[QGIS Commit] r8315 - trunk/qgis/src/plugins/grass/config
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Apr 3 09:06:33 EDT 2008
Author: jef
Date: 2008-04-03 09:06:32 -0400 (Thu, 03 Apr 2008)
New Revision: 8315
   trunk/qgis/src/plugins/grass/config/default.qgc
fix grass toolbox
Modified: trunk/qgis/src/plugins/grass/config/default.qgc
--- trunk/qgis/src/plugins/grass/config/default.qgc	2008-04-03 00:38:44 UTC (rev 8314)
+++ trunk/qgis/src/plugins/grass/config/default.qgc	2008-04-03 13:06:32 UTC (rev 8315)
@@ -4,432 +4,429 @@
 <modules>
 <section label="GRASS MODULES">
 	<grass name="shell"/>
-		<section label="File">
-			<section label="Import">
-				<section label="Import raster">
-					<grass name="r.in.gdal"/>
-					<grass name="r.in.gdal.loc"/>
-					<grass name="r.in.ascii"/>
-					<grass name="r.in.poly"/>
-					<grass name="r.in.arc"/>
-					<grass name="r.in.gridatb"/>
-					<grass name="r.in.mat"/>
-					<grass name="i.in.spotvgt"/>
-					<grass name="r.in.srtm"/>
-					<grass name="r.in.aster"/>
-				</section>
-				<section label="Import vector">
-					<grass name="v.in.ogr"/>
-					<grass name="v.in.ogr.loc"/>
-					<grass name="v.in.dxf"/>
-					<grass name="v.in.e00"/>
-					<grass name="v.in.mapgen"/>
-					<grass name="v.in.db"/>
-					<grass name="v.in.garmin"/>
-					<grass name="v.in.gpsbabel"/>
-				</section>
+	<section label="File">
+		<section label="Import">
+			<section label="Import raster">
+				<grass name="r.in.gdal"/>
+				<grass name="r.in.gdal.loc"/>
+				<grass name="r.in.ascii"/>
+				<grass name="r.in.poly"/>
+				<grass name="r.in.arc"/>
+				<grass name="r.in.gridatb"/>
+				<grass name="r.in.mat"/>
+				<grass name="i.in.spotvgt"/>
+				<grass name="r.in.srtm"/>
+				<grass name="r.in.aster"/>
 			</section>
-			<section label="Export">
-				<section label="Export raster">
-					<grass name="r.out.gdal.gtiff"/>
-					<grass name="r.out.arc"/>
-					<grass name="r.out.gridatb"/>
-					<grass name="r.out.mat"/>
-					<grass name="r.out.bin"/>
-					<grass name="r.out.png"/>
-					<grass name="r.out.ppm"/>
-					<grass name="r.out.ppm3"/>
-					<grass name="r.out.pov"/>
-					<grass name="r.out.tiff"/>
-					<grass name="r.out.vrml"/>
-				</section>
-				<section label="Export vector">
-					<grass name="v.out.ogr"/>
-					<grass name="v.out.ogr.gml"/>
-					<grass name="v.out.ogr.mapinfo"/>
-					<grass name="v.out.ascii"/>
-					<grass name="v.out.dxf"/>
-				</section>
+			<section label="Import vector">
+				<grass name="v.in.ogr"/>
+				<grass name="v.in.ogr.loc"/>
+				<grass name="v.in.dxf"/>
+				<grass name="v.in.e00"/>
+				<grass name="v.in.mapgen"/>
+				<grass name="v.in.db"/>
+				<grass name="v.in.garmin"/>
+				<grass name="v.in.gpsbabel"/>
 			</section>
-			<section label="Map type conversion">
-				<section label="Convert a raster to vector">
-					<grass name="r.to.vect.point"/>
-					<grass name="r.to.vect.line"/>
-					<grass name="r.to.vect.area"/>
-				</section>
-				<section label="Convert a vector to raster">
-					<grass name="v.to.rast.constant"/>
-					<grass name="v.to.rast.attr"/>
-				</section>
+		</section>
+		<section label="Export">
+			<section label="Export raster">
+				<grass name="r.out.gdal.gtiff"/>
+				<grass name="r.out.arc"/>
+				<grass name="r.out.gridatb"/>
+				<grass name="r.out.mat"/>
+				<grass name="r.out.bin"/>
+				<grass name="r.out.png"/>
+				<grass name="r.out.ppm"/>
+				<grass name="r.out.ppm3"/>
+				<grass name="r.out.pov"/>
+				<grass name="r.out.tiff"/>
