[QGIS Commit] r9126 - in trunk/qgis/src/plugins/grass: config modules
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 23 06:22:31 EDT 2008
Author: leolami
Date: 2008-08-23 06:22:31 -0400 (Sat, 23 Aug 2008)
New Revision: 9126
Added:
   trunk/qgis/src/plugins/grass/modules/r.colors.rast.1.png
   trunk/qgis/src/plugins/grass/modules/r.colors.rast.2.png
   trunk/qgis/src/plugins/grass/modules/r.colors.rast.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.droptable.1.png
   trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm
   trunk/qgis/src/plugins/grass/config/default.qgc
   trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm
   trunk/qgis/src/plugins/grass/modules/r.proj.qgm
Update r.proj, r.colors.rules and add r.colors.rast and v.db.droptable
Modified: trunk/qgis/src/plugins/grass/config/default.qgc
--- trunk/qgis/src/plugins/grass/config/default.qgc	2008-08-23 09:19:49 UTC (rev 9125)
+++ trunk/qgis/src/plugins/grass/config/default.qgc	2008-08-23 10:22:31 UTC (rev 9126)
@@ -22,10 +22,6 @@
 			<section label="Import vector">
 				<grass name="v.in.ogr"/>
 				<grass name="v.in.ogr.loc"/>
-				<grass name="v.in.ogr.all"/>
-				<grass name="v.in.ogr.all.loc"/>
-				<grass name="v.in.shape"/>
-				<grass name="v.in.shape.loc"/>
 				<grass name="v.in.dxf"/>
 				<grass name="v.in.e00"/>
 				<grass name="v.in.mapgen"/>
@@ -75,23 +71,19 @@
 	<section label="Config">
 		<section label="Region">
 			<section label="Region settings">
-				<grass name="g.region.save"/>
-				<grass name="g.region.zoom"/>
-				<grass name="g.region.multiple.raster"/>
-				<grass name="g.region.multiple.vector"/>
+				<grass name="g.region"/>
 			</section>
 			<section label="Projection management">
-				<section label="Print projection information of the current location">
+				<section label="Print projection info of current Location">
 					<grass name="g.proj.print"/>
 				</section>
-				<section label="Print projection information from a georeferenced file">
+				<section label="Print projection info from a file">
 					<grass name="g.proj.geo"/>
-					<grass name="g.proj.ascii"/>
 					<grass name="g.proj.proj"/>
 				</section>
-				<section label="Print projection information from a georeferenced file and create a new location based on it">
-					<grass name="g.proj.geo.new"/>
+				<section label="Print projection info from a file to create new location">
 					<grass name="g.proj.ascii.new"/>
+					<grass name="g.proj.geo.new"/>
 					<grass name="g.proj.proj.new"/>
 				</section>
 			</section>
@@ -109,9 +101,6 @@
 			<section label="Compress raster">
 				<grass name="r.compress"/>
 			</section>
-			<section label="Patch raster layers">
-				<grass name="r.patch"/>
-			</section>
 			<section label="Sets the boundary definitions for a raster map">
 				<grass name="r.region.region"/>
 				<grass name="r.region.raster"/>
@@ -136,12 +125,12 @@
 			</section>
 			<section label="Reproject raster from another Location">
 				<grass name="r.proj"/>
-				<grass name="r.proj.res"/>
 			</section>
 		</section>
 		<section label="Manage map colors">
 			<grass name="r.colors.table"/>
 			<grass name="r.colors.rules"/>
+			<grass name="r.colors.rast"/>
 			<grass name="r.blend"/>
 			<grass name="r.composite"/>
 			<grass name="r.his"/>
@@ -253,9 +242,6 @@
 			<section label="Topology management">
 				<grass name="v.build.all"/>
 			</section>
-			<section label="Patch vector layers">
-				<grass name="v.patch"/>
-			</section>
 			<section label="Toolset for cleaning topology of vector map">
 				<grass name="v.clean.break"/>
 				<grass name="v.clean.snap"/>
@@ -412,15 +398,16 @@
 		</section>
 		<section label="Tables management">
 			<grass name="v.db.addtable"/>
-			<grass name="v.db.addcol"/>
-			<grass name="v.db.dropcol"/>
-			<grass name="v.db.renamecol"/>
+			<grass name="v.db.droptable"/>
 		</section>
-		<section label="Queries">
+		<section label="Columns management">
+			<grass name="v.db.addcol"/>
 			<grass name="v.db.update_const"/>
 			<grass name="v.db.update_query"/>
 			<grass name="v.db.update_op"/>
 			<grass name="v.db.update_op_query"/>
+			<grass name="v.db.dropcol"/>
+			<grass name="v.db.renamecol"/>
 			<grass name="db.execute"/>
 		</section>
 		<section label="Others">
Added: trunk/qgis/src/plugins/grass/modules/r.colors.rast.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules/r.colors.rast.1.png
___________________________________________________________________
   + application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules/r.colors.rast.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules/r.colors.rast.2.png
Added: trunk/qgis/src/plugins/grass/modules/r.colors.rast.qgm
--- trunk/qgis/src/plugins/grass/modules/r.colors.rast.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/r.colors.rast.qgm	2008-08-23 10:22:31 UTC (rev 9126)
@@ -0,0 +1,7 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Set raster color table from existing raster" module="r.colors">
+	<option key="map" update="yes" />
+	<option key="raster" />
+</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm
--- trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm	2008-08-23 09:19:49 UTC (rev 9125)
+++ trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm	2008-08-23 10:22:31 UTC (rev 9126)
@@ -3,5 +3,5 @@
 <qgisgrassmodule label="Set raster color table from setted rules" module="r.colors">
-	<option key="rules" />
+	<file key="rules" type="old" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.proj.qgm
--- trunk/qgis/src/plugins/grass/modules/r.proj.qgm	2008-08-23 09:19:49 UTC (rev 9125)
+++ trunk/qgis/src/plugins/grass/modules/r.proj.qgm	2008-08-23 10:22:31 UTC (rev 9126)
@@ -2,9 +2,11 @@
 <qgisgrassmodule label="Re-project a raster map from one location to the current location" module="r.proj">
-	<file key="input" />
-	<option key="dbase" />
-	<option key="location" />
-	<option key="mapset" />
+	<option key="input" />
+	<option key="dbase"/>
+	<option key="location"/>
+	<option key="mapset"/>
 	<option key="method" />
+	<option key="resolution" />
+	<option key="output" />
 </qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules/v.db.droptable.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules/v.db.droptable.1.png
Added: trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm	2008-08-23 10:22:31 UTC (rev 9126)
@@ -0,0 +1,8 @@
+<qgisgrassmodule label="Remove existing attribute table of a vector map" module="v.db.droptable">
+	<option key="map" />
+	<option key="table" />
+	<option key="layer" answer="1" hidden="no" />
+</qgisgrassmodule>
More information about the QGIS-commit mailing list
