[QGIS Commit] r8313 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Wed Apr 2 18:35:34 EDT 2008
Author: jef
Date: 2008-04-02 18:35:33 -0400 (Wed, 02 Apr 2008)
New Revision: 8313
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
postgres provider update
- handle PQsendQuery in one getNextFeature run (fixes nested iteration of
cursors with connection pooling)
- beautify DELETE and ALTER TABLE statements
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2008-04-02 18:31:09 UTC (rev 8312)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2008-04-02 22:35:33 UTC (rev 8313)
@@ -564,7 +564,6 @@
return;
mFetching = true;
- mFirstFetch = true;
bool QgsPostgresProvider::getNextFeature(QgsFeature& feature)
@@ -577,43 +576,37 @@
return false;
- // Top up our queue if it is empty
- if (mFeatureQueue.empty())
+ if( mFeatureQueue.empty() )
QString fetch = QString("fetch forward %1 from %2").arg(mFeatureQueueSize).arg(cursorName);
- if(mFirstFetch)
+ if(PQsendQuery(connection, fetch.toUtf8()) == 0) //fetch features in asynchronously
- if(PQsendQuery(connection, fetch.toUtf8()) == 0) //fetch features in asynchronously
- qWarning("PQsendQuery failed (1)");
+ qWarning("PQsendQuery failed (1)");
- mFirstFetch = false;
- queryResult = PQgetResult(connection);
- PQgetResult(connection); //just to get the 0 pointer...
- int rows = PQntuples(queryResult);
- if (rows == 0)
+ PGresult *queryResult;
+ while( (queryResult = PQgetResult(connection)) )
- QgsDebugMsg("End of features");
- PQclear(queryResult);
- return false;
+ int rows = PQntuples(queryResult);
+ if (rows == 0)
+ continue;
- for (int row = 0; row < rows; row++)
- mFeatureQueue.push(QgsFeature());
- getFeature(queryResult, row, mFetchGeom, mFeatureQueue.back(), mAttributesToFetch);
- } // for each row in queue
+ for (int row = 0; row < rows; row++)
+ mFeatureQueue.push(QgsFeature());
+ getFeature(queryResult, row, mFetchGeom, mFeatureQueue.back(), mAttributesToFetch);
+ } // for each row in queue
- if(PQsendQuery(connection, fetch.toUtf8()) == 0) //already fetch the next couple of features asynchronously
- qWarning("PQsendQuery failed (2)");
+ PQclear(queryResult);
- } // if new queue is required
+ QgsDebugMsg("End of features");
+ return false;
// Now return the next feature from the queue
if(mFetchGeom)
@@ -1890,8 +1883,10 @@
PQexecNR(connection,QString("BEGIN").toUtf8());
for(QgsFeatureIds::const_iterator it=id.begin();it!=id.end();++it) {
- QString sql("DELETE FROM "+mSchemaTableName+" WHERE "+quotedIdentifier(primaryKey)+"="+QString::number(*it));
+ QString sql = QString("DELETE FROM %1 WHERE %2=%3")
+ .arg(mSchemaTableName)
+ .arg(quotedIdentifier(primaryKey))
+ .arg(*it);
QgsDebugMsg("delete sql: "+sql);
//send DELETE statement and do error handling
@@ -1920,8 +1915,10 @@
for(QgsNewAttributesMap::const_iterator iter=name.begin();iter!=name.end();++iter)
- QString sql="ALTER TABLE "+mSchemaTableName+" ADD COLUMN "+quotedIdentifier(iter.key())+" " +iter.value();
+ QString sql = QString("ALTER TABLE %1 ADD COLUMN %2 %3")
+ .arg(quotedIdentifier(iter.key()))
+ .arg(iter.value());
QgsDebugMsg(sql);
//send sql statement and do error handling
@@ -1956,7 +1953,9 @@
continue;
QString column = field_it->name();
- QString sql="ALTER TABLE "+mSchemaTableName+" DROP COLUMN "+quotedIdentifier(column);
+ QString sql = QString("ALTER TABLE %1 DROP COLUMN %2")
+ .arg(quotedIdentifier(column));
PGresult* result=PQexec(connection, sql.toUtf8());
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2008-04-02 18:31:09 UTC (rev 8312)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2008-04-02 22:35:33 UTC (rev 8313)
@@ -349,7 +349,6 @@
void loadFields();
bool mFetching; // true if a cursor was declared
- bool mFirstFetch; // true if fetch forward is called the first time after select
std::vector < QgsFeature > features;
QgsFieldMap attributeFields;
QString mDataComment;
@@ -364,14 +363,7 @@
//! Child thread for calculating count.
QgsPostgresCountThread mCountThread;
- * Pointer to the PostgreSQL query result object. If this pointer is 0,
- * there is no current selection set. Any future getNextFeature requests
- * will require execution of the select query to recreate the result set.
- PGresult *queryResult;
* Flag indicating if the layer data source is a valid PostgreSQL layer
bool valid;
