[QGIS Commit] r8956 - in docs/trunk/english_us/user_guide: . operation_system_icons plugins_decorations_images plugins_delimited_text_images plugins_georeferencer_images plugins_gps_images plugins_grass_module_images plugins_graticule_creator_images plugins_quick_print_images plugins_spit_images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Aug 1 06:33:01 EDT 2008
Author: dassau
Date: 2008-08-01 06:33:01 -0400 (Fri, 01 Aug 2008)
New Revision: 8956
Added:
   docs/trunk/english_us/user_guide/operation_system_icons/
   docs/trunk/english_us/user_guide/operation_system_icons/Makefile
   docs/trunk/english_us/user_guide/operation_system_icons/nix.png
   docs/trunk/english_us/user_guide/operation_system_icons/osx.png
   docs/trunk/english_us/user_guide/operation_system_icons/win.png
   docs/trunk/english_us/user_guide/plugins_decorations_images/copyright_label.png
   docs/trunk/english_us/user_guide/plugins_decorations_images/north_arrow.png
   docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar.png
   docs/trunk/english_us/user_guide/plugins_delimited_text_images/delimited_text.png
   docs/trunk/english_us/user_guide/plugins_georeferencer_images/georef.png
   docs/trunk/english_us/user_guide/plugins_georeferencer_images/georeferencer.png
   docs/trunk/english_us/user_guide/plugins_gps_images/gps_importer.png
   docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_clear_input.png
   docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_shell.png
   docs/trunk/english_us/user_guide/plugins_graticule_creator_images/grid_maker.png
   docs/trunk/english_us/user_guide/plugins_quick_print_images/quick_print.png
   docs/trunk/english_us/user_guide/plugins_spit_images/spit.png
Removed:
   docs/trunk/english_us/user_guide/plugins_decorations_images/copyrighticon.png
   docs/trunk/english_us/user_guide/plugins_decorations_images/northarrowicon.png
   docs/trunk/english_us/user_guide/plugins_decorations_images/scalebaricon.png
   docs/trunk/english_us/user_guide/plugins_delimited_text_images/icon.png
   docs/trunk/english_us/user_guide/plugins_georeferencer_images/icon.png
   docs/trunk/english_us/user_guide/plugins_gps_images/icon.png
   docs/trunk/english_us/user_guide/plugins_grass_module_images/add_raster.png
   docs/trunk/english_us/user_guide/plugins_grass_module_images/add_vector.png
   docs/trunk/english_us/user_guide/plugins_grass_module_images/clearInput.png
   docs/trunk/english_us/user_guide/plugins_graticule_creator_images/graticule.png
   docs/trunk/english_us/user_guide/plugins_quick_print_images/quickprint.png
   docs/trunk/english_us/user_guide/plugins_spit_images/spiticon.png
   docs/trunk/english_us/user_guide/Makefile
   docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_add_raster.png
   docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_add_vector.png
   docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_new_centroid.png
tested to update current qgis icons from source and fixed some problems
Modified: docs/trunk/english_us/user_guide/Makefile
--- docs/trunk/english_us/user_guide/Makefile	2008-08-01 09:10:46 UTC (rev 8955)
+++ docs/trunk/english_us/user_guide/Makefile	2008-08-01 10:33:01 UTC (rev 8956)
@@ -91,7 +91,8 @@
 #	(cd ./creating_applications_screenies && make)
 #	(cd ./help_and_support_screenies && make)
 #	(cd ./plugins_screenies && make)
+	(cd ./operation_system_icons && make)
 # make html
 # requires: latex2html oder tex4ht
 # http://www.cse.ohio-state.edu/~gurari/TeX4ht/mn.html
@@ -148,7 +149,7 @@
 #	(cd ./plugins_geoprocessing_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/*.png .)
 	(cd ./plugins_georeferencer_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/georeferencer/*.png .)
 	(cd ./plugins_gps_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/gps_importer/*.png .)
-	(cd ./plugins_grass_module_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/grass/themes/default/*.png .)
+	(cd ./plugins_grass_module_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/grass/themes/default/*.png $(QGISPLUGINSOURCE)/grass/modules/*.png .)
 	(cd ./plugins_graticule_creator_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/grid_maker/*.png .)
