[QGIS Commit] r8320 - in branches/rendercontext-branch/src: app/composer core core/raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Apr 6 06:49:26 EDT 2008
Author: mhugent
Date: 2008-04-06 06:49:26 -0400 (Sun, 06 Apr 2008)
New Revision: 8320
   branches/rendercontext-branch/src/app/composer/qgscomposer.cpp
   branches/rendercontext-branch/src/app/composer/qgscomposermap.h
   branches/rendercontext-branch/src/core/qgsmaprender.cpp
   branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp
Set vector scale factor such that widths are always mm. Scale raster layers to have the correct resolution in print output. Point symbol resolution is not handled yet
Modified: branches/rendercontext-branch/src/app/composer/qgscomposer.cpp
--- branches/rendercontext-branch/src/app/composer/qgscomposer.cpp	2008-04-04 19:16:34 UTC (rev 8319)
+++ branches/rendercontext-branch/src/app/composer/qgscomposer.cpp	2008-04-06 10:49:26 UTC (rev 8320)
@@ -332,6 +332,7 @@
   //set the resolution and paper orientation each time we call up the dialog, not just the first time we run it
   mPrinter->setResolution(mComposition->resolution());
   if (mComposition->paperOrientation() == QgsComposition::Portrait)
     mPrinter->setOrientation(QPrinter::Portrait);
Modified: branches/rendercontext-branch/src/app/composer/qgscomposermap.h
--- branches/rendercontext-branch/src/app/composer/qgscomposermap.h	2008-04-04 19:16:34 UTC (rev 8319)
+++ branches/rendercontext-branch/src/app/composer/qgscomposermap.h	2008-04-06 10:49:26 UTC (rev 8320)
@@ -71,7 +71,10 @@
     bool writeXML( QDomNode & node, QDomDocument & document, bool temp = false );
     bool readXML( QDomNode & node );
-    /** \brief Draw to paint device */
+    /** \brief Draw to paint device
+	@param extent map extent
+	@param size size in scene coordinates
+	@param dpi scene dpi*/
     void draw(QPainter *painter, const QgsRect& extent, const QSize& size, int dpi);
     /** \brief Reimplementation of QCanvasItem::paint - draw on canvas */
Modified: branches/rendercontext-branch/src/core/qgsmaprender.cpp
--- branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-04-04 19:16:34 UTC (rev 8319)
+++ branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-04-06 10:49:26 UTC (rev 8320)
@@ -212,6 +212,12 @@
   if (mDrawing)
     return;
+  QPaintDevice* thePaintDevice = painter->device();
+  if(!thePaintDevice)
+      return;
   mDrawing = true;
@@ -233,8 +239,9 @@
   //calculate scale factor
   //use the specified dpi and not those from the paint device
   //because sometimes QPainter units are in a local coord sys (e.g. in case of QGraphicsScene)
-  double meanDpi = mScaleCalculator->dpi();
-  double scaleFactor = meanDpi/25.4;
+  double sceneDpi = mScaleCalculator->dpi();
+  double scaleFactor = sceneDpi/25.4; //units should always be mm
+  double rasterScaleFactor = (thePaintDevice->logicalDpiX() + thePaintDevice->logicalDpiY()) / 2.0 /sceneDpi;
   mRenderContext.setScaleFactor(scaleFactor);
   // render all layers in the stack, starting at the base
@@ -303,6 +310,29 @@
       mRenderContext.setCoordTransform(ct);
+      //decide if we have to scale the raster
+      //this is necessary in case QGraphicsScene is used
+      bool scaleRaster = false;
+      QgsMapToPixel rasterMapToPixel;
+      QgsMapToPixel bk_mapToPixel;
+      double debug = fabs(rasterScaleFactor - 1.0);
+      if(ml->type() == QgsMapLayer::RASTER && fabs(rasterScaleFactor - 1.0) > 0.000001)
+	  scaleRaster = true;
+      if(scaleRaster)
+	  bk_mapToPixel = mRenderContext.mapToPixel();
+	  rasterMapToPixel = mRenderContext.mapToPixel();
+	  rasterMapToPixel.setMapUnitsPerPixel(mRenderContext.mapToPixel().mapUnitsPerPixel() / rasterScaleFactor);
+	  rasterMapToPixel.setYmax(mSize.height() * rasterScaleFactor);
+	  mRenderContext.setMapToPixel(rasterMapToPixel);
+	  mRenderContext.painter()->save();
+	  mRenderContext.painter()->scale(1.0/rasterScaleFactor, 1.0/rasterScaleFactor);
       if (!ml->draw(mRenderContext))
 	  emit drawError(ml);
@@ -316,6 +346,12 @@
 	    emit drawError(ml);
+      if(scaleRaster)
+	  mRenderContext.setMapToPixel(bk_mapToPixel);
+	  mRenderContext.painter()->restore();
       disconnect(ml, SIGNAL(drawingProgress(int,int)), this, SLOT(onDrawingProgress(int,int)));
Modified: branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp
--- branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp	2008-04-04 19:16:34 UTC (rev 8319)
+++ branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp	2008-04-06 10:49:26 UTC (rev 8320)
@@ -1265,24 +1265,25 @@
   else
     if ((myRasterViewPort->drawableAreaXDim) > 4000 &&  (myRasterViewPort->drawableAreaYDim > 4000))
-      // We have scaled one raster pixel to more than 4000 screen pixels. What's the point of showing this layer?
-      // Instead, we just stop displaying the layer. Prevents allocating the entire world of memory for showing
-      // very few pixels.
-      // (Alternatively, we have a very big screen > 2000 x 2000)
-      QgsDebugMsg("Too zoomed in! Displaying raster requires too much memory. Raster will not display");
-    } else {
-      // Otherwise use the old-fashioned GDAL direct-drawing style
-      // TODO: Move into its own GDAL provider.
-      // \/\/\/ - commented-out to handle zoomed-in rasters
-    //    draw(theQPainter,myRasterViewPort);
-      // /\/\/\ - commented-out to handle zoomed-in rasters
-      // \/\/\/ - added to handle zoomed-in rasters
-      draw(theQPainter, myRasterViewPort, &theQgsMapToPixel);
-      // /\/\/\ - added to handle zoomed-in rasters
+	// We have scaled one raster pixel to more than 4000 screen pixels. What's the point of showing this layer?
+	// Instead, we just stop displaying the layer. Prevents allocating the entire world of memory for showing
+	// very few pixels.
+	// (Alternatively, we have a very big screen > 2000 x 2000)
+	QgsDebugMsg("Too zoomed in! Displaying raster requires too much memory. Raster will not display");
+    else
+	// Otherwise use the old-fashioned GDAL direct-drawing style
+	// TODO: Move into its own GDAL provider.
+	// \/\/\/ - commented-out to handle zoomed-in rasters
+	//    draw(theQPainter,myRasterViewPort);
+	// /\/\/\ - commented-out to handle zoomed-in rasters
+	// \/\/\/ - added to handle zoomed-in rasters
+	draw(theQPainter, myRasterViewPort, &theQgsMapToPixel);
+	// /\/\/\ - added to handle zoomed-in rasters
   delete myRasterViewPort;
More information about the QGIS-commit mailing list
