[QGIS Commit] r9115 - branches/advanced_printing_branch/python/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Aug 22 01:56:12 EDT 2008
Author: timlinux
Date: 2008-08-22 01:56:11 -0400 (Fri, 22 Aug 2008)
New Revision: 9115
Added:
   branches/advanced_printing_branch/python/core/qgscoordinatereferencesystem.sip
Removed:
   branches/advanced_printing_branch/python/core/qgsspatialrefsys.sip
Renamed qgsspatialrefsys to qgscoordinatereferencesystem
Copied: branches/advanced_printing_branch/python/core/qgscoordinatereferencesystem.sip (from rev 9110, branches/advanced_printing_branch/python/core/qgsspatialrefsys.sip)
--- branches/advanced_printing_branch/python/core/qgscoordinatereferencesystem.sip	                        (rev 0)
+++ branches/advanced_printing_branch/python/core/qgscoordinatereferencesystem.sip	2008-08-22 05:56:11 UTC (rev 9115)
@@ -0,0 +1,298 @@
+ * \class QgsCoordinateReferenceSystem
+ * \brief Class for storing a spatial reference system (CRS)
+class QgsCoordinateReferenceSystem
+%TypeHeaderCode
+#include <qgscoordinatereferencesystem.h>
+%End
+    public:
+//      typedef void (*CUSTOM_CRS_VALIDATION)(QgsCoordinateReferenceSystem*);
+        enum CRS_TYPE {
+          QGIS_CRSID,
+          POSTGIS_SRID,
+          EPSG
+        //! Default constructor
+        QgsCoordinateReferenceSystem();
+        ~QgsCoordinateReferenceSystem();
+         * Constructs a CRS object from a WKT string
+         * @param theWkt A String containing a valid Wkt def
+        explicit QgsCoordinateReferenceSystem(QString theWkt);
+        /*! Use this constructor when you want to create a CRS object using
+         *  a postgis SRID, an EPSG id or a QGIS CRS_ID.
+         * @param theId The ID no valid for the chosen coordinate system id type
+         * @param theType One of the types described in QgsCoordinateReferenceSystem::CRS_TYPE
+        QgsCoordinateReferenceSystem(const long theId, CRS_TYPE theType=POSTGIS_SRID);
+        // Misc helper functions -----------------------
+        void createFromId(const long theId, CRS_TYPE theType=POSTGIS_SRID);
+         * \brief Set up this CRS from the given OGC CRS
+         * Sets this CRS to the given OGC WMS-format Coordinate Reference Systems.
+         * \note This function only deals with EPSG labels only at this time.
+         * \retval FALSE if not given an EPSG label
+        bool createFromOgcWmsCrs(QString theCrs);
+        /*! Set up this srs by fetching the appropriate information from the
+         * sqlite backend. First the system level read only srs.db will be checked
+         * and then the users ~/.qgis/qgis.db database will be checked for a match.
+         * @note Any members will be overwritten during this process.
+         * @param theSrid The postgis SRID for the desired spatial reference system.
+        bool createFromSrid(const long theSrid);
+        /*! Set up this srs using a WKT spatial ref sys definition.
+         * The wkt will be converted to a proj4 string using OGR helper
+         * functions. After this the srs databasses will be searched for matches.
+         * First the system level read only srs.db will be checked
+         * @note SRID and EPSG may be blank if no match can be found on srs db.
+         * @param theWkt The WKT for the desired spatial reference system.
+         * @return bool TRUE if sucess else false
+        bool createFromWkt(const QString theWkt);
+         * @param theEpsg The EPSG for the desired spatial reference system.
+        bool createFromEpsg(const long theEpsg);
+         * sqlite backend. If the srsid is < 100000, only the system srs.db
+         * will be checked. If the srsid > 100000 the srs will be retrieved from
+         * the ~/.qgis/qgis.db
+         * @param theSrsId The QGIS SrsId for the desired spatial reference system.
+        bool createFromSrsId (const long theSrsId);
+        /*! Set up this srs by passing it a proj4 style formatted string.
