[QGIS Commit] r9132 - in trunk/qgis/src/plugins/dxf2shp_converter: . dxflib/src
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 23 09:54:45 EDT 2008
Author: jef
Date: 2008-08-23 09:54:45 -0400 (Sat, 23 Aug 2008)
New Revision: 9132
   trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/builder.h
   trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.h
   trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.h
   trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui
   trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/getInsertions.cpp
dxf2shp cleanup (fixes #1236)
Modified: trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/builder.cpp	2008-08-23 13:54:45 UTC (rev 9132)
@@ -1,4 +1,4 @@
-// The code is heavily based on Christopher Michaelis'  DXF to Shapefile Converter
+// The code is heavily based on Christopher Michaelis'  DXF to Shapefile Converter
 // (http://www.wanderingidea.com/content/view/12/25/), released under GPL License
 // This code is based on two other products:
@@ -7,165 +7,157 @@
 // SHAPELIB (http://shapelib.maptools.org/)
 //    Used for the Shapefile functionality.
 //    It is Copyright (c) 1999, Frank Warmerdam, released under the following "MIT Style" license:
-//Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated
-//documentation files (the "Software"), to deal in the Software without restriction, including without limitation
-//the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software,
+//Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated
+//documentation files (the "Software"), to deal in the Software without restriction, including without limitation
+//the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software,
 //and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
 //The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
-//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
-//OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
-//LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR
+//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
+//OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
+//LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR
 //IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
+#include <cmath>
 #include <string>
-#include <iostream>
-#include <fstream>
 #include "builder.h"
-#define DEBUG 1
+#include "qgslogger.h"
-Builder::Builder() {
-  currentBlockX = 0.0;
-  currentBlockY = 0.0;
-  ignoringBlock = false;
-  current_polyline_pointcount = 0;
+Builder::Builder(std::string theFname,
+                 int theShapefileType,
+		 double *theGrpXVals, double *theGrpYVals,
+		 std::string *theGrpNames,
+		 int theInsertCount,
+		 bool theConvertText) :
+  fname(theFname),
+  shapefileType(theShapefileType),
+  grpXVals(theGrpXVals),
+  grpYVals(theGrpYVals),
+  grpNames(theGrpNames),
+  insertCount(theInsertCount),
+  convertText(theConvertText),
+  fetchedprims(0),
+  fetchedtexts(0),
+  ignoringBlock(false),
+  awaiting_polyline_vertices(0),
+  current_polyline_pointcount(0),
+  currentBlockX(0.0),
+  currentBlockY(0.0)
-Builder::~Builder(){
+Builder::~Builder()
+  polyVertex.clear();
+  shpObjects.clear();
+  textObjects.clear();
-  if(polyVertex.size() != 0)
-    polyVertex.clear();
+int Builder::textObjectsSize()
+  return textObjects.size();
-  if(shpObjects.size() != 0)
-    shpObjects.clear();
-  if(textObjects.size() != 0)
-    textObjects.clear();
-  logfile.close();
+std::string Builder::outputShp()
+  return outputshp;
-void Builder::initBuilder(string outf, int stype, double* grps_XVals, double* grps_YVals, string* grps_Names, int in_insertCount, bool getTexts) {