+				<grass name="r.out.vrml"/>
 			</section>
+			<section label="Export vector">
+				<grass name="v.out.ogr"/>
+				<grass name="v.out.ogr.gml"/>
+				<grass name="v.out.ogr.mapinfo"/>
+				<grass name="v.out.ascii"/>
+				<grass name="v.out.dxf"/>
+			</section>
 		</section>
-		<section label=" ">
+		<section label="Map type conversion">
+			<section label="Convert a raster to vector">
+				<grass name="r.to.vect.point"/>
+				<grass name="r.to.vect.line"/>
+				<grass name="r.to.vect.area"/>
+			</section>
+			<section label="Convert a vector to raster">
+				<grass name="v.to.rast.constant"/>
+				<grass name="v.to.rast.attr"/>
+			</section>
 		</section>
+	</section>
-		<section label="Config">
-			<section label="Region">
-				<section label="Region settings">
-					<grass name="g.region"/>
+	<section label=" ">
+	</section>
+	<section label="Config">
+		<section label="Region">
+			<section label="Region settings">
+				<grass name="g.region"/>
+			</section>
+			<section label="Projection management">
+				<section label="Print projection info of current Location">
+					<grass name="g.proj.print"/>
 				</section>
-				<section label="Projection management">
-					<section label="Print projection info of current Location">
-						<grass name="g.proj.print"/>
-					</section>
-					<section label="Print projection info from a file">
-						<grass name="g.proj.geo"/>
-						<grass name="g.proj.proj"/>
-					</section>
-					<section label="Print projection info from a file to create new location">
-						<grass name="g.proj.ascii.new"/>
-						<grass name="g.proj.geo.new"/>
-						<grass name="g.proj.proj.new"/>
-					</section>
+				<section label="Print projection info from a file">
+					<grass name="g.proj.geo"/>
+					<grass name="g.proj.proj"/>
 				</section>
-				<section label="Converte coordinates">
-					<grass name="m.cogo"/>
+				<section label="Print projection info from a file to create new location">
+					<grass name="g.proj.ascii.new"/>
+					<grass name="g.proj.geo.new"/>
+					<grass name="g.proj.proj.new"/>
 				</section>
 			</section>
+			<section label="Converte coordinates">
+				<grass name="m.cogo"/>
+			</section>
 		</section>
+	</section>
-		</section>
+	</section>
-		<section label="Raster">
-			<section label="Develop map">
-				<section label="Compress raster">
-					<grass name="r.compress"/>
-				</section>
-				<section label="Sets the boundary definitions for a raster map">
-					<grass name="r.region.region"/>
-					<grass name="r.region.raster"/>
-					<grass name="r.region.vector"/>
-					<grass name="r.region.edge"/>
-					<grass name="r.region.alignTo"/>
-				</section>
-				<section label="Manage raster cells value">
-					<grass name="r.null.val"/>
-					<grass name="r.null.to"/>
-					<grass name="r.quant"/>
-				</section>
-				<section label="Change resolution">
-					<grass name="r.resamp.stats"/>
-					<grass name="r.resamp.interp"/>
-					<grass name="r.resample"/>
-					<grass name="r.resamp.rst"/>
-				</section>
-				<section label="Raster support">
-					<grass name="r.support"/>
-					<grass name="r.support.stats"/>
-				</section>
-				<section label="Reproject raster from another Location">
-					<grass name="r.proj"/>
-				</section>
+	<section label="Raster">
+		<section label="Develop map">
+			<section label="Compress raster">
+				<grass name="r.compress"/>
 			</section>
-			<section label="Manage map colors">
-				<grass name="r.colors.table"/>
-				<grass name="r.colors.rules"/>
