[Pywps-dev] GSoC Weekly Report 1
Jachym Cepicky jachym.cepicky at gmail.com
Tue May 31 11:26:45 PDT 2016
And thank you for the report
it's ok, if you are able to get it running from the source code - did you
try pip or some other method?
installing from source code is OK for now, you can go on.
no module pywps - try to set PYTHONPATH environment variable before you run
demo.py [1]
[1] https://docs.python.org/2/using/cmdline.html#envvar-PYTHONPATH
út 31. 5. 2016 v 20:23 odesílatel Jachym Cepicky <jachym.cepicky at gmail.com>
napsal:
> Hi Vikas,
> you should probably send your reports to soc list too? (did I miss it
> there?)
> J
> ne 29. 5. 2016 v 13:14 odesílatel Vikas Mishra <vikasmishra95 at gmail.com>
> napsal:
>> Hi all,
>> Please find the first weekly report at
>> https://summerofcode16.wordpress.com/2016/05/29/gsoc-2016-weekly-report-1/
>> Also, yesterday I upgraded from ubuntu 15.10 to ubuntu 16.04 and now am
>> not able to run demo.py after installing pywps manually, however it works
>> if I install it directly from the source code repository.
>> I get an error that there is no module named 'pywps' installed.
>> Strangely enough it works perfect if I install directly from the source
>> code.
>> Any ideas?
>> Vikas Mishra
>> MSc(Hons) Economics + B.E. Electronics and Electrical Engineering
>> *Birla Institute of Technology & Science,* Pilani
>> KK Birla Goa Campus
>> 8412898899|vikasmishra95 at gmail.com
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160531/b4f7e735/attachment.html>
More information about the pywps-dev mailing list