-  shptype = stype;
-  fname = outf;
-  logfname = fname;
-  logfname = logfname.replace((logfname.length()-3),logfname.length(), "log");
-  logfile.open (logfname.c_str());
-  insertCount = in_insertCount;
-  awaiting_polyline_vertices = 0;
-  fetchedprims = 0;
-  fetchedtexts = 0;
-  grpXVals = grps_XVals;
-  grpYVals = grps_YVals;
-  grpNames = grps_Names;
-  convertText = getTexts;
-  switch (shptype) {
-    case 1:
-      shapefileType = SHPT_POINT;
-      break;
-    case 0:
-      shapefileType = SHPT_ARC;
-      break;
-    case 2:
-      shapefileType = SHPT_POLYGON;
-      break;
-    default:
-      shapefileType = SHPT_NULL;
-      break;
+std::string Builder::outputTShp()
+  return outputtshp;
 void Builder::addBlock(const DL_BlockData& data)
+  QgsDebugMsg("start block.");
-  logfile << "Block added\n";
   if (data.name.compare("ADCADD_ZZ") == 0)
-    logfile << "(Ignoring Block "<< data.name.c_str()<<")\n";
+    QgsDebugMsg( QString("Ignoring block %1").arg(data.name.c_str()) );
     ignoringBlock = true;
-  else
-    for (int i = 0; i < insertCount; i++)
+  else
+    for (int i=0; i<insertCount; i++)
-      if (strcmp(grpNames[i].c_str(), data.name.c_str()) == 0)
+      if (grpNames[i] == data.name)
         currentBlockX = grpXVals[i];
         currentBlockY = grpYVals[i];
-        logfile << "Found Coord for Block: ("<< grpXVals[i]<< "," << grpYVals[i]<<")\n";
+        QgsDebugMsg( QString("Found coord for block: (%1,%2)").arg( grpXVals[i] ).arg( grpYVals[i] ) );
 void Builder::endBlock()
   FinalizeAnyPolyline();
-  logfile << "endBlock added\n";
+  QgsDebugMsg("end block.");
-void Builder::addLayer(const DL_LayerData& data) {
-  logfile << "Layer: " << data.name.c_str() << "\n";
+void Builder::addLayer(const DL_LayerData& data)
+  QgsDebugMsg( QString("Layer: ").arg( data.name.c_str() ) );
-void Builder::addPoint(const DL_PointData& data) {
-  if(shptype != 1) {
-    logfile << " Ignoring Point \n";
+void Builder::addPoint(const DL_PointData& data)
+  if(shapefileType != SHPT_POINT)
+    QgsDebugMsg("ignoring point");
     return;
-  logfile << "(Add Point (" << data.x << "," << data.y << "," << data.z << ")\n";
+  QgsDebugMsg( QString("point (%1,%2,%3)").arg( data.x ).arg( data.y ).arg( data.z ) );
   if (ignoringBlock)
-    logfile << "ADCADD_ZZ block; ignoring. Exiting last add function.\n";
+    QgsDebugMsg("skipping point in block.");
     return;
-  double  x = data.x + currentBlockX;
-  double  y = data.y + currentBlockY;
+  double x = data.x + currentBlockX;
+  double y = data.y + currentBlockY;
   double z = data.z;
-  SHPObject	*psObject;
-  psObject = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL,
-      1, &x, &y, &z, NULL  );
+  SHPObject *psObject;
+  psObject = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL, 1, &x, &y, &z, NULL  );
-  shpObjects.push_back(psObject);
+  shpObjects.push_back(psObject);
   fetchedprims++;
 void Builder::addLine(const DL_LineData& data) {
-  //data.x1 , data.y1, data.z1
-  //data.x2 , data.y2, data.z2
+  //data.x1 , data.y1, data.z1
+  //data.x2 , data.y2, data.z2
-  if (shptype != 0)
+  if (shapefileType != SHPT_ARC)
-    logfile << "(Add Line - Ignoring [not creating polyline shapefile])\n";
+    QgsDebugMsg( "ignoring line" );
     return;
-  logfile << "(AddLine (" << data.x1 << "," << data.y1 << "," << data.z1 << " to "
-    << data.x2 << ","  << data.y2 << "," << data.z2 <<")\n";
+  QgsDebugMsg( QString("line 1,%2,%3 %4,%5,%6")
+                 .arg( data.x1 ).arg( data.y1 ).arg( data.z1 )
+                 .arg( data.x2 ).arg( data.y2 ).arg( data.z2 ) );
   if (ignoringBlock)
