[Pywps-dev] pywps - json output
Sylvain Beorchia sylvain.beorchia at gmail.com
Sun Oct 23 10:17:09 PDT 2016
Thank you for the fix Jachym.
But apparently it just changes the output, from :
<wps:ComplexData mimeType="application/geojson">
<![CDATA[
WwogICJmb28iLCAKICB7CiAgICAiYmFyIjogWwogICAgICAiYmF6IiwgCiAg
ICAgIG51bGwsIAogICAgICAxLjAsIAogICAgICAyCiAgICBdCiAgfQpd
</wps:ComplexData>
to:
[ "foo", { "bar": [ "baz", null, 1.0, 2 ] } ]
</wps:ComplexData>
JSON, but still in XML result.
Am i doing something wrong in my code ?
Thanks .
Sylvain.
2016-10-23 8:01 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> Hi Sylvain,
> fixed in master https://github.com/geopython/pywps/pull/201
> Hope, it works
> J
> so 22. 10. 2016 v 23:42 odesílatel Sylvain Beorchia <
> sylvain.beorchia at gmail.com> napsal:
>> Hi all,
>> Trying to build my first WPS, i want to return JSON outputs. After many
>> tests, i always got some JSON encoded chars embeded in XML, or clear JSON
>> embeded in XML...always XML.
>> Here is the simple code i've tried :
>> import json
>> from pywps import Process, LiteralInput, LiteralOutput, OGCUNIT, UOM,
>> ComplexInput, ComplexOutput, Format, FORMATS
>> class Test(Process):
>>     def __init__(self):
>>         inputs = [LiteralInput('name', 'Input name', data_type='string')]
>>         outputs = [ComplexOutput('out', 'Referenced Output',
>> supported_formats=[Format('application/geojson')])]
>>         super(Test, self).__init__(
>>             self._handler,
>>             identifier='cartogsm',
>>             title='Process Test',
>>             version='1.0.0.0',
>>             inputs=inputs,
>>             outputs=outputs,
>>             store_supported=True,
>>             status_supported=True
>>     def _handler(self, request, response):
>>         data = json.loads('["foo", {"bar":["baz", null, 1.0, 2]}]')
>>         out_bytes = json.dumps(data, indent=2)
>>         response.outputs['out'].output_format = 'application/json'
>>         response.outputs['out'].data = out_bytes
>>         return response
>> Ouput :
>> <wps:ProcessOutputs>
>> <wps:Output>
>> <ows:Identifier>out</ows:Identifier>
>> <ows:Title>Referenced Output</ows:Title>
>> <wps:Data>
>> <![CDATA[
>> </wps:ComplexData>
>> </wps:Data>
>> </wps:Output>
>> </wps:ProcessOutputs>
>> </wps:ExecuteResponse>
>> How can i return only JSON, with no XML at all ?
>> Thank you.
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20161023/72f5796e/attachment-0001.html>
More information about the pywps-dev mailing list
