[QGIS Commit] r9064 - branches/advanced_printing_branch/src/app/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 16 07:39:44 EDT 2008
Author: mhugent
Date: 2008-08-16 07:39:43 -0400 (Sat, 16 Aug 2008)
New Revision: 9064
   branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp
   branches/advanced_printing_branch/src/app/composer/qgscomposer.h
   branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp
   branches/advanced_printing_branch/src/app/composer/qgscomposerview.h
Automatically set selection tool in composer after creating an new composer element
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp	2008-08-16 09:56:51 UTC (rev 9063)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp	2008-08-16 11:39:43 UTC (rev 9064)
@@ -113,13 +113,7 @@
   //create composer view
   mView = new QgsComposerView (mViewFrame);
-  connect(mView, SIGNAL(selectedItemChanged(const QgsComposerItem*)), this, SLOT(showItemOptions(const QgsComposerItem*)));
-  connect(mView, SIGNAL(composerLabelAdded(QgsComposerLabel*)), this, SLOT(addComposerLabel(QgsComposerLabel*)));
-  connect(mView, SIGNAL(composerMapAdded(QgsComposerMap*)), this, SLOT(addComposerMap(QgsComposerMap*)));
-  connect(mView, SIGNAL(itemRemoved(QgsComposerItem*)), this, SLOT(deleteItem(QgsComposerItem*)));
-  connect(mView, SIGNAL(composerScaleBarAdded(QgsComposerScaleBar*)), this, SLOT(addComposerScaleBar(QgsComposerScaleBar*)));
-  connect(mView, SIGNAL(composerLegendAdded(QgsComposerLegend*)), this, SLOT(addComposerLegend(QgsComposerLegend*)));
-  connect(mView, SIGNAL(composerPictureAdded(QgsComposerPicture*)), this, SLOT(addComposerPicture(QgsComposerPicture*)));
+  connectSlots();
   mComposition  = new QgsComposition(mQgis->getMapCanvas());
   mView->setComposition(mComposition);
@@ -188,6 +182,18 @@
   mActionSelectMoveItem->setIcon(QIcon(QPixmap(myThemePath + "/mActionPan.png")));
+void QgsComposer::connectSlots()
+  connect(mView, SIGNAL(selectedItemChanged(const QgsComposerItem*)), this, SLOT(showItemOptions(const QgsComposerItem*)));
+  connect(mView, SIGNAL(composerLabelAdded(QgsComposerLabel*)), this, SLOT(addComposerLabel(QgsComposerLabel*)));
+  connect(mView, SIGNAL(composerMapAdded(QgsComposerMap*)), this, SLOT(addComposerMap(QgsComposerMap*)));
+  connect(mView, SIGNAL(itemRemoved(QgsComposerItem*)), this, SLOT(deleteItem(QgsComposerItem*)));
+  connect(mView, SIGNAL(composerScaleBarAdded(QgsComposerScaleBar*)), this, SLOT(addComposerScaleBar(QgsComposerScaleBar*)));
+  connect(mView, SIGNAL(composerLegendAdded(QgsComposerLegend*)), this, SLOT(addComposerLegend(QgsComposerLegend*)));
+  connect(mView, SIGNAL(composerPictureAdded(QgsComposerPicture*)), this, SLOT(addComposerPicture(QgsComposerPicture*)));
+  connect(mView, SIGNAL(actionFinished()), this, SLOT(setSelectionTool()));
 void QgsComposer::open ( void )
   if ( mFirstTime ) {
@@ -1204,13 +1210,8 @@
   //todo: move in function because duplicated code with constructor
   mView = new QgsComposerView(mViewFrame);
+  connectSlots();
   mComposition->readXML(compositionElem, doc);
@@ -1362,4 +1363,5 @@
 void QgsComposer::setSelectionTool()
   mActionSelectMoveItem->setChecked(true);
+  on_mActionSelectMoveItem_activated();
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposer.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposer.h	2008-08-16 09:56:51 UTC (rev 9063)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposer.h	2008-08-16 11:39:43 UTC (rev 9064)
@@ -197,6 +197,8 @@
 private:
     //! Set teh pixmap / icons on the toolbar buttons
     void setupTheme();
+    /**Etablishes the signal slot connection for the class*/
+    void connectSlots();
 #if 0
     /** \brief move up the content of the file
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp	2008-08-16 09:56:51 UTC (rev 9063)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposerview.cpp	2008-08-16 11:39:43 UTC (rev 9064)
@@ -104,6 +104,7 @@
       newLabelItem->setZValue(60);
       newLabelItem->setSelected(true);
       emit selectedItemChanged(newLabelItem);
+      emit actionFinished();
     break;
@@ -126,6 +127,7 @@
       newScaleBar->setZValue(60);
       newScaleBar->setSelected(true);
       emit selectedItemChanged(newScaleBar);
     break;
@@ -139,6 +141,7 @@
       newLegend->setSceneRect(QRectF(scenePoint.x(), scenePoint.y(), newLegend->rect().width(), newLegend->rect().height()));
       newLegend->setSelected(true);
       emit selectedItemChanged(newLegend);
       break;
   case AddPicture:
@@ -151,6 +154,7 @@
       newPicture->setSceneRect(QRectF(scenePoint.x(), scenePoint.y(), 30, 30));
       newPicture->setSelected(true);
       emit selectedItemChanged(newPicture);
   default:
@@ -218,6 +222,7 @@
 	composerMap->setSelected(true);
 	emit selectedItemChanged(composerMap);
       break;
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposerview.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposerview.h	2008-08-16 09:56:51 UTC (rev 9063)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposerview.h	2008-08-16 11:39:43 UTC (rev 9064)
@@ -104,6 +104,9 @@
   void composerPictureAdded(QgsComposerPicture* picture);
   /**Is emitted when a composer item has been removed from the scene*/
   void itemRemoved(QgsComposerItem*);
+  /**Current action (e.g. adding composer map) has been finished. The purpose of this signal is that
+   QgsComposer may set the selection tool again*/
+  void actionFinished();
 #endif
More information about the QGIS-commit mailing list