+         * The string will be parsed and the projection and ellipsoid
+         * members set and the remainder of the proj4 string will be stored
+         * in the parameters member. The reason for this is so that we
+         * can easily present the user with 'natural language' representation
+         * of the projection and ellipsoid by looking them up in the srs.bs sqlite
+         * database. Also having the ellpse and proj elements stripped out
+         * is hepful to speed up globbing queries (see below).
+         * We try to match the proj string to and srsid using the following logic:
+         * - perform a whole text search on srs name (if not null). The srs name will
+         *   have been set if this method has been delegated to from createFromWkt.
+         * - if the above does not match perform a whole text search on proj4 string (if not null)
+         * - if none of the above match convert the proj4 string to an OGR CRS
+         *   then check if its a geocs or a proj cs (using ogr isGeographic)
+         *   then sequentially walk through the database (first users qgis.db srs tbl then
+         *   system srs.db tbl), converting each entry into an ogr srs and using isSame
+         *   or isSameGeocs (essentially calling the == overloaded operator). We'll try to
+         *   be smart about this and first parse out the proj and ellpse strings and only
+         *   check for a match in entities that have the same ellps and proj entries so
+         *   that it doesnt munch yer cpu so much.
+         * @note If the srs was not matched, we will create a new entry on the users tbl_srs
+         *    for this srs.
+         * @param theProjString A proj4 format string
+        bool createFromProj4 (const QString theProjString);
+        /*! Find out whether this CRS is correctly initialised and useable */
+        bool isValid() const;
+        /*! Perform some validation on this CRS. If the sts doesnt validate the
+         *  default behaviour settings for layers with unknown CRS will be
+         * consulted and acted on accordingly. By hell or high water this
+         * method will do its best to make sure that this CRS is valid - even
+         * if that involves resorting to a hard coded default of geocs:wgs84.
+         * @note It is not usually neccessary to use this function, unless you
+         * are trying to force theis srs to be valid.
+        void validate();
+        /*! This is a globbing function to try to find a record in the database
+         *  that matches a CRS defined only by a proj4string. The goal is to
+         *  learn what the tbl_srs.srs_id value is for the CRS. Internally
+         *  the source CRS is converted to and OGR srs object using the proj4string
+         *  and then every record in the database that matches projection and ellipsoid
+         *  will be converted to an OGR srs in turn and compared to the source CRS.
+         *  There are some gotchas with using ogr isSame() srs comparison, but
+         *  its more effective than using straight string comparison of proj4params.
+         *  @note The ellipsoid and projection acronyms must be set as well as the proj4string!
+         *  @return lomg the SrsId of the matched CRS
+        long findMatchingProj();
+        /*! A string based associative array used for passing records around */
+        typedef QMap<QString, QString> RecordMap;
+        /*! Get a record from the srs.db or qgis.db backends, given an sql statment.
+         * @note only handles queries that return a single record.
+         * @note it will first try the system srs.db then the users qgis.db!
+         * @param QString The sql query to execute
+         * @return QMap An associative array of field name <-> value pairs
+         RecordMap getRecord(QString theSql);
+        /*! Overloaded == operator used to compare to CRS's.
+         *  Internally it will delegate to the equals method described below
+         bool operator==(const QgsCoordinateReferenceSystem &theSrs);
+        /*! Overloaded != operator used to compare to CRS's.
+          *  Returns opposite bool value to operator ==
+         bool operator!=(const QgsCoordinateReferenceSystem &theSrs);
+         *  Internally it will use OGR isSameCRS() or isSameGeoCRS() methods as appropriate.
+         *  Additionally logic may also be applied if the result from the OGR methods
+         *  is inconclusive.
+         bool equals(QString theProj4String);
+         /*! A helper to get an wkt representation of this srs
+          * @return string containing Wkt of the srs
+         QString toWkt() const;
+         /*! Restores state from the given Dom node.
+         * @param theNode The node from which state will be restored
+         * @return bool True on success, False on failure
+          bool readXML( QDomNode & theNode );
+        /*! Stores state to the given Dom node in the given document.
+         * Below is an example of the generated tag.
