[QGIS Commit] r9029 - trunk/qgis/src/gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Aug 7 20:07:58 EDT 2008
Author: timlinux
Date: 2008-08-07 20:07:58 -0400 (Thu, 07 Aug 2008)
New Revision: 9029
   trunk/qgis/src/gui/qgsprojectionselector.cpp
Fixed issues with projected crs list not being properly filed under the appropriate node and not being grouped. Also expand the proj node by default.
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp	2008-08-07 23:32:14 UTC (rev 9028)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp	2008-08-08 00:07:58 UTC (rev 9029)
@@ -643,7 +643,7 @@
     while(sqlite3_step(ppStmt) == SQLITE_ROW)
       // check to see if the srs is geographic
-      int isGeo = sqlite3_column_int(ppStmt, 2);
+      int isGeo = sqlite3_column_int(ppStmt, 3);
       if(isGeo)
         // this is a geographic coordinate system
@@ -659,16 +659,11 @@
       else
         // This is a projected srs
-        if (previousSrsTypeNode == NULL)
-          previousSrsTypeNode = mProjList;
         QTreeWidgetItem *node;
-        QString srsType = QString::fromUtf8((char*)sqlite3_column_text(ppStmt, 3));
+        QString srsType = QString::fromUtf8((char*)sqlite3_column_text(ppStmt, 4));
         // Find the node for this type and add the projection to it
         // If the node doesn't exist, create it
-        if (srsType == previousSrsType)
+        if (srsType == previousSrsType )
           node = previousSrsTypeNode;
@@ -701,6 +696,7 @@
         newItem->setText(QGIS_SRS_ID_COLUMN,QString::fromUtf8((char *)sqlite3_column_text(ppStmt, 1)));
+    mProjList->setExpanded(true);
   // close the sqlite3 statement
   sqlite3_finalize(ppStmt);
More information about the QGIS-commit mailing list
