[Pywps-dev] Import qgis.core into PyWPS process
Jáchym Čepický jachym.cepicky at gmail.com
Mon Jan 2 12:42:39 PST 2017
first check, if your GetCapabilities response is ok
(http://server/wps?service=wps&request=getcapabilities) - maybe the
plugin is corrupted (it's not the stablest piece of software).
Then please one more time: check the error.log of your web server, there
should be written more - you can pass any exception or error message
either to the mailing list or share it via pastebin.net or similar service
J
Dne 2.1.2017 v 21:38 Eduardo Silverio da Silva napsal(a):
> In my case I am using QGIS 2.18 (x32) and Python 2.7.13 (x32) on Windows
> 10, and I have already added the following environment variables:
> PYTHONPATH:
> C:\Program Files (x86)\QGIS 2.18\apps\qgis\python
> C:\Program Files (x86)\QGIS 2.18\apps\qgis\python\plugins
> C:\Program Files (x86)\QGIS 2.18\apps\Python27\Lib\site-packages
> PATH:
> C:\Program Files (x86)\QGIS 2.18\bin
> C:\Program Files (x86)\QGIS 2.18\apps\qgis\bin
> C:\Python27
> C:\Python27\Scripts
> Here is the code where I want to import the classes:
> #I would like to use these classes:
> # from qgis.core import *
> # from qgis.gui import *
> # from processing.core.Processing import Processing
> # import processing
> from pywps.Process import WPSProcess
> from types import FloatType
> class Process(WPSProcess):
>      def __init__(self):
>          WPSProcess.__init__(self,
>               identifier       = "processar",
>               title            = "Title",
>               version          = "1",
>               storeSupported   = "false",
>               statusSupported  = "false",
>               abstract         = "Abstract")
>          self.value1 = self.addLiteralInput(identifier = "value1", title =
> "Input 1", type = FloatType)
>          self.value2 = self.addLiteralInput(identifier = "value2", title =
> "Input 2", type = FloatType)
>          self.result = self.addLiteralOutput(identifier = "result", title =
> "Result", type = FloatType)
>      def execute(self):
>     # Here I would like to write the necessary code to execute the
> qgis:extractnodes algorithm:
>     # processing.runalg('qgis:extractnodes', 'river.shp', 'output.shp')
> v1 = self.value1.getValue()
>          v2 = self.value2.getValue()
>          self.result.setValue(v1 + v2)
>          return
> But even with those PATH variables configured I could not access the
> algorithm via WPS-client plugin.
> Regards,
> 2017-01-02 17:31 GMT-02:00 Salvatore Larosa <lrssvtml at gmail.com>:
>> Hi,
>> On Mon, Jan 2, 2017 at 4:31 PM, Eduardo Silverio da Silva <
>> eduardosilverio1990 at gmail.com> wrote:
>>> Hello people,
>>> I have a python script that uses some classes from qgis and it runs
>>> correctly in my standalone app (IDLE Python). But when I try to publish the
>>> script through PyWPS (3.2.5), the process does not apear in the list of
>>> GetCapabilities. I think the problem is with the following imports:
>>> When I comment these lines the algorithm is showed.
>> I guess the problem is with your environment variable, you should add the
>> QGIS python and plugins paths to PYTHONPATH and probably the QGIS lib path
>> to LD_LIBRARY.
>> Also, any error message could be useful in order to get some help from the
>> community. :)
>> Regards,
>> -SL
>> Salvatore Larosa
>> linkedIn: http://linkedin.com/in/larosasalvatore
>> twitter: @lrssvt
>> skype: s.larosa
>> IRC: lrssvt on freenode
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
twitter: @jachymc
More information about the pywps-dev mailing list