+         *  <spatialrefsys>
+         *      <proj4>+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs </proj4>
+         *       <srsid>2585</srsid>
+         *       <srid>4326</srid>
+         *       <epsg>4326</epsg>
+         *       <description>WGS 84</description>
+         *       <projectionacronym>longlat</projectionacronym>
+         *       <ellipsoidacronym>WGS84</ellipsoidacronym>
+         *   </spatialrefsys>
+         * @param theNode The node in which state will be restored
+         * @param theDom The document in which state will be stored
+          bool writeXML( QDomNode & theNode, QDomDocument & theDoc );
+         /** A static helper function to find out the proj4 string for a srsid
+           * @param int theSrsId The srsid used for the lookup
+           * @return QString The proj4 string
+         static QString getProj4FromSrsId(const int theSrsId);
+         /** Sets custom function to force valid CRS
+          *  QGIS uses implementation in QgisGui::customSrsValidation
+         // TODO: disabled for now, needs usage of %Method directive to pass the function
+         //static void setCustomSrsValidation(CUSTOM_CRS_VALIDATION f);
+        // Accessors -----------------------------------
+         /*! Get the SrsId - if possible
+         *  @return  long theSrsId The internal sqlite3 srs.db primary key for this srs
+        long srsid() const;
+        /*! Get the Postgis SRID - if possible.
+        *  @return  long theSRID The internal postgis SRID for this CRS
+        long srid() const;
+        /*! Get the Description
+         * @return  QString the Description A textual description of the srs.
+         * @note A zero length string will be returned if the description is uninitialised
+        QString description () const;
+        /*! Get the Projection Acronym
+         * @return  QString theProjectionAcronym The official proj4 acronym for the projection family
+         * @note A zero length string will be returned if the projectionAcronym is uninitialised
+        QString projectionAcronym() const;
+        /*! Get the Ellipsoid Acronym
+         * @return  QString theEllipsoidAcronym The official proj4 acronym for the ellipoid
+         * @note A zero length string will be returned if the ellipsoidAcronym is uninitialised
+        QString ellipsoidAcronym () const;
+        /** Get the Proj Proj4String. If proj and ellps keys are found in the parameters,
+         * they will be stripped out and the Projection and ellipsoid acronyms will be
+         * overridden with these.
+         * @return  QString theProj4String Proj4 format specifies that define this srs.
+         * @note A zero length string will be returned if the proj4String is uninitialised
+        QString proj4String() const;
+        /*! Get this Geographic? flag
+         * @return  bool theGeoFlag Whether this is a geographic or projected coordinate system
+        bool geographicFlag () const;
+        /*! Get the units that the projection is in
+         * @return QGis::units that gives the units for the coordinate system
+        QGis::units mapUnits() const;
+        /*! Set the postgis srid for this srs
+         * @return  long theSRID the Postgis spatial_ref_sys identifier for this srs (defaults to 0)
+        long postgisSrid () const;
+        /*! Set the EPSG identifier for this srs
+         * @return  long theEpsg the ESPG identifier for this srs (defaults to 0)
+        long epsg () const;
+        // Mutators -----------------------------------
+        /*! Set the QGIS  SrsId
+         *  @param  long theSrsId The internal sqlite3 srs.db primary key for this srs
+        void setSrsId(long theSrsId);
+         *  @param  long theSrsId The postgis spatial_ref_sys key for this srs
+        void setSrid(long theSrid);
+        /*! Set the Description
+         * @param  QString the Description A textual description of the srs.
+        void setDescription (QString theDescription);
+        /* Set the Proj Proj4String.
+         * @param  QString theProj4String Proj4 format specifies (excluding proj and ellips) that define this srs.
