[PyWPS-dev] running in production on windows - funding proposal
Idan Miara idan at miara.com
Sun Jul 5 02:09:57 PDT 2020
Hi all,
My employer would like to propose funding for extending pywps codebase to
support running a pywps service in production on Windows (for instance,
under IIS or as a windows service) in an asynchronous mode.
This extension shall include running a demo app with deployment
instructions, optionally with instructions for creating a windows installer
for a demo service. It shall be licensed under the pywps license (MIT) and
integrated into the official pywps codebase (or at least provide a decent
PR).
Currently, I am able to run this pywps demo.py
<https://github.com/bird-house/birdhouse-workshop/blob/master/demo/demo.py>
example
on Windows with the OSGeo4W python environment in synchronous mode.
If anyone would like to step forward with a proposal or to discuss it
further, please let me know.
Kind regards,
Idan
On Fri, 3 Jul 2020 at 10:58, Idan Miara <idan at miara.com> wrote:
> Hi Carsten, Luí­s and all,
> Thanks for your replies!
> Currently I use pywps with Docker based on gdal's official docker image
> (which is ubuntu based).
> https://github.com/talos-gis/talos_wps
> The service is still under testing but so far it looks very promising.
> I need to deploy it also on Windows because I need to use a customer's C
> DLL which is Windows only, so either I will need to port the DLL to Linux
> or find a way to run pywps on Windows in production.
> Luí­s wrote to me that from what he read online, all Python classes
> dealing with the Multiprocess must be modified to run on Windows, that is
> for running it in an asynchronous mode.
> I understand that this is not the normal setup, so I guess I will need to
> test how suitable this demo.py
> <https://github.com/bird-house/birdhouse-workshop/blob/master/demo/demo.py> is
> for production on Windows, or look for some other solution.
> Kind regards,
> Idan
> On Fri, 3 Jul 2020 at 10:32, Carsten Ehbrecht <ehbrecht at dkrz.de> wrote:
>> Hi Idan,
>> PyWPS is not meant to run in production on Windows. It may still work …
>> but I’m not sure.
>> Using a docker container might already be a good alternative.
>> There is a Flask demo with PyWPS … but outdated:
>> https://github.com/geopython/pywps-flask
>> Usually I use a cookiecutter template to setup a new PyWPS service which
>> includes docker container support:
>> https://github.com/bird-house/cookiecutter-birdhouse
>> For a full deployment on Linux with nginx/gunicron I use an Ansible
>> playbook:
>> https://github.com/bird-house/ansible-wps-playbook
>> Currently in our projects people are mostly using the PyWPS generated by
>> the cookiecutter … using Werkzeug/WSGI included in PyWPS either on the
>> Linux host or in a container (for production).
>> Cheers,
>> Carsten
>> Carsten Ehbrecht
>> Abteilung Datenmanagement
>> Deutsches Klimarechenzentrum GmbH (DKRZ)
>> Bundesstraße 45 a • D-20146 Hamburg • Germany
>> Phone: +49 40 460094-148
>> FAX:   +49 40 460094-270
>> Email: ehbrecht at dkrz.de
>> URL:   www.dkrz.de
>> Geschäftsführer: Prof. Dr. Thomas Ludwig
>> Sitz der Gesellschaft: Hamburg
>> Amtsgericht Hamburg HRB 39784
>> > On 1. Jul 2020, at 21:10, Idan Miara <idan at miara.com> wrote:
>> > Hi all,
>> > I have a working pywps service that is deployed successfully with a
>> Linux docker using gunicorn.
>> > I need some pointers for running it in a production environment on
>> Windows.
>> > As gunicorn is Linux only I need to find an alternative.
>> > I can run it on Windows with the birdhouse-workshop demo script:
>> > But the demo says: "Do not use this service in a production
>> environment." so I'm looking for a better solution.
>> > I have found also this rather complicated guide:
>> https://stackoverflow.com/questions/5072166/how-do-i-deploy-a-flask-application-in-iis
>> > Any suggestions?
>> > Kind regards,
>> > Idan
>> > _______________________________________________
>> > pywps-dev mailing list
>> > pywps-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20200705/656821fa/attachment.html>
More information about the pywps-dev mailing list
