[Pywps-dev] Fwd: auto deployment of pywps
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Sep 26 11:44:33 PDT 2016
just FYI, thanks to Tom Kralidis, demo.pywps.org is now running from MASTER
branch of our GITHub
That means, we can now point our integration tests to demo.pywps.org and
also run cite tests against latest code
Thanks one more time, Tome
J
P.S. I'm a bit sick this weeks, therefore sorry for long response times
---------- Forwarded message ---------
Date: Ășt 13. 9. 2016 v 4:23
Subject: Re: auto deployment of pywps
To: Jachym Cepicky <jachym.cepicky at gmail.com>
Hi Jachym: thank for the script. FYI the auto-deployment is now
setup. Script in
https://github.com/geopython/demo.pywps.org/blob/master/PyWPS/webhook-deploy.wsgi
Basically, when a GitHub commit occurs, the script is triggered and:
- updates master
- does python setup.py install
- touches the PyWPS/wps.wsgi file which auto-reloads the application
without having to reload Apache
Also note that I had to add www-data to the pywps group and changed
all files/dirs to be group writeable. As well, I added you to group
pywps.
So now the entire demo.pywps.org is clean, with the only diff being in
/osgeo/demo.pywps.org/etc/apache/demo.pycsw.org which has the GitHub
key (which we shouldn't commit this change of course :).
I had to make changes to your script to get everything working
correctly. Let me know your thoughts. If this is all okay/works,
I'll announce to the pywps-dev mailing list.
Cheers
..Tom
On Sun, Sep 11, 2016 at 4:03 PM, Jachym Cepicky
<jachym.cepicky at gmail.com> wrote:
> Hi Tom,
> I've written first version of the auto-deploy script and stored it in
> /home/jachym/pywps_update.py
> I hope, you can read it
> We need to make the script accessible as CGI script somewhere in
> pywps.demo.org/cgi-bin/
> Then we need, that the user "apache" has write access to all the files
> stored in /osgeo/demo.pywps.org/src/
> Please, have a look at the script (I hope, you have at least read
access?),
> and tell me, what we all can do to get it deployed? It basically just
calls
> "git pull" if only there is "# DEPLOY PYWPS #" string in the last commit
> message - so it should be easy to read and I do not see any possibility of
> doing any harm
> What do you think?
> Thanks
> Jachym
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160926/45d2c80d/attachment.html>
More information about the pywps-dev
