[PyWPS-dev] master or develop
Adam Laža
ad.laza32 at gmail.com
Fri Dec 14 00:10:06 PST 2018
Hi David,
Just cosmetics, I slightly edited the template. CDATA tag is not present if
we know that mimeType is XML-based. Response XML looks better then.
A.
[1]:
https://github.com/lazaa32/pywps/commit/f8b66e3f43f027ec3f20eacf9a82f9ac9c0e8499
čt 13. 12. 2018 v 8:00 odesílatel David Huard <huard.david at ouranos.ca>
napsal:
> Hi Adam, I've created a PR for your bug fix. Does it work for you ? It
> seems to work on my use cases.
> On Wed, Dec 12, 2018 at 9:31 AM David Huard <huard.david at ouranos.ca>
> wrote:
>> Looks good, trying to write a few tests to exercise it.
>> Good catch !
>> On Wed, Dec 12, 2018 at 1:02 AM Adam Laža <ad.laza32 at gmail.com> wrote:
>>> Hi David,
>>> check my bug fix [1]. It works for me but I would like to know if it is
>>> right approach.
>>> Cheers,
>>> Adam
>>> [1]:
>>> https://github.com/lazaa32/pywps/commit/5cccc38c997965d4566b21df0badf3244021bdeb
>>> st 12. 12. 2018 v 2:32 odesílatel David Huard <huard.david at ouranos.ca>
>>> napsal:
>>>> Hi Adam,
>>>> I think we have the same issue :
>>>> https://github.com/geopython/pywps/issues/412
>>>> My guess is that it's either due to my refactoring or to the new
>>>> templates or a combination of both.
>>>> I noticed that if you do
>>>> ComplexOutput.data = <file content>
>>>> ... then it works
>>>> but if you do
>>>> ComplexOutput.file = <file path>
>>>> it doesn't. Hopefully this is a hint as to what is going wrong.
>>>> I think the offending bit is is inout.outputs.ComplexOutput. If the
>>>> ComplexOutput is a file and as_reference is False, _json_data is called
>>>> which I think might fail to fill the json data field. It's not obvious why
>>>> though. Do you have a test case you could add to the test suite ?
>>>> HTH,
>>>> David
>>>> On Tue, Dec 11, 2018 at 4:06 AM Adam Laža <ad.laza32 at gmail.com> wrote:
>>>>> Hi Carsten,
>>>>> thanks for reply. Good to know. However since I switched for master
>>>>> branch I can get output in ExecuteResponse only as reference. Even if I
>>>>> force attribute asReference=false I still get only reference to output, not
>>>>> the output directly.
>>>>> I use pywps-flask demo server and Buffer process for testing. Any idea
>>>>> what could be wrong?
>>>>> Cheers,
>>>>> Adam
>>>>> út 11. 12. 2018 v 0:16 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de>
>>>>> napsal:
>>>>>> Hi Adam,
>>>>>> yes, please use master branch to rebase. We switched awhile ago (Code
>>>>>> sprint Bonn in March?).
>>>>>> Cheers,
>>>>>> Carsten
>>>>>> > On 8 Dec 2018, at 04:16, Adam Laža <ad.laza32 at gmail.com> wrote:
>>>>>> > Hi devs,
>>>>>> > I'd like to make a new PR for my Docker extension in few days. Now
>>>>>> I'm just bit confused because I wanted to rebase my branch onto develop
>>>>>> branch to avoid conflicts but it seems to me that develop branch is no more
>>>>>> used and that you use master instead (develop has last commit July 16,
>>>>>> master 26 days ago).
>>>>>> > Could anyone confirm that right approach is to rebase onto master
>>>>>> and make a PR against master?
>>>>>> > Thanks,
>>>>>> > Adam
>>>>>> > _______________________________________________
>>>>>> > pywps-dev mailing list
>>>>>> > pywps-dev at lists.osgeo.org
>>>>>> > https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181214/2d43403e/attachment.html>
More information about the pywps-dev
