[Pywps-dev] pywps - json output
Sylvain Beorchia sylvain.beorchia at gmail.com
Sun Oct 23 15:14:43 PDT 2016
Thank you for your answers.
Jachym, i knew that WPS is XML a  based communication protocol, but i was
hoping for a full  JSON output.
I'm going to have a look at the rawdataoutput Jonas suggered.
Thank you.
Sylvain.
2016-10-23 22:26 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> Ah, yes, I almost forget about it
> ne 23. 10. 2016 v 22:10 odesílatel Jonas Eberle <jonas.eberle at gmx.de>
> napsal:
>> Hi Sylvain,
>> if you have only one output, you can use the rawdataoutput paramater,
>> just like this WPS request:
>> http://artemis.geogr.uni-jena.de/cgi-bin/testbox.cgi?
>> service=WPS&version=1.0.0&request=Execute&identifier=
>> fossgis_wps_proj&datainputs=[epsg_target=2927;epsg_source=
>> 4326;wkt=POINT(11%2051)]*&rawdataoutput=output*
>> In your case it should be &rawdataoutput=out. Then you will get directly
>> the data from this output.
>> Cheers,
>> Jonas
>> ----- Am 23. Okt 2016 um 19:17 schrieb Sylvain Beorchia <
>> sylvain.beorchia at gmail.com>:
>> Thank you for the fix Jachym.
>> But apparently it just changes the output, from :
>> <wps:ComplexData mimeType="application/geojson">
>> <![CDATA[
>> WwogICJmb28iLCAKICB7CiAgICAiYmFyIjogWwogICAgICAiYmF6IiwgCiAg
>> ICAgIG51bGwsIAogICAgICAxLjAsIAogICAgICAyCiAgICBdCiAgfQpd
>> </wps:ComplexData>
>> to:
>> [ "foo", { "bar": [ "baz", null, 1.0, 2 ] } ]
>> </wps:ComplexData>
>> JSON, but still in XML result.
>> Am i doing something wrong in my code ?
>> Thanks .
>> Sylvain.
>> 2016-10-23 8:01 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>> Hi Sylvain,
>> fixed in master https://github.com/geopython/pywps/pull/201
>> Hope, it works
>> J
>> so 22. 10. 2016 v 23:42 odesílatel Sylvain Beorchia <
>> sylvain.beorchia at gmail.com> napsal:
>> Hi all,
>> Trying to build my first WPS, i want to return JSON outputs. After many
>> tests, i always got some JSON encoded chars embeded in XML, or clear JSON
>> embeded in XML...always XML.
>> Here is the simple code i've tried :
>> import json
>> from pywps import Process, LiteralInput, LiteralOutput, OGCUNIT, UOM,
>> ComplexInput, ComplexOutput, Format, FORMATS
>> class Test(Process):
>>     def __init__(self):
>>         inputs = [LiteralInput('name', 'Input name', data_type='string')]
>>         outputs = [ComplexOutput('out', 'Referenced Output',
>> supported_formats=[Format('application/geojson')])]
>>         super(Test, self).__init__(
>>             self._handler,
>>             identifier='cartogsm',
>>             title='Process Test',
>>             version='1.0.0.0',
>>             inputs=inputs,
>>             outputs=outputs,
>>             store_supported=True,
>>             status_supported=True
>>     def _handler(self, request, response):
>>         data = json.loads('["foo", {"bar":["baz", null, 1.0, 2]}]')
>>         out_bytes = json.dumps(data, indent=2)
>>         response.outputs['out'].output_format = 'application/json'
>>         response.outputs['out'].data = out_bytes
>>         return response
>> Ouput :
>> <wps:ProcessOutputs>
>> <wps:Output>
>> <ows:Identifier>out</ows:Identifier>
>> <ows:Title>Referenced Output</ows:Title>
>> <wps:Data>
>> <![CDATA[
>> </wps:ComplexData>
>> </wps:Data>
>> </wps:Output>
>> </wps:ProcessOutputs>
>> </wps:ExecuteResponse>
>> How can i return only JSON, with no XML at all ?
>> Thank you.
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20161024/86c6c70f/attachment-0001.html>
More information about the pywps-dev mailing list