-				<grass name="r.blend"/>
-				<grass name="r.composite"/>
-				<grass name="r.his"/>
+			<section label="Sets the boundary definitions for a raster map">
+				<grass name="r.region.region"/>
+				<grass name="r.region.raster"/>
+				<grass name="r.region.vector"/>
+				<grass name="r.region.edge"/>
+				<grass name="r.region.alignTo"/>
 			</section>
-			<section label="Spatial analysis">
-				<section label="Buffer">
-					<grass name="r.buffer"/>
-				</section>
-				<section label="Mask">
-					<grass name="r.mask"/>
-				</section>
-				<section label="Map algebra">
-					<grass name="r.mapcalc"/>
-					<grass name="r.mapcalculator"/>
-				</section>
-				<section label="Neighborhood analysis">
-					<grass name="r.neighbors"/>
-					<grass name="v.neighbors"/>
-				</section>
-				<section label="Overlay maps">
-					<grass name="r.statistics"/>
-				</section>
-				<section label="Terrain analysis">
-					<grass name="r.cost"/>
-					<grass name="r.drain"/>
-					<grass name="r.shaded.relief"/>
-					<grass name="r.slope.aspect.slope"/>
-					<grass name="r.slope.aspect.aspect"/>
-					<grass name="r.param.scale"/>
-					<grass name="r.texture"/>
-					<grass name="r.texture.bis"/>
-					<grass name="r.los"/>
-				</section>
-				<section label="Transform features">
-					<grass name="r.clump"/>
-					<grass name="r.grow"/>
-					<grass name="r.thin"/>
-				</section>
+			<section label="Manage raster cells value">
+				<grass name="r.null.val"/>
+				<grass name="r.null.to"/>
+				<grass name="r.quant"/>
 			</section>
-			<section label="Spatial models">
-				<section label="Hydrologic modelling">
-					<grass name="r.carve"/>
-					<grass name="r.fill.dir"/>
-					<grass name="r.lake.xy"/>
-					<grass name="r.lake.seed"/>
-					<grass name="r.topidx"/>
-					<grass name="r.basins.fill"/>
-					<grass name="r.water.outlet"/>
-				</section>
+			<section label="Change resolution">
+				<grass name="r.resamp.stats"/>
+				<grass name="r.resamp.interp"/>
+				<grass name="r.resample"/>
+				<grass name="r.resamp.rst"/>
 			</section>
-			<section label="Change category values and labels">
-				<grass name="r.reclass.area.greater"/>
-				<grass name="r.reclass.area.lesser"/>
-				<grass name="r.reclass"/>
-				<grass name="r.recode"/>
-				<grass name="r.rescale"/>
+			<section label="Raster support">
+				<grass name="r.support"/>
+				<grass name="r.support.stats"/>
 			</section>
-			<section label="Surface management">
-				<section label="Create random points">
-					<grass name="r.random"/>
-					<grass name="r.random.cells"/>
-				</section>
-				<section label="Generate surface">
-					<grass name="v.kernel"/>
-					<grass name="r.surf.fractal"/>
-					<grass name="r.surf.gauss"/>
-					<grass name="r.surf.random"/>
-				</section>
-				<section label="Generate vector contour lines">
-					<grass name="r.contour"/>
-					<grass name="r.contour2"/>
-				</section>
-				<section label="Interpolate surface">
-					<grass name="r.bilinear"/>
-					<grass name="v.surf.bspline"/>
-					<grass name="r.surf.idw"/>
-					<grass name="r.surf.idw2"/>
-					<grass name="r.surf.contour"/>
-					<grass name="v.surf.idw"/>
-					<grass name="v.surf.rst"/>
-					<grass name="r.fillnulls"/>
-				</section>
+			<section label="Reproject raster from another Location">
+				<grass name="r.proj"/>
 			</section>
-			<section label="Reports and statistics">
-				<section label="Reports">
-					<grass name="r.cats"/>
-				</section>
-				<section label="Statistics">
