[QGIS Commit] r8377 - docs/branches/0.9.1/spanish/user_guide
svn_qgis at osgeo.org
Tue Apr 22 17:50:42 EDT 2008
Author: cdavilam
Date: 2008-04-22 17:50:42 -0400 (Tue, 22 Apr 2008)
New Revision: 8377
docs/branches/0.9.1/spanish/user_guide/creating_applications.tex
docs/branches/0.9.1/spanish/user_guide/getting_started.tex
docs/branches/0.9.1/spanish/user_guide/literature.tex
Started translation of Creating aplications and other chapters reviewed
Modified: docs/branches/0.9.1/spanish/user_guide/creating_applications.tex
--- docs/branches/0.9.1/spanish/user_guide/creating_applications.tex 2008-04-19 18:21:42 UTC (rev 8376)
+++ docs/branches/0.9.1/spanish/user_guide/creating_applications.tex 2008-04-22 21:50:42 UTC (rev 8377)
@@ -1,75 +1,72 @@
-\section{Creating Applications}
+\section{Crear aplicaciones}
-One of the goals of QGIS is to provide not only an application, but a set of
-libraries that can be used to create new applications. This goal has been
-realized with the refactoring of libraries that took place after the release of
-0.8. With the release of 0.9, development of standalone
-applications using either C++ or Python is possible.
+Uno de los objetivos de QGIS es proporcionar no sólo una aplicación, sino un conjunto de
+bibliotecas que se puedan usar para crear nuevas aplicaciones. Este objetivo se ha realizado
+con la reconstrucción de bibliotecas que tuvo lugar después del lanzamiento de la versión 0.8.
+Con el lanzamiento de la 0.9 es posible el desarrollo de aplicaciones independientes que usen
+bien C++ o Python.
-In this chapter we'll take a brief look at the process for creating a standalone
-Python application. The QGIS blog has several examples of creating
-PyQGIS\footnote{An application created using Python and the QGIS bindings}
-applications. We'll use one of them as a starting point to get a look at how to
-create an application.
+En este capítulo echaremos una breve ojeada al proceso de crear aplicaciones independientes en
+Python. El blog de QGIS tiene varios ejemplos de creación de aplicaciones en
+PyQGIS\footnote{An application created using Python and the QGIS bindings}. Usaremos uno de
+ellos como punto de partida para tener una idea de cómo crear una aplicación.
-The features we want in the application are:
+Las funciones que queremos en la aplicación son:
\begin{itemize}
-\item Load a vector layer
-\item Pan
-\item Zoom in and out
-\item Zoom to the full extent of the layer
-\item Set custom colors when the layer is loaded
+\item Cargar una capa vectorial.
+\item Panorámica.
+\item Acercar y alejar zum.
+\item Zum a la extesión completa de la capa.
+\item Estalecer colores personalizados al cargar la capa.
\end{itemize}
-This is a pretty minimal feature set. Let's start by designing the GUI using
-Qt Designer.
+Se trata de un conjunto mínimo de funciones. Comencemos por diseñar la GUI usando Qt Designer.
-\subsection{Designing the GUI}
+\subsection{Diseñar la GUI}
-Since we are creating a minimalistic application, we'll take the same
-approach with the GUI. Using Qt Designer, we create a simple MainWindow with
-no menu or toolbars. This gives us a blank slate to work with. To create the
-MainWindow:
+Puesto que estamos creando una aplicación mínima, usaremos la misma aproximación con la GUI.
+Usando Qt Designer, creamos una MainWindow sencilla sin menús ni barras de herramientas.
+Esto nos da un slate en blando con el que trabajar. Para crear la MainWindow:
\begin{enumerate}
-\item Create a directory for developing the application and change to it
-\item Run Qt Designer
-\item The "New Form" dialog should appear. If it doesn't, choose
-\textsl{New Form...} from the \textsl{File} menu.
-\item Choose "Main Window" from the templates/forms list
-\item Click \textsl{Create}
-\item Resize the new window to something manageable
-\item Find the Frame widget in the list (under Containers) and drag it to
-the main window you just created
-\item Click outside the frame to select the main window area
-\item Click on the \textsl{Lay Out in a Grid} tool. When you do, the frame
-will expand to fill your entire main window
-\item Save the form as \textsl{mainwindow.ui}
-\item Exit Qt Designer
+\item Crear un directorio para desarrollar la aplicación y cambiar a él.