+    QgsDebugMsg( "skipping line in block." );
     return;
@@ -177,158 +169,158 @@
   xv[1] = data.x2 + currentBlockX;
   yv[1] = data.y2 + currentBlockY;
-  zv[1] = data.z2;
+  zv[1] = data.z2;
-      2, xv, yv, zv, NULL  );
+  psObject = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL, 2, xv, yv, zv, NULL );
   fetchedprims++;
+void Builder::addPolyline(const DL_PolylineData& data)
+  if (shapefileType!=SHPT_ARC && shapefileType!=SHPT_POLYGON)
+    QgsDebugMsg( "ignoring polyline" );
+    return;
-  void Builder::addPolyline(const DL_PolylineData& data) {
-    if (shptype != 0 && shptype != 2)
-      logfile << "(Add Polyline - Ignoring [not creating polyline shapefile or polygon shapefile])\n";
-      return;
+  QgsDebugMsg( "reading polyline - expecting vertices" );
-    logfile << "(Add Polyline) Awaiting Vertices...\n";
+  if (ignoringBlock)
+    QgsDebugMsg( "skipping polyline in block" );
+    return;
-    if (ignoringBlock)
+  // Add previously created polyline if not finalized yet
+  if (current_polyline_pointcount > 0)
+    if (current_polyline_willclose)
-      return;
-    // Add previously created polyline if not finalized yet
-    if (current_polyline_pointcount > 0)
-      if (current_polyline_willclose)
+      DL_VertexData myVertex;
-        DL_VertexData myVertex;
+      myVertex.x = closePolyX;
+      myVertex.y = closePolyY;
+      myVertex.z = closePolyZ;
-        myVertex.x = closePolyX;
-        myVertex.y = closePolyY;
-        myVertex.z = closePolyZ;
+      polyVertex.push_back(myVertex);
-        polyVertex.push_back(myVertex);
+    SHPObject *psShape;
+    int dim = polyVertex.size();
+    double *xv = new double[dim];
+    double *yv = new double[dim];
+    double *zv = new double[dim];
+    for (int i=0; i < dim; i++)
+      xv[i] = polyVertex[i].x;
+      yv[i] = polyVertex[i].y;
+      zv[i] = polyVertex[i].z;
-      SHPObject	*psShape;
-      int dim = polyVertex.size();
-      double *xv = new double[dim];
-      double *yv = new double[dim];
-      double *zv = new double[dim];
+    psShape = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL, dim, xv, yv, zv, NULL  );
-      for (int i=0; i < dim; i++)
-        xv[i] = polyVertex[i].x;
-        yv[i] = polyVertex[i].y;
-        zv[i] = polyVertex[i].z;
+    delete [] xv;
+    delete [] yv;
+    delete [] zv;
-      psShape = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL, dim, xv, yv, zv, NULL  );
+    shpObjects.push_back(psShape);
-      delete [] xv;
-      delete [] yv;
-      delete [] zv;
-      shpObjects.push_back(psShape);
+    fetchedprims++;
-      fetchedprims++;
+    QgsDebugMsg( QString("polyline prepared: %1").arg(fetchedprims - 1) );
+    current_polyline_pointcount = 0;
+  // Now that the currently-adding polyline (if any) is
+  // finalized, parse out the flag options
-      logfile <<  "Finalized adding of polyline shape " << fetchedprims - 1 << "\n";
+  if (data.flags == 1 || data.flags == 32)
+    current_polyline_willclose = true;
+    store_next_vertex_for_polyline_close = true;
+  else
+    current_polyline_willclose = false;
+    store_next_vertex_for_polyline_close = false;
-    // Now that the currently-adding polyline (if any) is
-    // finalized, parse out the flag options
-    if (data.flags == 1 || data.flags == 32)
-      current_polyline_willclose = true;
-      store_next_vertex_for_polyline_close = true;
-    else
-      current_polyline_willclose = false;
-      store_next_vertex_for_polyline_close = false;
+void Builder::addVertex(const DL_VertexData& data)
+    QgsDebugMsg( "ignoring vertex" );
+    return;