-					<grass name="r.sum"/>
-					<grass name="r.report"/>
-					<grass name="r.average"/>
-					<grass name="r.median"/>
-					<grass name="r.mode"/>
-					<grass name="r.volume"/>
-					<grass name="r.surf.area"/>
-					<grass name="r.univar"/>
-					<grass name="r.covar"/>
-					<grass name="r.regression.line"/>
-					<grass name="r.coin"/>
-				</section>
-			</section>
 		</section>
+		<section label="Manage map colors">
+			<grass name="r.colors.table"/>
+			<grass name="r.colors.rules"/>
+			<grass name="r.blend"/>
+			<grass name="r.composite"/>
+			<grass name="r.his"/>
 		</section>
-		<section label="Vector">
-				<section label="Topology management">
-					<grass name="v.build.all"/>
-				</section>
-				<section label="Toolset for cleaning topology of vector map">
-					<grass name="v.clean.break"/>
-					<grass name="v.clean.snap"/>
-					<grass name="v.clean.rmdangles"/>
-					<grass name="v.clean.chdangles"/>
-					<grass name="v.clean.rmbridge"/>
-					<grass name="v.clean.chbridge"/>
-					<grass name="v.clean.rmdupl"/>
-					<grass name="v.clean.rmdac"/>
-					<grass name="v.clean.bpol"/>
-					<grass name="v.clean.prune"/>
-					<grass name="v.clean.rmarea"/>
-					<grass name="v.clean.rmline"/>
-					<grass name="v.clean.rmsa"/>
-				</section>
-				<section label="Geometry management">
-					<section label="Change the type of geometry elements">
-					<grass name="v.type.lb"/>
-					<grass name="v.type.bl"/>
-					<grass name="v.type.pc"/>
-					<grass name="v.type.cp"/>
-				</section>
-				<section label="Manage features">
-					<grass name="v.centroids"/>
-					<grass name="v.build.polylines"/>
-					<grass name="v.segment"/>
-					<grass name="v.to.points"/>
-					<grass name="v.parallel"/>
-					<grass name="v.dissolve"/>
-				</section>
-				<section label="Convert 2D vector to 3D by sampling raster">
-					<grass name="v.drape"/>
-				</section>
-				<section label="Reproject vector from another Location">
-					<grass name="v.transform"/>
-					<grass name="v.proj"/>
-				</section>
+		<section label="Spatial analysis">
+			<section label="Buffer">
+				<grass name="r.buffer"/>
 			</section>
-			<section label="Database connection">
-				<grass name="v.db.connect"/>
-				<grass name="v.db.sconnect"/>
-				<grass name="v.db.what.connect"/>
+			<section label="Mask">
+				<grass name="r.mask"/>
 			</section>
-				<section label="Extract features from vector">
-					<grass name="v.extract.where"/>
-					<grass name="v.extract.list"/>
-					<grass name="v.select.overlap"/>
-				</section>
-					<grass name="v.buffer"/>
-				</section>
-				<section label="Vector geometry analysis">
-					<grass name="v.distance"/>
-				</section>
-				<section label="Network analysis">
-					<grass name="v.net.nodes"/>
-					<grass name="v.net.alloc"/>
-					<grass name="v.net.iso"/>
-					<grass name="v.net.salesman"/>
-					<grass name="v.net.steiner"/>
-				</section>
-				<section label="Overlay">
-					<grass name="v.overlay.or"/>
-					<grass name="v.overlay.and"/>
-					<grass name="v.overlay.not"/>
-					<grass name="v.overlay.xor"/>
-				</section>
+			<section label="Map algebra">
+				<grass name="r.mapcalc"/>
+				<grass name="r.mapcalculator"/>
 			</section>
-			<section label="Change field">
-				<section label="Layers categories management">
-					<grass name="v.category.add"/>
-					<grass name="v.category.del"/>
-					<grass name="v.category.sum"/>
-				</section>
-				<section label="Reclass category values">