+\item Ejecutar Qt Designer.
+\item Deba aparecer el diálogo "Formulario nuevo". Si no lo hace, seleccionar
+\textsl{Formulario nuevo...} del menú \textsl{Archivo}.
+\item Seleccionar "Ventana principal" de la lista de plantillas/formularios.
+\item Pulsar \textsl{Crear}.
+\item Redimensionar la nueva ventana a algo manejable.
+\item Buscar el widget Marco (Frame) en la lista (bajo Contenedores) y arrastrarlo a la ventana principal
+que acabamos de crear.
+\item Pulsar fuera del marco para seleccionar el área de la ventana principal.
+\item Pulsar en la herramienta \textsl{Lay Out in a Grid}. Al hacerlo el marco se expandirá hasta
+ocupar totalmente la ventana principal.
+\item Guardar el formulario como \textsl{mainwindow.ui}.
+\item Salir de Qt Designer.
\end{enumerate}
-Now compile the form using the PyQt interface compiler:
+Ahora compile el formulario usando el compilador de la interfaz de PyQt:
\begin{verbatim}
pyuic4 -o mainwindow_ui.py mainwindow.ui
\end{verbatim}
-This creates the Python source for the main window GUI. Next we need to create
-the application code to fill the blank slate with some tools we can use.
+Esto crea la fuente de Python para la ventana principal de la GUI. Lo siguiente que necesitamos es crear
+el código de la aplicación para rellenar la slate en blanco con algunas herramientas que podamos usar.
-\subsection{Creating the MainWindow}
+\subsection{Crear la VentanaPrincipal}
-Now we are ready to write the \textbf{MainWindow} class that will do the real work.
-Since it takes up quite a few lines, we'll look at it in chunks, starting
-with the import section and environment setup:
+Ahora estamos listos para escribir la clase \textbf{MainWindow} que hará el trabajo real. Puesto que
+Since it takes up quite a few lines, we'll look at it in chunks, comenzaremos con la sección de
+importación y la configuración del entorno:
\begin{verbatim}
1 # Loosely based on:
-2 # Original C++ Tutorial 2 by Tim Sutton
-3 # ported to Python by Martin Dobias
-4 # with enhancements by Gary Sherman for FOSS4G2007
-5 # Licensed under the terms of GNU GPL 2
+2 # C++ Tutorial 2 oribignal por Tim Sutton
+3 # migrado a Python por Martin Dobias
+4 # con mejoras por Gary Sherman para FOSS4G2007
+5 # Licenciado bajo los términos de la GNU GPL 2
6
7 from PyQt4.QtCore import *
8 from PyQt4.QtGui import *
@@ -77,54 +74,53 @@
10 from qgis.gui import *
11 import sys
12 import os
-13 # Import our GUI
+13 # Importar nuestra GUI
14 from mainwindow_ui import Ui_MainWindow
-15 # Import our resources (icons)
+15 # Importar nuestros recursos (iconos)
16 import resources
17
-18 # Environment variable QGISHOME must be set to the 0.9 install directory
-19 # before running this application
+18 # La variable de entorno QGISHOME se debe establecer al directorio de instalación de la versión 0.9
+19 # antes de ejecutar esta aplicación
20 qgis_prefix = os.getenv("QGISHOME")
\end{verbatim}
-Some of this should look familiar from our plugin, especially the PyQt4 and
-QGIS imports. Some specific things to note are the import of our GUI in line
-14 and the import of our resources file on line 16.
+Parte de esto debería resultar familiar de nuestro complemento, especialmente las importaciones de PyQt4 y
+QGIS. Algunas cosas específicas que destacar son la importacion de nuestra GUI en la línea 14 y la
+importación de nuestro archivo de recursos en la línea 16.
-Our application needs to know where to find the QGIS installation. Because
-of this, we set the QGISHOME environment variable to point to the install
-directory of QGIS 0.9. In line 20 we store this value from
-the environment for later use.
+Nuestra aplicación necesita saber dóndo encontrar la instalación de QGIS. Por eso, establecemos la
+variable de entorno QGISHOME para que apunto al directorio de instalación de QGIS 0.9. En la línea
+20 guardamos este valor del entorno para usarla después.
-Next we need to create our \textbf{MainWindow} class which will contain
-all the logic of our application.