+  QgsDebugMsg( QString("vertex (%1,%2,%3)").arg( data.x ).arg( data.y ).arg( data.z ) );
-  void Builder::addVertex(const DL_VertexData& data)  {
-      logfile << "(Add Vertex - Ignoring [not creating polyline shapefile or polygon shapefile])\n";
-      return;
+    QgsDebugMsg( "skipping vertex in block" );
+    return;
-    logfile << "(Add Vertex) (" << data.x << "," << data.y << "," << data.z << ")\n";
+  myVertex.x = data.x + currentBlockX;
+  myVertex.y = data.y + currentBlockY;
+  myVertex.z = data.z;
-      return;
-    myVertex.x = data.x + currentBlockX;
-    myVertex.y = data.y + currentBlockY;
-    myVertex.z = data.z;
+  current_polyline_pointcount++;
-    current_polyline_pointcount++;
-    if (store_next_vertex_for_polyline_close)
-      closePolyX = data.x + currentBlockX;
-      closePolyY = data.y + currentBlockY;
-      closePolyZ = data.z;
+  if (store_next_vertex_for_polyline_close)
+    closePolyX = data.x + currentBlockX;
+    closePolyY = data.y + currentBlockY;
+    closePolyZ = data.z;
-void Builder::endSequence() {
-  logfile << "endSequence\n";
+void Builder::endSequence()
+  QgsDebugMsg( "endSequence" );
 void Builder::addArc(const DL_ArcData& data)
-  if (shptype != 0)
+  if (shapefileType!=SHPT_ARC)
-    logfile << "(Add Arc - Ignoring [not creating polyline shapefile])\n";
+    QgsDebugMsg( "ignoring arc" );
     return;
-  double pi = 3.1415926535897932384626433832795;
   int fromAngle = (int) data.angle1 + 1;
   int toAngle = (int) data.angle2 + 1;
-  logfile << "(Add Arc (" << data.cx << "," << data.cy << "," << data.cz << ","
-    << data.radius << "," << data.angle1 << ","  << data.angle2 << ")\n";
+  QgsDebugMsg( QString("arc (%1,%2,%3 r=%4 a1=%5 a2=%6)")
+                 .arg( data.cx ).arg( data.cy ).arg( data.cz )
+		 .arg( data.radius )
+		 .arg( data.angle1 ).arg( data.angle2 ) );
   if (ignoringBlock)
+    QgsDebugMsg( "skipping arc in block" );
     return;
@@ -337,20 +329,20 @@
   // Approximate the arc
-  register double radianMeasure;
-  register double deg2radFactor = (pi / 180);
+  double radianMeasure;
-  vector <DL_PointData> arcPoints;
+  std::vector <DL_PointData> arcPoints;
   DL_PointData myPoint;
-  for (i = fromAngle; ; i += 1, shpIndex++)
+  for (i = fromAngle; ; i++, shpIndex++)
     if (i > 360)
       i = 0;
-    if (shpIndex > 1000) break;
+    if (shpIndex > 1000)
+      break;
-    radianMeasure = i * deg2radFactor;
+    radianMeasure = i * M_PI / 180.0;
     myPoint.x = data.radius * cos(radianMeasure) + data.cx + currentBlockX;
     myPoint.y = data.radius * sin(radianMeasure) + data.cy + currentBlockY;
@@ -358,18 +350,19 @@
     arcPoints.push_back(myPoint);
-    if (i == toAngle) break;
+    if (i == toAngle)
+      break;
   // Finalize
   int dim = arcPoints.size();
     xv[i] = arcPoints[i].x;
     yv[i] = arcPoints[i].y;
@@ -394,35 +387,28 @@
 void Builder::addCircle(const DL_CircleData& data)
-    logfile << "(Add Circle - Ignoring [not creating polyline shapefile or polygon shapefile])\n";
+    QgsDebugMsg( "ignoring circle" );
     return;
-  logfile << "(Add Circle  (%6.3f, %6.3f, %6.3f) %6.3f\n", data.cx, data.cy, data.cz, data.radius;
+  QgsDebugMsg( QString("circle (%1,%2,%3 r=%4)").arg( data.cx ).arg( data.cy ).arg( data.cz ).arg( data.radius ) );
   if (ignoringBlock)
+    QgsDebugMsg( "skipping circle in block" );
     return;
-  register double i = 0;
-  register long shpIndex = 0;
-  // Approximate the circle with 360 line segments connecting points along that circle
-  double increment = ((2 * pi ) / 360);
-  vector <DL_PointData> circlePoints;
+  std::vector <DL_PointData> circlePoints;
-  for (; i <= 2 * pi; i += increment, shpIndex++)