-					<grass name="v.reclass.file"/>
-					<grass name="v.reclass.attr"/>
-				</section>
+			<section label="Neighborhood analysis">
+				<grass name="r.neighbors"/>
+				<grass name="v.neighbors"/>
 			</section>
-			<section label="Work with vector points">
-				<section label="Create standard vectors">
-					<grass name="v.in.region"/>
-					<grass name="v.mkgrid.region"/>
-				</section>
-				<section label="Create points">
-					<grass name="v.random"/>
-				</section>
-				<section label="Delaunay triangulation, Voronoi diagram and convex hull">
-					<grass name="v.hull"/>
-					<grass name="v.delaunay.line"/>
-					<grass name="v.delaunay.area"/>
-					<grass name="v.voronoi.line"/>
-					<grass name="v.voronoi.area"/>
-				</section>
+			<section label="Overlay maps">
+				<grass name="r.statistics"/>
 			</section>
-			<section label="Vector update by other maps">
-				<grass name="v.rast.stats"/>
-				<grass name="v.what.vect"/>
-				<grass name="v.what.rast"/>
-				<grass name="v.sample"/>
+			<section label="Terrain analysis">
+				<grass name="r.cost"/>
+				<grass name="r.drain"/>
+				<grass name="r.shaded.relief"/>
+				<grass name="r.slope.aspect.slope"/>
+				<grass name="r.slope.aspect.aspect"/>
+				<grass name="r.param.scale"/>
+				<grass name="r.texture"/>
+				<grass name="r.texture.bis"/>
+				<grass name="r.los"/>
 			</section>
-			<section label="Report and statistics">
-				<grass name="v.to.db"/>
-				<grass name="v.report"/>
-				<grass name="v.univar"/>
-				<grass name="v.normal"/>
+			<section label="Transform features">
+				<grass name="r.clump"/>
+				<grass name="r.grow"/>
+				<grass name="r.thin"/>
 			</section>
 		</section>
+		<section label="Spatial models">
+			<section label="Hydrologic modelling">
+				<grass name="r.carve"/>
+				<grass name="r.fill.dir"/>
+				<grass name="r.lake.xy"/>
+				<grass name="r.lake.seed"/>
+				<grass name="r.topidx"/>
+				<grass name="r.basins.fill"/>
+				<grass name="r.water.outlet"/>
+			</section>
 		</section>
-		<section label="Imagery">
-			<section label="Develop images and group">
-				<grass name="i.image.mosaic"/>
+		<section label="Change category values and labels">
+			<grass name="r.reclass.area.greater"/>
+			<grass name="r.reclass.area.lesser"/>
+			<grass name="r.reclass"/>
+			<grass name="r.recode"/>
+			<grass name="r.rescale"/>
+		</section>
+		<section label="Surface management">
+			<section label="Create random points">
+				<grass name="r.random"/>
+				<grass name="r.random.cells"/>
 			</section>
-			<section label="Manage image colors">
-				<grass name="i.rgb.his"/>
-				<grass name="i.his.rgb"/>
-				<grass name="i.landsat.rgb"/>
-				<grass name="i.fusion.brovey"/>
+			<section label="Generate surface">
+				<grass name="v.kernel"/>
+				<grass name="r.surf.fractal"/>
+				<grass name="r.surf.gauss"/>
+				<grass name="r.surf.random"/>
 			</section>
-			<section label="Filter image">
-				<grass name="i.zc"/>
-				<grass name="r.mfilter"/>
+			<section label="Generate vector contour lines">
+				<grass name="r.contour"/>
+				<grass name="r.contour2"/>
 			</section>
-			<section label="Tassled cap vegetation index">
-				<grass name="i.tasscap4"/>
-				<grass name="i.tasscap5"/>
-				<grass name="i.tasscap7"/>
+			<section label="Interpolate surface">
+				<grass name="r.bilinear"/>
+				<grass name="v.surf.bspline"/>
+				<grass name="r.surf.idw"/>
+				<grass name="r.surf.idw2"/>
+				<grass name="r.surf.contour"/>
+				<grass name="v.surf.idw"/>
