[Pywps-dev] process logging
jorge.dejesus jorge.dejesus at geocat.net
Mon Nov 20 23:52:13 PST 2017
Hi Martin
Try to run pywps from the github  it has less bugs and less issues
https://github.com/geopython/pywps-flask
You have an example of logging
https://github.com/PyWPS/pywps-workshop/blob/master/processes/total_length_logging.py
You need to get the logger
import logging
LOGGER = logging.getLogger('PYWPS')
LOGGER.info('Adquired logger inside total_length.py')
LOGGER.info("אני לא אוהב יום שני")
The configuration level=INFO should be ok
Jorge
On 20-11-17 11:09, Martin Landa wrote:
> Hi,
> I wanted to ask how properly log processes. I put to my code
> logging.info(...)
> checked configuration
> level=INFO
> But none of process log messages (only those coming from pywps lib
> itself) are printed to log file/db. Using pywps installed via pip
> (4.0.0). What am I doing wrong? Thanks! Martin
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20171121/bd646902/attachment.html>
More information about the pywps-dev mailing list