+  // Approximate the circle with 360 line segments connecting points along that circle
+  register long shpIndex = 0;
+  for (double i=0.0; i<=2*M_PI; i+=M_PI/180.0, shpIndex++)
     myPoint.x = data.radius * cos(i) + data.cx + currentBlockX;
     myPoint.y = data.radius * sin(i) + data.cy + currentBlockY;
     myPoint.z = data.cz;
@@ -430,18 +416,17 @@
     circlePoints.push_back(myPoint);
   int dim = circlePoints.size();
     xv[i] = circlePoints[i].x;
     yv[i] = circlePoints[i].y;
     zv[i] = circlePoints[i].z;
@@ -455,28 +440,15 @@
   fetchedprims++;
   circlePoints.clear();
-void Builder::set_numlayers(int n) { numlayers = n; }
-void Builder::set_numpoints(int n) { numpoints = n; }
-void Builder::set_numlines(int n) { numlines = n; }
-void Builder::set_numplines(int n) { numplines = n; }
-int Builder::ret_numlayers() { return numlayers; }
-int Builder::ret_numpoints() { return numpoints; }
-int Builder::ret_numlines() { return numlines; }
-int Builder::ret_numplines() { return numplines; }
-int Builder::ret_textObjectsSize() { return textObjects.size(); }
-string Builder::ret_outputshp() { return outputshp; }
-string Builder::ret_outputtshp() { return outputtshp; }
-void Builder::addText(const DL_TextData& data) {
-  if(convertText) {
+void Builder::addText(const DL_TextData &data)
+  if(convertText)
     DL_TextData myText(
         data.ipx + currentBlockX, data.ipy + currentBlockY,data.ipz,
-        data.apx,data.apy,data.apz,
+        data.apx,data.apy,data.apz,
         data.height,data.xScaleFactor,data.textGenerationFlags,
         data.hJustification,data.vJustification,
         data.text,data.style,data.angle
@@ -484,15 +456,11 @@
     textObjects.push_back(myText);
-    logfile << "Text added: " <<data.text << "\n";
+    QgsDebugMsg( QString("text: %1").arg( data.text.c_str() ) );
     fetchedtexts++;
-void Builder::set_shptype(int n) { shptype = n; }
-void Builder::set_convertText(bool b) { convertText = b; }
 void Builder::FinalizeAnyPolyline()
   // Save the last polyline / polygon if one exists.
@@ -505,21 +473,20 @@
     psObject = SHPCreateObject( shapefileType, fetchedprims, 0, NULL, NULL, dim, xv, yv, zv, NULL  );
@@ -530,25 +497,27 @@
     fetchedprims++;
-    logfile << "Finalized adding of polyline shape " << fetchedprims - 1 <<"\n";
+    QgsDebugMsg( QString("Finalized adding of polyline shape %1").arg( fetchedprims - 1 ) );
-void Builder::print_shpObjects() {
+void Builder::print_shpObjects()
   int dim = shpObjects.size();
   int dimTexts = textObjects.size();
-  logfile << "Number Of Primitives: " << dim << "\n";
-  logfile << "Numper of Text Fields: " << dimTexts << "\n";
+  QgsDebugMsg( QString( "Number pf primitives: %1").arg( dim ) );
+  QgsDebugMsg( QString( "Number of text fields: %1").arg( dimTexts ) );
-  SHPHandle	hSHP;
+  SHPHandle hSHP;
-  if(strcmp(".shp",(fname.substr(fname.length()-4)).c_str()) == 0) {
+  if( fname.substr(fname.length()-4).compare(".shp")==0 )
     outputdbf = fname;
     outputdbf = outputdbf.replace((outputdbf.length()-3),outputdbf.length(), "dbf");
     outputshp = fname;
@@ -557,14 +526,9 @@
     outputtdbf = outputtdbf.replace((outputtdbf.length()-4),outputtdbf.length(), "_texts.dbf");
     outputtshp = fname;
     outputtshp = outputtshp.replace((outputtshp.length()-4),outputtshp.length(), "_texts.shp");
-    //        outputdbf = fname.replace((fname.length()-3),fname.length(), "dbf");
-    //      outputshp = fname.replace((fname.length()-3),fname.length(), "shp");
-    //    outputtdbf = fname.replace((fname.length()-4),fname.length(), "_texts.dbf");
-    //   outputtshp = fname.replace((fname.length()-4),fname.length(), "_texts.shp");
