[PyWPS-dev] Response document of a stored job is not updated (pywps 4.2)
Carsten Ehbrecht
ehbrecht at dkrz.de
Wed Jan 23 09:05:25 PST 2019
Hi Donatien,
This might be an issue. Would like to open an issue on GitHub?
My guessing is, we can’t fix this for sqlite. But I have made a quick check with one of my PyWPS services using a Postgres DB and it looks the “queueing” is also not working as expected.
Thanks,
Carsten
> On 21 Jan 2019, at 4:17 pm, Donatien Dallery <donatien.dallery at yahoo.fr> wrote:
> Hello devs,
> I make a asynchronous process that works perfectly when the job is alone (parallelprocesses=1). So, to test the maxprocesses=10, i send two requests to my server. The second job is stored and a document has built. But, when the first job is finished and the second is released, the document response of second wasn't updated, but the database sqlite and log file are updated and files are produced in work directory. The response document remains stuck with <wps:ProcessAccepted percentCompleted="0">PyWPS Process waterFlowSimulation accepted</wps:ProcessAccepted>.
> I don't understand the problem because the response document of the first job is updated <wps:ProcessSucceeded>PyWPS Process Estimation waterFlowSimulation finished</wps:ProcessSucceeded>.
> Do you have any idea where the problem may come from ? Does the PyWPS 4.2.1 has a problem with stored job in async process ?
> If you need information about code or logs, I can give you them.
> Thanks,
> Donatien
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20190123/8e8ce4b9/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20190123/8e8ce4b9/attachment.bin>
More information about the pywps-dev