+        void setProj4String (QString theProj4String);
+        /*! Set this Geographic? flag
+         * @param  bool theGeoFlag Whether this is a geographic or projected coordinate system
+        void setGeographicFlag (bool theGeoFlag);
+         * @param  long theEpsg the ESPG identifier for this srs (defaults to 0)
+        void setEpsg (long theEpsg);
+        /*! Set the projection acronym
+         * @param QString the acronym (must be a valid proj4 projection acronym)
+        void setProjectionAcronym(QString theProjectionAcronym);
+        /*! Set the ellipsoid acronym
+         * @param QString the acronym (must be a valid proj4 ellipsoid acronym)
+        void setEllipsoidAcronym(QString theEllipsoidAcronym);
Deleted: branches/advanced_printing_branch/python/core/qgsspatialrefsys.sip
--- branches/advanced_printing_branch/python/core/qgsspatialrefsys.sip	2008-08-21 22:50:22 UTC (rev 9114)
+++ branches/advanced_printing_branch/python/core/qgsspatialrefsys.sip	2008-08-22 05:56:11 UTC (rev 9115)
@@ -1,298 +0,0 @@
- * \class QgsCoordinateReferenceSystem
- * \brief Class for storing a spatial reference system (CRS)
-class QgsCoordinateReferenceSystem
-%TypeHeaderCode
-#include <qgscoordinatereferencesystem.h>
-%End
-    public:
-//      typedef void (*CUSTOM_CRS_VALIDATION)(QgsCoordinateReferenceSystem*);
-        enum CRS_TYPE {
-          QGIS_CRSID,
-          POSTGIS_SRID,
-          EPSG
-        //! Default constructor
-        QgsCoordinateReferenceSystem();
-        ~QgsCoordinateReferenceSystem();
-         * Constructs a CRS object from a WKT string
-         * @param theWkt A String containing a valid Wkt def
-        explicit QgsCoordinateReferenceSystem(QString theWkt);
-        /*! Use this constructor when you want to create a CRS object using
-         *  a postgis SRID, an EPSG id or a QGIS CRS_ID.
-         * @param theId The ID no valid for the chosen coordinate system id type
-         * @param theType One of the types described in QgsCoordinateReferenceSystem::CRS_TYPE
-        QgsCoordinateReferenceSystem(const long theId, CRS_TYPE theType=POSTGIS_SRID);
-        // Misc helper functions -----------------------
-        void createFromId(const long theId, CRS_TYPE theType=POSTGIS_SRID);
-         * \brief Set up this CRS from the given OGC CRS
-         * Sets this CRS to the given OGC WMS-format Coordinate Reference Systems.
-         * \note This function only deals with EPSG labels only at this time.
-         * \retval FALSE if not given an EPSG label
-        bool createFromOgcWmsCrs(QString theCrs);
-        /*! Set up this srs by fetching the appropriate information from the
-         * sqlite backend. First the system level read only srs.db will be checked
-         * and then the users ~/.qgis/qgis.db database will be checked for a match.
-         * @note Any members will be overwritten during this process.
-         * @param theSrid The postgis SRID for the desired spatial reference system.
-        bool createFromSrid(const long theSrid);
-        /*! Set up this srs using a WKT spatial ref sys definition.
-         * The wkt will be converted to a proj4 string using OGR helper
-         * functions. After this the srs databasses will be searched for matches.
-         * First the system level read only srs.db will be checked
-         * @note SRID and EPSG may be blank if no match can be found on srs db.
-         * @param theWkt The WKT for the desired spatial reference system.
-         * @return bool TRUE if sucess else false
-        bool createFromWkt(const QString theWkt);
-         * @param theEpsg The EPSG for the desired spatial reference system.
-        bool createFromEpsg(const long theEpsg);
-         * sqlite backend. If the srsid is < 100000, only the system srs.db
-         * will be checked. If the srsid > 100000 the srs will be retrieved from
-         * the ~/.qgis/qgis.db
-         * @param theSrsId The QGIS SrsId for the desired spatial reference system.
-        bool createFromSrsId (const long theSrsId);
-        /*! Set up this srs by passing it a proj4 style formatted string.
-         * The string will be parsed and the projection and ellipsoid
-         * members set and the remainder of the proj4 string will be stored
-         * in the parameters member. The reason for this is so that we
-         * can easily present the user with 'natural language' representation
-         * of the projection and ellipsoid by looking them up in the srs.bs sqlite
-         * database. Also having the ellpse and proj elements stripped out
-         * is hepful to speed up globbing queries (see below).
