[Pywps-dev] Guidelines for netCDF file and opendap accesss within pywps
Jachym Cepicky jachym.cepicky at gmail.com
Tue Jun 26 06:16:10 PDT 2018
I belive,
here is the place, where data get downloaded
https://github.com/geopython/pywps/blob/master/pywps/app/Service.py#L191
út 26. 6. 2018 v 14:57 odesílatel David Huard <huard.david at ouranos.ca>
napsal:
> Hi Jachym,
> Thanks for the pointers, I've started writing validators for netCDF. I'm
> still wondering where the decision to download a file is made? Can I
> shortcut that decision and avoid a file download if the href is a valid
> opendap link, ie it passes the validatenetcdf checks?
> On Fri, Jun 22, 2018 at 4:53 AM Jachym Cepicky <jachym.cepicky at gmail.com>
> wrote:
>> Hi,
>> yes ComplexInput should work for you - you can pass the url with the data
>> using "<Reference ... />" element.. see [1] for example
>> Any Format can have (and has by default) `validator` function, which
>> return's, whether the input data are valid or no [3]. You can also use
>> `get_format` function [4] and set the validator there.
>> Example, how validating function can look can be shapefile or gml
>> validators [5]
>> You should probably extend foramts [2] with NetCDF mimetype
>> But, this will check the file only after it was downloaded to PyWPS - not
>> the URL. Still. is that sufficient?
>> Jachym
>> [1]
>> https://github.com/geopython/pywps/blob/master/tests/requests/wps_execute_request-responsedocument-1.xml#L24
>> [2]
>> https://github.com/geopython/pywps/blob/master/pywps/inout/formats/__init__.py
>> [3]
>> https://github.com/geopython/pywps/blob/master/pywps/inout/formats/__init__.py#L42
>> [4]
>> https://github.com/geopython/pywps/blob/master/pywps/inout/formats/__init__.py#L215
>> [5]
>> https://github.com/geopython/pywps/blob/master/pywps/validator/complexvalidator.py
>> čt 21. 6. 2018 v 17:15 odesílatel David Huard <huard.david at ouranos.ca>
>> napsal:
>>> Hi all,
>>> I'd like to contribute a pull request to better handle netCDF files in
>>> pywps but I don't know where to start.
>>> We have a number of processes taking netCDF
>>> <https://www.unidata.ucar.edu/software/netcdf/> files as inputs. For
>>> those less familiar with the format, netCDF is based on HDF5 and a set of
>>> conventions <http://cfconventions.org/>. It is the standard data format
>>> in oceanography and climatology. netCDF files are usually stored on servers
>>> with support for opendap <https://www.opendap.org/>. This means that
>>> users can either download the netCDF file and then open it locally, or use
>>> the opendap protocol to open it remotely. What that means is that you can
>>> do
>>> from netCDF4 import nc
>>> ds1 = nc.Dataset("<path to local file>")
>>> ds2 = nc.Dataset("<link to opendap address>")
>>> and both ds1 and ds2 will behave identically. However ds2 is not
>>> downloaded locally, but rather read remotely on demand. If a file contains
>>> a 3D matrix (time, lat, lon), you can read one slice of the matrix without
>>> downloading it all.
>>> Some of our pywps.Process support both netCDF file and opendap access.
>>> We define a ComplexInput for the address to an actual netCDF file, and a
>>> LiteralInput for the opendap address.
>>> My question is whether there would be a clean way for pywps to support
>>> both modes with one ComplexInput? Internally, pywps would check if the
>>> address supports opendap (just check if nc.Dataset(url) works), and if not,
>>> would download the file locally to the server.
>>> In both cases, we could do
>>> ds = nc.Dataset(requests.inputs['resource'][0].file)
>>> I'm willing to put the time to do it, I just don't know where to start.
>>> Thanks,
>>> David
>>> pywps-dev mailing list
>>> pywps-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/pywps-dev
>> Jachym Cepicky
>> e-mail: jachym.cepicky gmail com
>> URL: http://les-ejk.cz
>> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Jachym Cepicky
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20180626/e2bef73c/attachment.html>
More information about the pywps-dev mailing list