+Lo siguiente que necesitamos es crear nuestra clase \textbf{MainWindow} que contendrá toda la lógica de
+nuestra aplicación.
\begin{verbatim}
21 class MainWindow(QMainWindow, Ui_MainWindow):
22
23 def __init__(self):
24 QMainWindow.__init__(self)
25
-26 # Required by Qt4 to initialize the UI
+26 # Requerido por Qt4 para inicializar la UI
27 self.setupUi(self)
28
-29 # Set the title for the app
+29 # Establecer el título de la aplicación
30 self.setWindowTitle("FOSS4G2007 Demo App")
31
-32 # Create the map canvas
+32 # Crear el lienzo del mapa
33 self.canvas = QgsMapCanvas()
-34 # Set the background color to light blue something
+34 # Establecer el color de fondo a azul claro
35 self.canvas.setCanvasColor(QColor(200,200,255))
36 self.canvas.enableAntiAliasing(True)
37 self.canvas.useQImageToRender(False)
38 self.canvas.show()
39
-40 # Lay our widgets out in the main window using a
+40 # Disponer nuestros widgets en la ventana principal usando una
41 # vertical box layout
42 self.layout = QVBoxLayout(self.frame)
43 self.layout.addWidget(self.canvas)
44
-45 # Create the actions for our tools and connect each to the appropriate
-46 # method
+45 # Crear las acciones para nuestras herramientas y conectar cada una con el método
+46 # adecuado
47 self.actionAddLayer = QAction(QIcon(":/foss4g2007/mActionAddLayer.png"),
48 \
49 "Add Layer", self.frame)
@@ -143,7 +139,7 @@
62 self.connect(self.actionZoomFull, SIGNAL("activated()"),
63 self.zoomFull)
64
-65 # Create a toolbar
+65 # Crear una barra de herramientas
66 self.toolbar = self.addToolBar("Map")
67 # Add the actions to the toolbar
68 self.toolbar.addAction(self.actionAddLayer)
@@ -152,15 +148,15 @@
71 self.toolbar.addAction(self.actionPan);
72 self.toolbar.addAction(self.actionZoomFull);
73
-74 # Create the map tools
+74 # Crear las herramientas de mapa
75 self.toolPan = QgsMapToolPan(self.canvas)
76 self.toolZoomIn = QgsMapToolZoom(self.canvas, False) # false = in
77 self.toolZoomOut = QgsMapToolZoom(self.canvas, True) # true = out
\end{verbatim}
-Lines 21 through 27 are the basic declaration and initialization of the
-\textbf{MainWindow} and the set up of the user interface using the
-\textsl{setupUi} method. This is required for all applications.
+Las líneas 21 a 27 son la declaración básica y la inicialización de la \textbf{MainWindow}
+y la configuración de la interfaz de usuario usando el método \textsl{setupUi}. Esto hace
+falta para todas las aplicaciones.
Next we set the title for the application so it says something more
interesting than 'MainWindow' (line 30). Once that is
Modified: docs/branches/0.9.1/spanish/user_guide/getting_started.tex
--- docs/branches/0.9.1/spanish/user_guide/getting_started.tex 2008-04-19 18:21:42 UTC (rev 8376)
+++ docs/branches/0.9.1/spanish/user_guide/getting_started.tex 2008-04-22 21:50:42 UTC (rev 8377)
@@ -1,7 +1,7 @@
% vim:autoindent:set textwidth=78:
-\section{Comenzando}\label{label_getstarted}
+\section{Comenzar}\label{label_getstarted}
-Este capítulo ofrece un vistazo rápido de QGIS funcionando con datos disponibles
+Este capítulo ofrece un vistazo rápido del funcionamiento de QGIS con datos disponibles
en la página web de QGIS.
\subsection{Instalación}\label{label_installation}
@@ -11,15 +11,15 @@
La instrucciones de instalación se distribuyen con el código fuente de QGIS y
también están disponibles en \url{http://qgis.org}.
-Los paquetes estándares de instalación están disponibles para Windows y Mac OS X.
+Los paquetes estándar de instalación están disponibles para Windows y Mac OS X.
Se proporcionan los paquetes binarios para la mayoría de sabores de GNU/Linux.
-Obtén la última información sobre los paquetes binarios en el sitio web QGIS
+Obtenga la última información sobre los paquetes binarios en el sitio web QGIS
\url{http://download.qgis.org}.
