[QGIS Commit] r8333 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Apr 10 03:59:27 EDT 2008
Author: dassau
Date: 2008-04-10 03:59:27 -0400 (Thu, 10 Apr 2008)
New Revision: 8333
   docs/trunk/english_us/user_guide/working_with_vector.tex
more typos from Paolo
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2008-04-09 15:20:53 UTC (rev 8332)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2008-04-10 07:59:27 UTC (rev 8333)
@@ -824,9 +824,9 @@
 \minisec{Editing Vertices of a Feature}
 \index{vector layers!editing!vertex}
-For both PostgreSQL/PostGIS and shapefile-based layers, the verticies of features can be edited.
+For both PostgreSQL/PostGIS and shapefile-based layers, the vertices of features can be edited.
-Verticies can be directly edited, that is, you don't
+vertices can be directly edited, that is, you don't
 have to choose which feature to edit before you can change
 its geometry.
 In some cases, several features may share the same vertex
@@ -856,12 +856,12 @@
 \minisec{Adding Vertices of a Feature}
 \index{vector layers!adding!vertex}
-You can add new verticies to a feature by using the \textit{Add Vertex} icon
+You can add new vertices to a feature by using the \textit{Add Vertex} icon
 on the toolbar.
-Note, it doesn't make sense to add more verticies to a Point feature!
+Note, it doesn't make sense to add more vertices to a Point feature!
-In this version of QGIS, verticies can only be added to an \textit{existing} line
+In this version of QGIS, vertices can only be added to an \textit{existing} line
 segment of a line feature.  If you want to extend a line beyond its end,
 you will need to move the terminating vertex first, then add a new vertex where
 the terminus used to be.
@@ -869,13 +869,13 @@
 \minisec{Moving Vertices of a Feature}
 \index{vector layers!moving!vertex}
-You can move verticies using the \textit{Move Vertex} icon
+You can move vertices using the \textit{Move Vertex} icon
 on the toolbar.
 \minisec{Deleting Vertices of a Feature}
 \index{vector layers!deleting!vertex}
-You can delete verticies by using the \textit{Delete Vertex} icon
+You can delete vertices by using the \textit{Delete Vertex} icon
 on the toolbar.
 Note, it doesn't make sense to delete the vertex of a Point feature!
@@ -996,7 +996,7 @@
 \minisec{Snap Mode}
 \index{editing!snap}
-QGIS allows digitized verticies to be snapped to other verticies of the same layer. To
+QGIS allows digitized vertices to be snapped to other vertices of the same layer. To
 set the snapping tolerance, go to
 \textit{Settings}->\textit{Project Properties}->\textit{General}->\textit{Snapping Tolerance}.
 Note that the snapping tolerance is in map units.
More information about the QGIS-commit mailing list