+				<grass name="v.surf.rst"/>
+				<grass name="r.fillnulls"/>
 			</section>
-			<section label="Transform image">
-				<grass name="i.fft"/>
-				<grass name="i.ifft"/>
+		</section>
+		<section label="Reports and statistics">
+			<section label="Reports">
+				<grass name="r.cats"/>
 			</section>
-				<grass name="r.describe"/>
-				<grass name="r.bitpattern"/>
-				<grass name="r.kappa"/>
-				<grass name="i.oif"/>
+			<section label="Statistics">
+				<grass name="r.sum"/>
+				<grass name="r.report"/>
+				<grass name="r.average"/>
+				<grass name="r.median"/>
+				<grass name="r.mode"/>
+				<grass name="r.volume"/>
+				<grass name="r.surf.area"/>
+				<grass name="r.univar"/>
+				<grass name="r.covar"/>
+				<grass name="r.regression.line"/>
+				<grass name="r.coin"/>
 			</section>
 		</section>
+	</section>
-		</section>
+	</section>
-		<section label="Database">
-			<section label="Database management">
-				<grass name="db.connect"/>
-				<grass name="db.connect.schema"/>
-				<grass name="db.login"/>
-				<grass name="db.in.ogr"/>
+	<section label="Vector">
+			<section label="Topology management">
+				<grass name="v.build.all"/>
 			</section>
-			<section label="Tables management">
-				<grass name="v.db.addtable"/>
-				<grass name="v.db.addcol"/>
-				<grass name="v.db.dropcol"/>
-				<grass name="v.db.renamecol"/>
+			<section label="Toolset for cleaning topology of vector map">
+				<grass name="v.clean.break"/>
+				<grass name="v.clean.snap"/>
+				<grass name="v.clean.rmdangles"/>
+				<grass name="v.clean.chdangles"/>
+				<grass name="v.clean.rmbridge"/>
+				<grass name="v.clean.chbridge"/>
+				<grass name="v.clean.rmdupl"/>
+				<grass name="v.clean.rmdac"/>
+				<grass name="v.clean.bpol"/>
+				<grass name="v.clean.prune"/>
+				<grass name="v.clean.rmarea"/>
+				<grass name="v.clean.rmline"/>
+				<grass name="v.clean.rmsa"/>
 			</section>
-			<section label="Queries">
-				<grass name="v.db.update_const"/>
-				<grass name="v.db.update_query"/>
-				<grass name="v.db.update_op"/>
-				<grass name="v.db.update_op_query"/>
-				<grass name="db.execute"/>
+			<section label="Change the type of geometry elements">
+				<grass name="v.type.lb"/>
+				<grass name="v.type.bl"/>
+				<grass name="v.type.pc"/>
+				<grass name="v.type.cp"/>
 			</section>
-			<section label="Others">
-				<grass name="v.db.join"/>
-				<grass name="v.db.univar"/>
+			<section label="Manage features">
+				<grass name="v.centroids"/>
+				<grass name="v.build.polylines"/>
+				<grass name="v.segment"/>
+				<grass name="v.to.points"/>
+				<grass name="v.parallel"/>
+				<grass name="v.dissolve"/>
 			</section>
+			<section label="Convert 2D vector to 3D by sampling raster">
+				<grass name="v.drape"/>
+			</section>
+			<section label="Reproject vector from another Location">
+				<grass name="v.transform"/>
+				<grass name="v.proj"/>
+			</section>
 		</section>
+		<section label="Database connection">
+			<grass name="v.db.connect"/>
+			<grass name="v.db.sconnect"/>
+			<grass name="v.db.what.connect"/>
 		</section>
-		<section label="3d Visualization">
-			<grass name="nviz"/>
+			<section label="Extract features from vector">
+				<grass name="v.extract.where"/>
+				<grass name="v.extract.list"/>
+				<grass name="v.select.overlap"/>
+			</section>
+				<grass name="v.buffer"/>
+			</section>
+			<section label="Vector geometry analysis">
+				<grass name="v.distance"/>
+			</section>
+			<section label="Network analysis">
