[Pywps-dev] usage of boundingbox parameter
Jachym Cepicky jachym.cepicky at gmail.com
Fri Mar 25 13:11:57 PDT 2016
bounding box is not used that often, I usually code it once and forget
about it  - therefore sorry for not so well formed answer
AFAIK, there is no way how to "share" with the client the default value of
some input parameter (except for abstract text) - but you can still
configure it and set minOccures to 0 -> default value should be taken
J
st 23. 3. 2016 v 15:26 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de>
napsal:
> Hi *,
> in WPS one can use the boundingbox parameter type. I can define a bbox
> parameter with pywps and the values are a list of CRS (like EPSG:4326).
> The default value is the first CRS in this list.
> In some processes i would like to define some specific bounding boxes
> (like 10,50,12,52) as default value.
> Is there a way to this with wps capabilities?
> Cheers,
> Carsten
> Carsten Ehbrecht
> Abteilung Datenmanagement
> Deutsches Klimarechenzentrum GmbH (DKRZ)
> Bundesstraße 45 a • D-20146 Hamburg • Germany
> Phone: +49 40 460094-148
> FAX:   +49 40 460094-270
> Email: ehbrecht at dkrz.de
> URL:   www.dkrz.de
> Geschäftsführer: Prof. Dr. Thomas Ludwig
> Sitz der Gesellschaft: Hamburg
> Amtsgericht Hamburg HRB 39784
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160325/8ccf37d4/attachment.html>
More information about the pywps-dev mailing list