\subsection{Datos de ejemplo}\label{label_sampledata}
\index{data!sample}
-Si no tienes datos SIG a mano, puedes obtener un conjunto de datos de Alaska
+Si no tiene datos SIG a mano, puede obtener un conjunto de datos de Alaska
de la web de QGIS \url{http://qgis.org}. La proyección para los datos de Alaska
es Albers Equal Area con las unidades en metros:
@@ -40,8 +40,8 @@
UNIT["Meter",1.0]]
\end{verbatim}
-Para utilizarlo con GRASS, una base de datos de ejemplo GRASS (p.ej. Spearfish)
-se puede obtener de la web-SIG oficial GRASS \url{http://grass.itc.it/download/data.php}.
+Para utilizarlo con GRASS, se puede obtener una base de datos de GRASS de ejemplo (p.ej. Spearfish)
+de la web-SIG oficial de GRASS \url{http://grass.osgeo.org/download/data.php}.
La proyeccción oficial del conjunto de datos de Spearfish es UTM Zone 13, Northern Hemisphere:
\begin{verbatim}
@@ -63,19 +63,19 @@
Estos conjuntos de datos se utilizarán como base para muchos ejemplos y
capturas de pantalla en este documento.
-\subsection{Iniciando QGIS}\label{label_startinqgis}
+\subsection{Iniciar QGIS}\label{label_startinqgis}
-Suponiendo que tienes QGIS instalado en el PATH, puedes iniciar QGIS tecleando:
-\textbf{qgis} en línea de comandos o haciendo doble click sobre el enlace a QGIS
-(o acceso directo) sobre el escritorio. Bajo MS Windows, inicia QGIS a través
-del menú Inicio, y bajo Mac OS X, haz doble click en tu carpeta de aplicaciones.
+Suponiendo que tiene QGIS instalado en el PATH, puede iniciar QGIS tecleando:
+\textbf{qgis} en línea de órdenes o haciendo doble clic sobre el enlace a QGIS
+(o acceso directo) del escritorio. Bajo MS Windows, inicie QGIS a través
+del menú Inicio, y bajo Mac OS X, haga doble click en el icono de su carpeta de aplicaciones.
-\subsubsection{Opciones de Línea de Comandos}\index{command line options}
+\subsubsection{Opciones de línea de órdenes}\index{command line options}
\label{label_commandline}
QGIS soporta un buen número de opciones cuando se inicia desde la línea de
-comandos. Para obtener la lista de opciones, teclea \texttt{qgis ---help} en la
-línea de comandos.
+órdenes. Para obtener la lista de opciones, teclee \texttt{qgis ---help} en la
+línea de órdenes.
La sentencia de uso para QGIS es:
\small
@@ -103,43 +103,43 @@
\end{verbatim}
\normalsize
-\begin{Tip} \caption{\textsc{Ejemplo utilizando argumentos en línea de comandos}}
-\qgistip{Puedes iniciar QGIS especificando uno o más archivos de datos sobre la
-línea de comandos. Por ejemplo, suponiendo que estas en tu directorio de datos,
-puedes iniciar QGIS con dos archivos shape y un raster preparados para cargarlos
-con el arranque utilizando el siguiente comando:
+\begin{Tip} \caption{\textsc{Ejemplo utilizando argumentos en línea de órdenes}}
+\qgistip{Puede iniciar QGIS especificando uno o más archivos de datos sobre la
+línea de órdenes. Por ejemplo, suponiendo que está en su directorio de datos,
+puede iniciar QGIS con dos archivos shape y un ráster preparados para cargarlos
+en el arranque utilizando la siguiente orden:
\ttfamily{qgis ak\_shade.tif alaska.shp majrivers.shp}
\end{Tip}
-\minisec{Opción de línea de comandos \texttt{---snapshot}}
-Esta opción te permite crear una captura de pantalla en formato PNG de la vista actual.
-Esto puede ser útil cuando tienes muchos proyectos y quieres generar capturas de tus datos.
+\minisec{Opción de línea de órdenes \texttt{---snapshot}}
+Esta opción permite crear una captura de pantalla en formato PNG de la vista actual.
+Esto puede ser útil cuando se tienen muchos proyectos y se quieren generar capturas de tus datos.
