[Pywps-dev] WPS server randomly fails, tries to chdir on unknow directory
Sylvain Beorchia sylvain.beorchia at gmail.com
Mon Mar 13 06:57:25 PDT 2017
Hi all,
Using the pywps server, i got some problems when calling my processes via
AJAX.
When i call my processes directly no problem.
Via Ajax (from a web application), i've got random fails. Sometimes it's
ok, sometimes not.
But the error is always the same :
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0.0-py2.7.egg/pywps/app/Service.py",
line 309, in execute, referer: https://myurl.net/
os.chdir(olddir), referer: https://myurl.net/
OSError: [Errno 2] No such file or directory:
'/myurl/tmp/pywps_process_HMmYdu', referer: https://myurl.net/
The code below is executed:
        olddir = os.path.abspath(os.curdir)
        try:
            os.chdir(process.workdir)
            response = self._parse_and_execute(process, wps_request, uuid)
        finally:
                os.chdir(olddir)
Sometimes, olddir is empty. Sometimes it corresponds to a real dir. And
sometimes not, in that case it crashes.
By the way, i've got plenty of undeleted pywps_process_xxx directories in
my work dir.
Any help will be appreciated.
Thank you.
Sylvain.
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20170313/a8bc2b92/attachment.html>
More information about the pywps-dev mailing list
