[QGIS Commit] r9031 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Aug 8 04:42:16 EDT 2008
Author: gjm
Date: 2008-08-08 04:42:16 -0400 (Fri, 08 Aug 2008)
New Revision: 9031
   trunk/qgis/src/app/qgsidentifyresults.cpp
   trunk/qgis/src/app/qgsidentifyresults.h
   trunk/qgis/src/app/qgsmaptoolidentify.cpp
Actions now provide access to the coordinates for points and the
start/end points for linestrings. Also includes some
raionalisation of, and subtle bug fies for, the action code.
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp	2008-08-08 07:01:02 UTC (rev 9030)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp	2008-08-08 08:42:16 UTC (rev 9031)
@@ -54,6 +54,9 @@
   connect( lstResults, SIGNAL(currentItemChanged(QTreeWidgetItem*, QTreeWidgetItem*)),
            this, SLOT(handleCurrentItemChanged(QTreeWidgetItem*, QTreeWidgetItem*)));
+  // The label to use for the Derived node in the identify results
+  mDerivedLabel = tr("(Derived)");
 QgsIdentifyResults::~QgsIdentifyResults()
@@ -121,31 +124,8 @@
   // Save the attribute values as these are needed for substituting into
   // the action.
-  // A little bit complicated because the user could of right-clicked
-  // on a parent or a child in the dialog box. We also want to keep
-  // track of which row in the identify results table was actually
-  // clicked on. This is stored as an index into the mValues vector.
+  extractAllItemData(item);
-  QTreeWidgetItem* parent = item->parent();
-  if (parent == 0)
-    parent = item;
-  mValues.clear();
-  for (int j = 0; j < parent->childCount(); ++j)
-    if ( parent->child(j)->text(0) != "action" ) {
-      mValues.push_back(std::make_pair(parent->child(j)->text(0),
-                                       parent->child(j)->text(1)));
-      // Need to do the comparison on the text strings rather than the
-      // pointers because if the user clicked on the parent, we need
-      // to pick up which child that actually is (the parent in the
-      // identify results dialog box is just one of the children
-      // that has been chosen by some method).
-      if (parent->child(j)->text(0) == item->text(0))
-        mClickedOnValue = j;
   if (mActions.size() > 0)
     mActionPopup->popup(event->globalPos());
@@ -194,7 +174,7 @@
   else
     // Create new derived-attribute root node
-    daRootNode = new QTreeWidgetItem(fnode, QStringList(tr("(Derived)")));
+    daRootNode = new QTreeWidgetItem(fnode, QStringList(mDerivedLabel));
     QFont font = daRootNode->font(0);
     font.setItalic(true);
     daRootNode->setFont(0, font);
@@ -277,22 +257,8 @@
   int id = item->text(3).toInt();
-  if (parent == 0)
-    parent = item;
-  mValues.clear();
   mActions.doAction(id, mValues, mClickedOnValue);
 void QgsIdentifyResults::on_buttonHelp_clicked()
@@ -337,3 +303,53 @@
   mCurrentFeatureId = fid2;
   emit selectedFeatureChanged(mCurrentFeatureId);
+void QgsIdentifyResults::extractAllItemData(QTreeWidgetItem* item)
+  // Extracts the name/value pairs from the given item. This includes data
+  // under the (Derived) item.
+  // A little bit complicated because the user could of right-clicked
+  // on any item in the dialog box. We want a toplevel item, so walk upwards
+  // as far as possible.
+  // We also want to keep track of which row in the identify results table was
+  // actually clicked on. This is stored as an index into the mValues vector.
+  QTreeWidgetItem* child = item;
+  QTreeWidgetItem* parent = child->parent();
+  while (parent != 0)
+    child = parent;
+    parent = parent->parent();
+  parent = child;
+  mValues.clear();
+  // For the code below we
+  // need to do the comparison on the text strings rather than the
+  // pointers because if the user clicked on the parent, we need
+  // to pick up which child that actually is (the parent in the
+  // identify results dialog box is just one of the children
+  // that has been chosen by some method).
+  for (int j = 0; j < parent->childCount(); ++j)
+    if ( parent->child(j)->text(0) != "action" ) {
+      // For derived attributes, build up a virtual name
+      if (parent->child(j)->text(0) == mDerivedLabel ) {
+	for (int k = 0; k < parent->child(j)->childCount(); ++k)
+	  mValues.push_back(
+	    std::make_pair(mDerivedLabel + "."
+			   + parent->child(j)->child(k)->text(0),
+			   parent->child(j)->child(k)->text(1)));
+      else // do the actual feature attributes
+	mValues.push_back(std::make_pair(parent->child(j)->text(0),
+					 parent->child(j)->text(1)));
+    if (parent->child(j)->text(0) == item->text(0))
+      mClickedOnValue = j;
Modified: trunk/qgis/src/app/qgsidentifyresults.h
--- trunk/qgis/src/app/qgsidentifyresults.h	2008-08-08 07:01:02 UTC (rev 9030)
+++ trunk/qgis/src/app/qgsidentifyresults.h	2008-08-08 08:42:16 UTC (rev 9031)
@@ -116,6 +116,7 @@
   std::vector<std::pair<QString, QString> > mValues;
   static const int context_id = 689216579;
   int mCurrentFeatureId;
+  QString mDerivedLabel;
    Keeps track of what derived-attribute (e.g. Length, Area)
@@ -125,6 +126,10 @@
    Second item: Derived-attribute root node for that feature
   std::map<QTreeWidgetItem *, QTreeWidgetItem *> mDerivedAttributeRootNodes;
+  // Convenience function to populate mValues with all of the item names and
+  // values for a item, including the derived ones.
+  void extractAllItemData(QTreeWidgetItem* item);
 #endif
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp	2008-08-08 07:01:02 UTC (rev 9030)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp	2008-08-08 08:42:16 UTC (rev 9031)
@@ -314,6 +314,15 @@
       double dist = calc.measure(f_it->geometry());
       QString str = calc.textUnit(dist, 3, mCanvas->mapUnits(), false);
       mResults->addDerivedAttribute(featureNode, QObject::tr("Length"), str);
+      // Add the start and end points in as derived attributes
+      str.setNum(f_it->geometry()->asPolyline().first().x(), 'g', 10);
+      mResults->addDerivedAttribute(featureNode, "startX", str);
+      str.setNum(f_it->geometry()->asPolyline().first().y(), 'g', 10);
+      mResults->addDerivedAttribute(featureNode, "startY", str);
+      str.setNum(f_it->geometry()->asPolyline().last().x(), 'g', 10);
+      mResults->addDerivedAttribute(featureNode, "endX", str);
+      str.setNum(f_it->geometry()->asPolyline().last().y(), 'g', 10);
+      mResults->addDerivedAttribute(featureNode, "endY", str);
     else if (layer->vectorType() == QGis::Polygon)
@@ -321,6 +330,15 @@
       QString str = calc.textUnit(area, 3, mCanvas->mapUnits(), true);
       mResults->addDerivedAttribute(featureNode, QObject::tr("Area"), str);
+    else if (layer->vectorType() == QGis::Point)
+      // Include the x and y coordinates of the point as a derived attribute
+      QString str;
+      str.setNum(f_it->geometry()->asPoint().x(), 'g', 10);
+      mResults->addDerivedAttribute(featureNode, "X", str);
+      str.setNum(f_it->geometry()->asPoint().y(), 'g', 10);
+      mResults->addDerivedAttribute(featureNode, "Y", str);
     // Add actions
     QgsAttributeAction::aIter iter = actions.begin();
More information about the QGIS-commit mailing list
