[QGIS Commit] r9051 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Aug 12 13:53:40 EDT 2008
Author: ersts
Date: 2008-08-12 13:53:39 -0400 (Tue, 12 Aug 2008)
New Revision: 9051
   trunk/qgis/src/plugins/georeferencer/plugingui.cpp
   trunk/qgis/src/plugins/georeferencer/pluginguibase.ui
   trunk/qgis/src/plugins/georeferencer/qgsgeorefwarpoptionsdialog.cpp
   trunk/qgis/src/plugins/georeferencer/qgsimagewarper.cpp
   trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp
-Fixed color error when creating new file, closes ticket #1034
-Updated the auto arrange
-Fixed an issue that caused qgis to segfault
Modified: trunk/qgis/src/plugins/georeferencer/plugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/plugingui.cpp	2008-08-12 15:42:24 UTC (rev 9050)
+++ trunk/qgis/src/plugins/georeferencer/plugingui.cpp	2008-08-12 17:53:39 UTC (rev 9051)
@@ -165,85 +165,45 @@
 	  return;
-      int width, height; //width and height of screen
+      int myScreenWidth, myScreenHeight; //width and height of screen
       //store initial size and position of qgis window
       mPluginWindowsArranged = true;
       origSize = mainWindow->size();
       origPos = mainWindow->pos();
-      //qt distinguishes between geometry with and without window frame
-      int widthIncrMainWindow, heightIncrMainWindow;
-      int widthIncrPointDialog, heightIncrPointDialog;
-      int widthIncrThis, heightIncrThis;
       //read the desktop geometry
       QDesktopWidget* desktop = QApplication::desktop();
       QRect screenGeometry = desktop->availableGeometry();
-      width = screenGeometry.width();
-      height = screenGeometry.height();
+      myScreenWidth = screenGeometry.width();
+      myScreenHeight = screenGeometry.height();
-      int leftRightBorder; //border between plugin/point dialogs on the left and qgis main window on the right
-      int pluginPointDialogBorder; //border on y-axis between plugin dialog and point dialog
+      int newPluginDialogHeight = qMax(int(myScreenHeight * 0.2), minimumHeight());
+      int newPluginDialogWidth = qMax(int(myScreenWidth * 0.33), minimumWidth());
+      int newPointDialogHeight = qMax(int(myScreenHeight * 0.70), mPointDialog->minimumHeight());
+      int newPointDialogWidth = qMax(int(myScreenWidth * 0.33), mPointDialog->minimumWidth());
+      int newMainWindowHeight = qMax(int(myScreenHeight * 0.95), mainWindow->minimumHeight());
+      int newMainWindowWidth = qMax(int(myScreenWidth * 0.65), mainWindow->minimumHeight());
-      leftRightBorder = width/3;
-      pluginPointDialogBorder = height/5;
-      //consider minimum heights of plugin dialog and mPointDialog
-      int minPluginDialogHeight = minimumHeight() + (frameSize().height() - this->height());
-      int minPointDialogHeight = mPointDialog->minimumHeight() +	\
-	(mPointDialog->frameSize().height() - mPointDialog->height());
-      if((height - pluginPointDialogBorder) < minPointDialogHeight)
-	  pluginPointDialogBorder = (height - minPointDialogHeight);
-      if(pluginPointDialogBorder < minPluginDialogHeight)
-	  pluginPointDialogBorder = minPluginDialogHeight;
-      //consider minimum widths of plugin/point dialogs and qgis main window
-      int minPluginDialogWidth = minimumWidth() + (frameSize().width() - this->width());
-      int minPointDialogWidth = mPointDialog->minimumWidth() +		\
-	(mPointDialog->frameSize().width() - mPointDialog->width());
-      int minMainWindowWidth = mainWindow->minimumWidth() +		\
-	(mainWindow->frameSize().width() - mainWindow->width());
-      if(leftRightBorder < minPointDialogWidth)
-	  leftRightBorder = minPointDialogWidth;
-      if(leftRightBorder < minPluginDialogWidth)
-	  leftRightBorder = minPluginDialogWidth;
-      if((width - leftRightBorder) < minMainWindowWidth)
-	  leftRightBorder = width - minMainWindowWidth;
       //place main window
-      widthIncrMainWindow = (width -leftRightBorder) - mainWindow->frameSize().width();
-      heightIncrMainWindow = height - mainWindow->frameSize().height();
       mainWindow->setEnabled(false); //avoid getting two resize events for the main canvas
-      mainWindow->resize(mainWindow->width() + widthIncrMainWindow, mainWindow->height() + heightIncrMainWindow);
-      mainWindow->move(leftRightBorder, 0);
+      mainWindow->resize(newMainWindowWidth, newMainWindowHeight);
+      //Resize again to account for frame border width -- Probably a better way to do this.
