
>>>>>>   File
>>>>>> line 178, in _run_process
>>>>>>     wps_response.update_status('Process error: %s.%s Line %i %s' %
>>>>>> (fname, method_name, exc_tb.tb_lineno, e), -1)
>>>>>>   File
>>>>>> line 47, in update_status
>>>>>>     update_response(self.uuid, self)
>>>>>>   File
>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/dblog.py",
>>>>>> line 67, in update_response
>>>>>>     cur.execute(update)
>>>>>> OperationalError: near "''": syntax error
>>>>>> How can I fix this?
>>>>>> Best,
>>>>>> Lorenzo
>>>>>> _______________________________________________
>>>>>> pywps-dev mailing list
>>>>>> pywps-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160624/4d0bdc1a/attachment-0001.html>
More information about the pywps-dev mailing list