-         * We try to match the proj string to and srsid using the following logic:
-         * - perform a whole text search on srs name (if not null). The srs name will
-         *   have been set if this method has been delegated to from createFromWkt.
-         * - if the above does not match perform a whole text search on proj4 string (if not null)
-         * - if none of the above match convert the proj4 string to an OGR CRS
-         *   then check if its a geocs or a proj cs (using ogr isGeographic)
-         *   then sequentially walk through the database (first users qgis.db srs tbl then
-         *   system srs.db tbl), converting each entry into an ogr srs and using isSame
-         *   or isSameGeocs (essentially calling the == overloaded operator). We'll try to
-         *   be smart about this and first parse out the proj and ellpse strings and only
-         *   check for a match in entities that have the same ellps and proj entries so
-         *   that it doesnt munch yer cpu so much.
-         * @note If the srs was not matched, we will create a new entry on the users tbl_srs
-         *    for this srs.
-         * @param theProjString A proj4 format string
-        bool createFromProj4 (const QString theProjString);
-        /*! Find out whether this CRS is correctly initialised and useable */
-        bool isValid() const;
-        /*! Perform some validation on this CRS. If the sts doesnt validate the
-         *  default behaviour settings for layers with unknown CRS will be
-         * consulted and acted on accordingly. By hell or high water this
-         * method will do its best to make sure that this CRS is valid - even
-         * if that involves resorting to a hard coded default of geocs:wgs84.
-         * @note It is not usually neccessary to use this function, unless you
-         * are trying to force theis srs to be valid.
-        void validate();
-        /*! This is a globbing function to try to find a record in the database
-         *  that matches a CRS defined only by a proj4string. The goal is to
-         *  learn what the tbl_srs.srs_id value is for the CRS. Internally
-         *  the source CRS is converted to and OGR srs object using the proj4string
-         *  and then every record in the database that matches projection and ellipsoid
-         *  will be converted to an OGR srs in turn and compared to the source CRS.
-         *  There are some gotchas with using ogr isSame() srs comparison, but
-         *  its more effective than using straight string comparison of proj4params.
-         *  @note The ellipsoid and projection acronyms must be set as well as the proj4string!
-         *  @return lomg the SrsId of the matched CRS
-        long findMatchingProj();
-        /*! A string based associative array used for passing records around */
-        typedef QMap<QString, QString> RecordMap;
-        /*! Get a record from the srs.db or qgis.db backends, given an sql statment.
-         * @note only handles queries that return a single record.
-         * @note it will first try the system srs.db then the users qgis.db!
-         * @param QString The sql query to execute
-         * @return QMap An associative array of field name <-> value pairs
-         RecordMap getRecord(QString theSql);
-        /*! Overloaded == operator used to compare to CRS's.
-         *  Internally it will delegate to the equals method described below
-         bool operator==(const QgsCoordinateReferenceSystem &theSrs);
-        /*! Overloaded != operator used to compare to CRS's.
-          *  Returns opposite bool value to operator ==
-         bool operator!=(const QgsCoordinateReferenceSystem &theSrs);
-         *  Internally it will use OGR isSameCRS() or isSameGeoCRS() methods as appropriate.
-         *  Additionally logic may also be applied if the result from the OGR methods
-         *  is inconclusive.
-         bool equals(QString theProj4String);
-         /*! A helper to get an wkt representation of this srs
-          * @return string containing Wkt of the srs
-         QString toWkt() const;
-         /*! Restores state from the given Dom node.
-         * @param theNode The node from which state will be restored
-         * @return bool True on success, False on failure
-          bool readXML( QDomNode & theNode );
-        /*! Stores state to the given Dom node in the given document.
-         * Below is an example of the generated tag.
