[Pywps-dev] gdal in docker
jorge.dejesus jorge.dejesus at geocat.net
Mon Nov 20 23:43:28 PST 2017
Hi Adam
Actually you have a good point, the docker images have no install for
GDAL. I will try to update  the dockerfile in the following days (bit
pressed with work).
For GDAL I normally install in server I normally follow the things from
Geographica
https://github.com/GeographicaGS/Docker-GDAL2/tree/master/2.2.2
https://github.com/GeographicaGS/Docker-GDAL2/blob/master/2.2.2/Dockerfile
These dockersfile are for ubuntu and python3 so therefore they will
properly work with pywps4-flask
Jorge
On 20-11-17 22:36, Adam Laža wrote:
> Hi devs,
> I'm using pywps-flask docker image but when I tried to run demo
> processes which need gdal I got this exception:
> <ows:ExceptionText>Complex validation requires GDAL/OGR
> support</ows:ExceptionText>
> I wanted to edit dockerfile so there will be gdal installed but I
> wasn't really successful. I tried different ways to install gdal with
> apk and pip but none of them succeeded.
> Does anybody use pywps in docker with gdal installed (and with
> Dockerfile using alpine)?
> Thanks in advance.
> Adam
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20171121/29eaf9ea/attachment.html>
More information about the pywps-dev mailing list