-Actualmente esto genera un fichero PNG con 800x600 pixeles. Se puede añadir un nombre despues de
+Actualmente esto genera un fichero PNG con 800x600 pixeles. Se puede añadir un nombre después de
\texttt{---snapshot}.
-\minisec{Opción de línea de comandos \texttt{---lang}}
-Basado en tu QGIS local, selecciona la localización correcta. Si quieres cambiar el lenguaje,
-puedes proporcionar otro lenguaje con esta opción.
+\minisec{Opción de línea de órdenes \texttt{---lang}}
+En base a su configuración local, QGIS selecciona la localización correcta. Si se quiere cambiar el idioma,
+se puede proporcionar otro idioma con esta opción.
-\minisec{Opción de línea de comandos \texttt{---project}}
-También es posible iniciar QGIS con un proyecto existente. Simplemente añade
-la opción \texttt{--project} seguida del nombre de tu proyecto y QGIS se abrirá
+\minisec{Opción de línea de órdenes \texttt{---project}}
+También es posible iniciar QGIS con un proyecto existente. Simplemente añada
+la opción \texttt{--project} seguida del nombre de su proyecto y QGIS se abrirá
con todas las capas cargadas definidas en el fichero dado.
-\minisec{Opción de línea de comandos \texttt{---extent}}
-Para arrancar con un extensión específica del mapa utiliza esta opción. Necesitas
+\minisec{Opción de línea de órdenes \texttt{---extent}}
+Para arrancar con una extensión específica del mapa utilice esta opción. Es necesario
añadir los límites en el siguiente orden separados por comas:
\begin{verbatim}
--extent xmin,ymin,xmax,ymax
\end{verbatim}
-\subsection{GUI QGIS (Interfaz Gráfica de Usuario)}\index{main window}
+\subsection{Interfaz Gráfica de Usuario (GUI) de QGIS}\index{main window}
\label{label_qgismainwindow}
-Cuando QGIS arranca, te encuentras con la GUI como se muestra abajo
+Cuando QGIS arranca, se encuentra con la GUI como se muestra abajo
(los números del 1 hasta el 6 en ovalos azules señalan las seis áreas principales
de la interfaz que se describen abajo):
@@ -150,21 +150,21 @@
\end{center}
\end{figure}
-\textbf{Nota:} La decoración de tu ventana (barra de título, etc.) puede aparecer
-distinto dependiendo de tu sistema operativo y administrador de ventanas.
+\textbf{Nota:} La decoración de su ventana (barra de título, etc.) puede aparecer
+distinta dependiendo del sistema operativo y administrador de ventanas.
La Interfaz Gráfica de Usuario (GUI) de QGIS está dividida en seis áreas:
\begin{tabbing}
-1. Barra de Menús \hspace{3cm}\= 4. Vista de Mapa \\
-2. Barra de Herramientas \hspace{3cm}\> 5. Vista General \\
-3. Leyenda del Mapa \hspace{3cm}\> 6. Barra de Estado
+1. Barra de menús \hspace{3cm}\= 4. Vista del mapa \\
+2. Barra de herramientas \hspace{3cm}\> 5. Vista general del mapa \\
+3. Leyenda del mapa \hspace{3cm}\> 6. Barra de estado
\end{tabbing}
Estos seis componentes de la interfaz de QGIS están descritos con más detalle
en las siguientes secciones.
-\subsubsection{Barra de Menús}\label{label_menubar}
+\subsubsection{Barra de menús}\label{label_menubar}
\index{menus}
La barra de menús proporciona acceso a varias características de QGIS utilizando
Modified: docs/branches/0.9.1/spanish/user_guide/literature.tex
--- docs/branches/0.9.1/spanish/user_guide/literature.tex 2008-04-19 18:21:42 UTC (rev 8376)
+++ docs/branches/0.9.1/spanish/user_guide/literature.tex 2008-04-22 21:50:42 UTC (rev 8377)
@@ -1,17 +1,17 @@
\thispagestyle{empty}
-\addcontentsline{toc}{section}{Cited literature}
+\addcontentsline{toc}{section}{Literatura citada}
\begin{btSect}[plain]{cited_lit}
-\section*{Literature}
+\section*{Literatura}
\setlength{\bibhang}{2em}
\btPrintCited
\end{btSect}
\nocite{*}
\begin{btSect}[plain]{cited_weblinks}
-\section*{Web-References}
+\section*{Referencias web}
\btPrintCited
\end{btSect}