-         *  <spatialrefsys>
-         *      <proj4>+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs </proj4>
-         *       <srsid>2585</srsid>
-         *       <srid>4326</srid>
-         *       <epsg>4326</epsg>
-         *       <description>WGS 84</description>
-         *       <projectionacronym>longlat</projectionacronym>
-         *       <ellipsoidacronym>WGS84</ellipsoidacronym>
-         *   </spatialrefsys>
-         * @param theNode The node in which state will be restored
-         * @param theDom The document in which state will be stored
-          bool writeXML( QDomNode & theNode, QDomDocument & theDoc );
-         /** A static helper function to find out the proj4 string for a srsid
-           * @param int theSrsId The srsid used for the lookup
-           * @return QString The proj4 string
-         static QString getProj4FromSrsId(const int theSrsId);
-         /** Sets custom function to force valid CRS
-          *  QGIS uses implementation in QgisGui::customSrsValidation
-         // TODO: disabled for now, needs usage of %Method directive to pass the function
-         //static void setCustomSrsValidation(CUSTOM_CRS_VALIDATION f);
-        // Accessors -----------------------------------
-         /*! Get the SrsId - if possible
-         *  @return  long theSrsId The internal sqlite3 srs.db primary key for this srs
-        long srsid() const;
-        /*! Get the Postgis SRID - if possible.
-        *  @return  long theSRID The internal postgis SRID for this CRS
-        long srid() const;
-        /*! Get the Description
-         * @return  QString the Description A textual description of the srs.
-         * @note A zero length string will be returned if the description is uninitialised
-        QString description () const;
-        /*! Get the Projection Acronym
-         * @return  QString theProjectionAcronym The official proj4 acronym for the projection family
-         * @note A zero length string will be returned if the projectionAcronym is uninitialised
-        QString projectionAcronym() const;
-        /*! Get the Ellipsoid Acronym
-         * @return  QString theEllipsoidAcronym The official proj4 acronym for the ellipoid
-         * @note A zero length string will be returned if the ellipsoidAcronym is uninitialised
-        QString ellipsoidAcronym () const;
-        /** Get the Proj Proj4String. If proj and ellps keys are found in the parameters,
-         * they will be stripped out and the Projection and ellipsoid acronyms will be
-         * overridden with these.
-         * @return  QString theProj4String Proj4 format specifies that define this srs.
-         * @note A zero length string will be returned if the proj4String is uninitialised
-        QString proj4String() const;
-        /*! Get this Geographic? flag
-         * @return  bool theGeoFlag Whether this is a geographic or projected coordinate system
-        bool geographicFlag () const;
-        /*! Get the units that the projection is in
-         * @return QGis::units that gives the units for the coordinate system
-        QGis::units mapUnits() const;
-        /*! Set the postgis srid for this srs
-         * @return  long theSRID the Postgis spatial_ref_sys identifier for this srs (defaults to 0)
-        long postgisSrid () const;
-        /*! Set the EPSG identifier for this srs
-         * @return  long theEpsg the ESPG identifier for this srs (defaults to 0)
-        long epsg () const;
-        // Mutators -----------------------------------
-        /*! Set the QGIS  SrsId
-         *  @param  long theSrsId The internal sqlite3 srs.db primary key for this srs
-        void setSrsId(long theSrsId);
-         *  @param  long theSrsId The postgis spatial_ref_sys key for this srs
-        void setSrid(long theSrid);
-        /*! Set the Description
-         * @param  QString the Description A textual description of the srs.
-        void setDescription (QString theDescription);
-        /* Set the Proj Proj4String.
-         * @param  QString theProj4String Proj4 format specifies (excluding proj and ellips) that define this srs.
-        void setProj4String (QString theProj4String);
-        /*! Set this Geographic? flag
-         * @param  bool theGeoFlag Whether this is a geographic or projected coordinate system
-        void setGeographicFlag (bool theGeoFlag);
-         * @param  long theEpsg the ESPG identifier for this srs (defaults to 0)
-        void setEpsg (long theEpsg);
-        /*! Set the projection acronym
-         * @param QString the acronym (must be a valid proj4 projection acronym)
-        void setProjectionAcronym(QString theProjectionAcronym);
-        /*! Set the ellipsoid acronym
-         * @param QString the acronym (must be a valid proj4 ellipsoid acronym)
-        void setEllipsoidAcronym(QString theEllipsoidAcronym);
More information about the QGIS-commit mailing list