+      mainWindow->resize(newMainWindowWidth - (mainWindow->width() - newMainWindowWidth), newMainWindowHeight - (mainWindow->height() - newMainWindowHeight));
+      mainWindow->move(myScreenWidth - newMainWindowWidth, 0);
       mainWindow->setEnabled(true);
-      //place point dialog
-      widthIncrPointDialog = leftRightBorder - mPointDialog->frameSize().width();
-      heightIncrPointDialog = height - pluginPointDialogBorder - mPointDialog->frameSize().height();
-      mPointDialog->resize(mPointDialog->width() + widthIncrPointDialog, mPointDialog->height() + heightIncrPointDialog);
-      mPointDialog->move(0, pluginPointDialogBorder);
       //place this dialog
-      widthIncrThis = leftRightBorder - frameSize().width();
-      heightIncrThis = pluginPointDialogBorder - frameSize().height();
-      resize(this->width() + widthIncrThis, this->height() + heightIncrThis);
+      resize(newPluginDialogWidth, newPluginDialogHeight);
+      resize(newPluginDialogWidth - (width() - newPluginDialogWidth), newPluginDialogHeight - (height() - newPluginDialogHeight));
       move(0, 0);
+      //place point dialog
+      mPointDialog->resize(newPointDialogWidth, newPointDialogHeight);
+      mPointDialog->resize(newPointDialogWidth - (mPointDialog->width() - newPointDialogWidth), newPointDialogHeight - (mPointDialog->height() - newPointDialogHeight));
+      mPointDialog->move(0, int(myScreenHeight * 0.3));
Modified: trunk/qgis/src/plugins/georeferencer/pluginguibase.ui
--- trunk/qgis/src/plugins/georeferencer/pluginguibase.ui	2008-08-12 15:42:24 UTC (rev 9050)
+++ trunk/qgis/src/plugins/georeferencer/pluginguibase.ui	2008-08-12 17:53:39 UTC (rev 9051)
@@ -6,71 +6,63 @@
     <x>0</x>
     <y>0</y>
     <width>424</width>
-    <height>155</height>
+    <height>131</height>
    </rect>
   </property>
   <property name="windowTitle" >
    <string>Georeferencer</string>
   </property>
   <property name="windowIcon" >
-   <iconset resource="georeferencer.qrc" >:/icon.png</iconset>
+   <iconset/>
   </property>
   <layout class="QGridLayout" >
-   <property name="margin" >
-    <number>9</number>
-   </property>
-   <property name="spacing" >
-    <number>6</number>
-   </property>
-   <item row="1" column="1" colspan="2" >
-    <widget class="QPushButton" name="mArrangeWindowsButton" >
+   <item row="0" column="0" >
+    <widget class="QLabel" name="textLabel1" >
      <property name="text" >
-      <string>Arrange plugin windows</string>
+      <string>Raster file:</string>
      </property>
     </widget>
    </item>
-   <item row="0" column="2" >
-    <widget class="QPushButton" name="pbnSelectRaster" >
+   <item row="0" column="1" >
+    <widget class="QLineEdit" name="leSelectRaster" >
      <property name="sizePolicy" >
-      <sizepolicy>
-       <hsizetype>0</hsizetype>
-       <vsizetype>0</vsizetype>
+      <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
        <horstretch>0</horstretch>
        <verstretch>0</verstretch>
       </sizepolicy>
      </property>
-     <property name="text" >
-      <string>...</string>
-     </property>
     </widget>
    </item>
-   <item row="0" column="1" >
-    <widget class="QLineEdit" name="leSelectRaster" >
+   <item row="0" column="2" >
+    <widget class="QPushButton" name="pbnSelectRaster" >
-      <sizepolicy>
+      <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
       </sizepolicy>
      </property>
-    </widget>
-   </item>
-   <item row="0" column="0" >
-    <widget class="QLabel" name="textLabel1" >
-      <string>Raster file:</string>
