[QGIS Commit] r9071 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Aug 18 18:31:52 EDT 2008
Author: jef
Date: 2008-08-18 18:31:52 -0400 (Mon, 18 Aug 2008)
New Revision: 9071
   trunk/qgis/src/core/qgsspatialrefsys.cpp
fix #1205 and #1221
Modified: trunk/qgis/src/core/qgsspatialrefsys.cpp
--- trunk/qgis/src/core/qgsspatialrefsys.cpp	2008-08-18 13:23:07 UTC (rev 9070)
+++ trunk/qgis/src/core/qgsspatialrefsys.cpp	2008-08-18 22:31:52 UTC (rev 9071)
@@ -24,6 +24,7 @@
 #include <QDomElement>
 #include <QFileInfo>
 #include <QRegExp>
+#include <QTextStream>
 #include "qgsapplication.h"
 #include "qgslogger.h"
@@ -226,12 +227,8 @@
     mEpsg = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,6)).toLong();
     int geo = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,7)).toInt();
     mGeoFlag = (geo == 0 ? false : true);
+    setProj4String( proj4String );
     setMapUnits();
-    mIsValidFlag = true;
-    const char *oldlocale = setlocale(LC_NUMERIC, NULL);
-    setlocale(LC_NUMERIC, "C");
-    OSRImportFromProj4( mSRS, proj4String.toLatin1().constData() );
-    setlocale(LC_NUMERIC, oldlocale);
   else
@@ -278,7 +275,7 @@
   //now that we have the proj4string, delegate to createFromProj4String so
   // that we can try to fill in the remaining class members...
-  //create from Proj wil set the isValidFalg
+  //create from Proj will set the isValidFlag
   createFromProj4(QString(proj4src));
   CPLFree(proj4src);
@@ -288,11 +285,7 @@
 bool QgsSpatialRefSys::isValid() const
-  if (mIsValidFlag)
-    return true;
-  return false;
+  return mIsValidFlag;
 bool QgsSpatialRefSys::createFromProj4 (const QString theProj4String)
@@ -410,10 +403,7 @@
       if (!myRecord.empty())
         // Success!  We have found the proj string by swapping the lat_1 and lat_2
-        OSRImportFromProj4(mSRS, theProj4StringModified.toLatin1().constData() );
+        setProj4String( theProj4StringModified );
         mySrsId=myRecord["srs_id"].toLong();
         QgsDebugMsg("QgsSpatialRefSys::createFromProj4 proj4string match search for srsid returned srsid: " + QString::number(mySrsId));
         if (mySrsId > 0)
@@ -664,8 +654,12 @@
 void QgsSpatialRefSys::setProj4String (QString theProj4String)
+  OSRDestroySpatialReference( mSRS );
+  mSRS = OSRNewSpatialReference(NULL);
   mIsValidFlag = OSRImportFromProj4(mSRS, theProj4String.toLatin1().constData() )==OGRERR_NONE;
 void QgsSpatialRefSys::setGeographicFlag (bool theGeoFlag)
@@ -691,7 +685,6 @@
   if (!mIsValidFlag)
-    QgsLogger::warning("No valid projection. Unable to set map units.");
     mMapUnits = QGis::UNKNOWN;
     return;
@@ -944,6 +937,7 @@
        setGeographicFlag(false);
      //make sure the map units have been set
      setMapUnits();
More information about the QGIS-commit mailing list