 #	(cd ./plugins_installer_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/*.png .)
 #	(cd ./plugins_mapserver_export_images && rm -f *.png *.eps && cp $(QGISPLUGINSOURCE)/*.png .)
Added: docs/trunk/english_us/user_guide/operation_system_icons/Makefile
--- docs/trunk/english_us/user_guide/operation_system_icons/Makefile	                        (rev 0)
+++ docs/trunk/english_us/user_guide/operation_system_icons/Makefile	2008-08-01 10:33:01 UTC (rev 8956)
@@ -0,0 +1,43 @@
+# makefile to convert figures into eps format for the book
+# Comments from Michel Wurtz:
+# You will notice that the list given is the list of targets.  "all" just
+# refer to this list.  The most important rule is the next rule, that give
+# the generic rule for transforming a .fig into a .eps file.  Note the use
+# of % (define the couple target:source) and the use of
+# $< (source postfix, here .fig) and $@ (target postfix, here .eps)
+# with .eps extension:
+#JPG=qgis_icon_new_verylarge.eps\
+#	nextfile.eps
+PNG=\
+	nix.eps\
+	win.eps\
+	osx.eps\
+##### TARGETS #####
+all: $(PNG) $(JPG)
+	if [ ! -d ../finalpix/ ]; then mkdir ../finalpix; fi
+	#don't use move (mv):
+	cp *.eps ../finalpix/
+#$(EPS):	%.eps: %.fig
+#	fig2dev -L eps $< > $@
+#$(FIGPNG): %.png: %.fig
+#	fig2dev -L png -m 2 $< > $@
+$(PNG): %.eps: %.png
+	# Workaround for PDF
+	#convert -geometry 300x -depth 1 $< $@
+	convert $< $@
+$(JPG): %.eps: %.jpg
+	convert $< $@
+clean:
+	rm -f *.bak *~ *.pdf $(PNG) $(JPG)
Added: docs/trunk/english_us/user_guide/operation_system_icons/nix.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/operation_system_icons/nix.png
___________________________________________________________________
   + application/octet-stream
Added: docs/trunk/english_us/user_guide/operation_system_icons/osx.png
Property changes on: docs/trunk/english_us/user_guide/operation_system_icons/osx.png
Added: docs/trunk/english_us/user_guide/operation_system_icons/win.png
Property changes on: docs/trunk/english_us/user_guide/operation_system_icons/win.png
Added: docs/trunk/english_us/user_guide/plugins_decorations_images/copyright_label.png
Property changes on: docs/trunk/english_us/user_guide/plugins_decorations_images/copyright_label.png
Deleted: docs/trunk/english_us/user_guide/plugins_decorations_images/copyrighticon.png
Added: docs/trunk/english_us/user_guide/plugins_decorations_images/north_arrow.png
Property changes on: docs/trunk/english_us/user_guide/plugins_decorations_images/north_arrow.png
Deleted: docs/trunk/english_us/user_guide/plugins_decorations_images/northarrowicon.png
Added: docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar.png
Property changes on: docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar.png
Deleted: docs/trunk/english_us/user_guide/plugins_decorations_images/scalebaricon.png
Added: docs/trunk/english_us/user_guide/plugins_delimited_text_images/delimited_text.png
Property changes on: docs/trunk/english_us/user_guide/plugins_delimited_text_images/delimited_text.png
Deleted: docs/trunk/english_us/user_guide/plugins_delimited_text_images/icon.png
Added: docs/trunk/english_us/user_guide/plugins_georeferencer_images/georef.png
Property changes on: docs/trunk/english_us/user_guide/plugins_georeferencer_images/georef.png
Added: docs/trunk/english_us/user_guide/plugins_georeferencer_images/georeferencer.png
Property changes on: docs/trunk/english_us/user_guide/plugins_georeferencer_images/georeferencer.png
Deleted: docs/trunk/english_us/user_guide/plugins_georeferencer_images/icon.png
Added: docs/trunk/english_us/user_guide/plugins_gps_images/gps_importer.png
Property changes on: docs/trunk/english_us/user_guide/plugins_gps_images/gps_importer.png
Deleted: docs/trunk/english_us/user_guide/plugins_gps_images/icon.png
Deleted: docs/trunk/english_us/user_guide/plugins_grass_module_images/add_raster.png
Deleted: docs/trunk/english_us/user_guide/plugins_grass_module_images/add_vector.png
Deleted: docs/trunk/english_us/user_guide/plugins_grass_module_images/clearInput.png
Modified: docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_add_raster.png
Modified: docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_add_vector.png
Added: docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_clear_input.png
Property changes on: docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_clear_input.png
Modified: docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_new_centroid.png
Added: docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_shell.png
Property changes on: docs/trunk/english_us/user_guide/plugins_grass_module_images/grass_shell.png
Deleted: docs/trunk/english_us/user_guide/plugins_graticule_creator_images/graticule.png
Added: docs/trunk/english_us/user_guide/plugins_graticule_creator_images/grid_maker.png
Property changes on: docs/trunk/english_us/user_guide/plugins_graticule_creator_images/grid_maker.png
Added: docs/trunk/english_us/user_guide/plugins_quick_print_images/quick_print.png
Property changes on: docs/trunk/english_us/user_guide/plugins_quick_print_images/quick_print.png
Deleted: docs/trunk/english_us/user_guide/plugins_quick_print_images/quickprint.png
Added: docs/trunk/english_us/user_guide/plugins_spit_images/spit.png
Property changes on: docs/trunk/english_us/user_guide/plugins_spit_images/spit.png
Deleted: docs/trunk/english_us/user_guide/plugins_spit_images/spiticon.png
More information about the QGIS-commit mailing list