+      <string>...</string>
      </property>
     </widget>
    </item>
-   <item row="2" column="0" colspan="3" >
+   <item row="1" column="0" colspan="3" >
     <layout class="QHBoxLayout" >
-      <number>0</number>
-     </property>
       <number>6</number>
      </property>
+     <property name="leftMargin" >
+      <number>0</number>
+     </property>
+     <property name="topMargin" >
+     </property>
+     <property name="rightMargin" >
+     </property>
+     <property name="bottomMargin" >
+     </property>
      <item>
       <widget class="QPushButton" name="pbnDescription" >
@@ -79,6 +71,13 @@
       </widget>
      </item>
      <item>
+      <widget class="QPushButton" name="mArrangeWindowsButton" >
+       <property name="text" >
+        <string>Arrange plugin windows</string>
+       </property>
+      </widget>
+     </item>
+     <item>
       <spacer>
        <property name="orientation" >
         <enum>Qt::Horizontal</enum>
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefwarpoptionsdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefwarpoptionsdialog.cpp	2008-08-12 15:42:24 UTC (rev 9050)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefwarpoptionsdialog.cpp	2008-08-12 17:53:39 UTC (rev 9051)
@@ -22,9 +22,9 @@
   setupUi(this);
   QStringList compressionMethods;
   compressionMethods << "NONE";
-  compressionMethods << "LZW (" + tr("unstable") + ")";
-  compressionMethods << "PACKBITS (" + tr("unstable") + ")";
-  compressionMethods << "DEFLATE (" + tr("unstable") + ")";
+  compressionMethods << "LZW";
+  compressionMethods << "PACKBITS";
+  compressionMethods << "DEFLATE";
   mCompressionComboBox->addItems(compressionMethods);
Modified: trunk/qgis/src/plugins/georeferencer/qgsimagewarper.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsimagewarper.cpp	2008-08-12 15:42:24 UTC (rev 9050)
+++ trunk/qgis/src/plugins/georeferencer/qgsimagewarper.cpp	2008-08-12 17:53:39 UTC (rev 9051)
@@ -85,10 +85,11 @@
     GDALRasterBandH hSrcBand = GDALGetRasterBand(hSrcDS,i+1);
     GDALRasterBandH hDstBand = GDALGetRasterBand(hDstDS,i+1);
-    GDALColorTableH cTable = GDALGetRasterColorTable(hSrcDS);
+    GDALColorTableH cTable = GDALGetRasterColorTable(hSrcBand);
+    GDALSetRasterColorInterpretation (hDstBand, GDALGetRasterColorInterpretation(hSrcBand));
     if (cTable)
-      GDALSetRasterColorTable(hDstDS,cTable);
+      GDALSetRasterColorTable(hDstBand,cTable);
     double noData = GDALGetRasterNoDataValue(hSrcBand,NULL);
Modified: trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp	2008-08-12 15:42:24 UTC (rev 9050)
+++ trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp	2008-08-12 17:53:39 UTC (rev 9051)
@@ -313,7 +313,14 @@
     QgsImageWarper::ResamplingMethod resampling;
     QgsImageWarper warper(-rotation);
     d.getWarpOptions(resampling, useZeroForTrans, compressionMethod);
-    warper.warp(mLayer->source(), outputFileName,
+    //Closing the dialog by pressing the X button rather than clicking the OK button causes GDAL to barf and QGIS
+    //to crash because reasampling is not a valid option
+    //**not sure exactly what is going on in the case as the other two options are still correct but that could be coincidence
+    if(resampling != QgsImageWarper::NearestNeighbour && resampling != QgsImageWarper::Bilinear && resampling != QgsImageWarper::Cubic)
+      return false;
+    warper.warp(mLayer->source(), outputFileName,
 		xOffset, yOffset, resampling, useZeroForTrans, compressionMethod);
More information about the QGIS-commit mailing list