+				<grass name="v.net.nodes"/>
+				<grass name="v.net.alloc"/>
+				<grass name="v.net.iso"/>
+				<grass name="v.net.salesman"/>
+				<grass name="v.net.steiner"/>
+			</section>
+			<section label="Overlay">
+				<grass name="v.overlay.or"/>
+				<grass name="v.overlay.and"/>
+				<grass name="v.overlay.not"/>
+				<grass name="v.overlay.xor"/>
+			</section>
 		</section>
+		<section label="Change field">
+			<section label="Layers categories management">
+				<grass name="v.category.add"/>
+				<grass name="v.category.del"/>
+				<grass name="v.category.sum"/>
+			</section>
+			<section label="Reclass category values">
+				<grass name="v.reclass.file"/>
+				<grass name="v.reclass.attr"/>
+			</section>
+		</section>
+		<section label="Work with vector points">
+			<section label="Create standard vectors">
+				<grass name="v.in.region"/>
+				<grass name="v.mkgrid.region"/>
+			</section>
+			<section label="Create points">
+				<grass name="v.random"/>
+			</section>
+			<section label="Delaunay triangulation, Voronoi diagram and convex hull">
+				<grass name="v.hull"/>
+				<grass name="v.delaunay.line"/>
+				<grass name="v.delaunay.area"/>
+				<grass name="v.voronoi.line"/>
+				<grass name="v.voronoi.area"/>
+			</section>
+		</section>
+		<section label="Vector update by other maps">
+			<grass name="v.rast.stats"/>
+			<grass name="v.what.vect"/>
+			<grass name="v.what.rast"/>
+			<grass name="v.sample"/>
+		</section>
+		<section label="Report and statistics">
+			<grass name="v.to.db"/>
+			<grass name="v.report"/>
+			<grass name="v.univar"/>
+			<grass name="v.normal"/>
+		</section>
+	</section>
+	</section>
+	<section label="Imagery">
+		<section label="Develop images and group">
+			<grass name="i.image.mosaic"/>
 		</section>
+		<section label="Manage image colors">
+			<grass name="i.rgb.his"/>
+			<grass name="i.his.rgb"/>
+			<grass name="i.landsat.rgb"/>
+			<grass name="i.fusion.brovey"/>
+		</section>
+		<section label="Filter image">
+			<grass name="i.zc"/>
+			<grass name="r.mfilter"/>
+		</section>
+		<section label="Tassled cap vegetation index">
+			<grass name="i.tasscap4"/>
+			<grass name="i.tasscap5"/>
+			<grass name="i.tasscap7"/>
+		</section>
+		<section label="Transform image">
+			<grass name="i.fft"/>
+			<grass name="i.ifft"/>
+		</section>
+			<grass name="r.describe"/>
+			<grass name="r.bitpattern"/>
+			<grass name="r.kappa"/>
+			<grass name="i.oif"/>
+		</section>
+	</section>
-		<section label="Help">
-			<grass name="g.manual"/>
+	</section>
+	<section label="Database">
+		<section label="Database management">
+			<grass name="db.connect"/>
+			<grass name="db.connect.schema"/>
+			<grass name="db.login"/>
+			<grass name="db.in.ogr"/>
 		</section>
+		<section label="Tables management">
+			<grass name="v.db.addtable"/>
+			<grass name="v.db.addcol"/>
+			<grass name="v.db.dropcol"/>
+			<grass name="v.db.renamecol"/>
+		</section>
+		<section label="Queries">
+			<grass name="v.db.update_const"/>
+			<grass name="v.db.update_query"/>
+			<grass name="v.db.update_op"/>
+			<grass name="v.db.update_op_query"/>
+			<grass name="db.execute"/>
+		</section>
+		<section label="Others">
+			<grass name="v.db.join"/>
+			<grass name="v.db.univar"/>
+		</section>
 	</section>
+	</section>
+	<section label="3d Visualization">
+		<grass name="nviz"/>
+	</section>
+	</section>
+	<section label="Help">
+		<grass name="g.manual"/>
+	</section>
 </section>
 </modules>
More information about the QGIS-commit mailing list