-  else {
+  else
     outputdbf = fname;
     outputdbf = outputdbf.append(".dbf");
     outputshp = fname;
@@ -573,10 +537,6 @@
     outputtdbf = outputtdbf.append(".dbf");
     outputtshp = fname;
     outputtshp = outputtdbf.append(".shp");
-    //outputdbf = fname.append(".dbf");
-    //outputshp = fname.append(".shp");
-    //outputtdbf = fname.append("_texts.dbf");
-    //outputtshp = fname.append("_texts.shp");
   DBFHandle dbffile = DBFCreate(outputdbf.c_str());
@@ -584,23 +544,26 @@
   hSHP = SHPCreate( outputshp.c_str(), shapefileType );
-  logfile << "Writing to main shp file...\n";
+  QgsDebugMsg( "Writing to main shp file..." );
-  for(int i=0; i< dim; i++) {
+  for(int i=0; i<dim; i++)
     SHPWriteObject(hSHP, -1, shpObjects[i] );
     SHPDestroyObject(shpObjects[i]);
-    DBFWriteIntegerAttribute(dbffile, i, 0, i);
+    DBFWriteIntegerAttribute(dbffile, i, 0, i);
   SHPClose(hSHP);
   DBFClose(dbffile);
-  logfile << "Done!\n";
+  QgsDebugMsg( "Done!" );
-  if((convertText) && (dimTexts > 0)) {
-    SHPHandle	thSHP;
+  if( convertText && dimTexts>0 )
+    SHPHandle thSHP;
     DBFHandle Tdbffile = DBFCreate(outputtdbf.c_str());
-    thSHP = SHPCreate( outputtshp.c_str(), SHPT_POINT );
+    thSHP = SHPCreate( outputtshp.c_str(), SHPT_POINT );
     DBFAddField( Tdbffile, "tipx", FTDouble, 20, 10 );
     DBFAddField( Tdbffile, "tipy", FTDouble, 20, 10 );
@@ -617,16 +580,15 @@
     DBFAddField( Tdbffile, "style", FTString, 50, 0 );
     DBFAddField( Tdbffile, "angle", FTDouble, 20, 10 );
-    logfile << "Writing Texts' shp File...\n";
+    QgsDebugMsg( "Writing Texts' shp File..." );
-    for(int i=0; i< dimTexts; i++) {
+    for(int i=0; i<dimTexts; i++)
       double x = textObjects[i].ipx;
       double y = textObjects[i].ipy;
       double z = textObjects[i].ipz;
-      psObject = SHPCreateObject( SHPT_POINT, i, 0, NULL, NULL,
+      psObject = SHPCreateObject( SHPT_POINT, i, 0, NULL, NULL, 1, &x, &y, &z, NULL  );
       SHPWriteObject(thSHP, -1, psObject );
@@ -655,6 +617,6 @@
     SHPClose(thSHP);
     DBFClose(Tdbffile);
-    logfile << "Done!";
Modified: trunk/qgis/src/plugins/dxf2shp_converter/builder.h
--- trunk/qgis/src/plugins/dxf2shp_converter/builder.h	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/builder.h	2008-08-23 13:54:45 UTC (rev 9132)
@@ -24,13 +24,16 @@
 #include "shapelib-1.2.10/shapefil.h"
 #include "getInsertions.h"
 #include <vector>
-#include <fstream>
-using namespace std;
 class Builder: public DL_CreationAdapter
   public:
-    Builder();
+    Builder(std::string theFname,
+                 bool theConvertText);
     ~Builder();
     void FinalizeAnyPolyline();
@@ -47,49 +50,35 @@
     virtual void endSequence();
     virtual void addText(const DL_TextData &data);
-    void set_numlayers(int n);
-    void set_numpoints(int n);
-    void set_numlines(int n);
-    void set_numplines(int n);
-    void set_shptype(int n);
-    void set_convertText(bool);
-    void initBuilder(string, int, double*, double*, string*, int, bool);
     void print_shpObjects();
-    int ret_numlabels();
-    int ret_numlayers();
-    int ret_numpoints();
-    int ret_numlines();
-    int ret_numplines();
-    int ret_shptype();
-    int ret_textObjectsSize();
-    string ret_outputshp();
-    string ret_outputtshp();
-    bool convertText;
+    int textObjectsSize();
+    std::string outputShp();
+    std::string outputTShp();
   private:
-    string outputdbf;
-    string outputshp;
-    string outputtdbf;
-    string outputtshp;
-    string logfname;
-    ofstream logfile;
+    std::string fname;
+    int shapefileType; // SHPT_POINT, ...
+    double *grpXVals;
+    double *grpYVals;
+    std::string *grpNames;
+    int insertCount;
+    bool convertText;
+    std::string outputdbf;
+    std::string outputshp;
+    std::string outputtdbf;
+    std::string outputtshp;
-    vector < DL_VertexData > polyVertex;
-    vector <SHPObject *> shpObjects; // metto qui tutti gli oggetti letti
-    vector <DL_TextData> textObjects;
+    std::vector <DL_VertexData> polyVertex;
+    std::vector <SHPObject *> shpObjects; // all read objects are stored here
+    std::vector <DL_TextData> textObjects;
     int numlayers;
     int numpoints;
     int numlines;
     int numplines;
-    int shptype; // 0 ,1 ,2
-    int shapefileType; // SHPT_POINT, ...
     int fetchedprims;
     int fetchedtexts;
@@ -102,11 +91,6 @@
     SHPObject *currently_Adding_PolyLine;
-    double *grpXVals;
-    double *grpYVals;
-    string *grpNames;
-    string fname;
-    int insertCount;
     double closePolyX, closePolyY, closePolyZ;
     double currentBlockX, currentBlockY;
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp	2008-08-23 13:54:45 UTC (rev 9132)
@@ -32,7 +32,7 @@
 #include <QAction>
 #include <QToolBar>
-static const char *const sIdent =
+static const char *const sIdent =
   "$Id: plugin.cpp 6935 2007-05-07 14:29:51Z wonder $";
 static const QString sName = QObject::tr("Dxf2Shp Converter");
 static const QString sDescription = QObject::tr(
@@ -47,7 +47,7 @@
- * Constructor for the plugin. The plugin is passed a pointer
+ * Constructor for the plugin. The plugin is passed a pointer
  * an interface object that provides access to exposed functions in QGIS.
  * @param theQGisInterface - Pointer to the QGIS interface object
@@ -60,24 +60,23 @@
- * Initialize the GUI interface for the plugin - this is only called once when the plugin is
+ * Initialize the GUI interface for the plugin - this is only called once when the plugin is
  * added to the plugin registry in the QGIS application.
 void dxf2shpConverter::initGui()
+  // Create the action for tool
+  mQActionPointer = new QAction(QIcon(":/dxf2shpconverter/dxf2shp_converter.png"), "Dxf2Shp Converter", this);
-  // Create the action for tool
-  mQActionPointer = new QAction(QIcon(":/dxf2shpconverter/dxf2shp_converter.png")
-    , "Dxf2Shp Converter", this);
   // Set the what's this text
-  mQActionPointer->setWhatsThis(tr(
-    "Converts DXF files in Shapefile format"));
+  mQActionPointer->setWhatsThis(tr("Converts DXF files in Shapefile format"));
   // Connect the action to the run
   connect(mQActionPointer, SIGNAL(activated()), this, SLOT(run()));
   // Add the icon to the toolbar
   mQGisIface->addToolBarIcon(mQActionPointer);
-  mQGisIface->addPluginMenu("&Dxf2Shp", mQActionPointer);
+  mQGisIface->addPluginMenu(tr("&Dxf2Shp"), mQActionPointer);
 //method defined in interface
@@ -87,16 +86,17 @@
 // Slot called when the menu item is activated
-// If you created more menu items / toolbar buttons in initiGui, you should
+// If you created more menu items / toolbar buttons in initiGui, you should
 // create a separate handler for each action - this single run() method will
 // not be enough
 void dxf2shpConverter::run()
   dxf2shpConverterGui *myPluginGui =
     new dxf2shpConverterGui(mQGisIface->getMainWindow(), QgisGui::ModalDialogFlags);
   myPluginGui->setAttribute(Qt::WA_DeleteOnClose);
-  connect(myPluginGui, SIGNAL(createLayer(QString)), this, SLOT(addMyLayer(QString)));
+  connect(myPluginGui, SIGNAL(createLayer(QString,QString)), this, SLOT(addMyLayer(QString,QString)));
   myPluginGui->show();
@@ -105,14 +105,14 @@
 void dxf2shpConverter::unload()
   // remove the GUI
-  mQGisIface->removePluginMenu("&Dxf2Shp", mQActionPointer);
+  mQGisIface->removePluginMenu(tr("&Dxf2Shp"), mQActionPointer);
   mQGisIface->removeToolBarIcon(mQActionPointer);
   delete mQActionPointer;
-void dxf2shpConverter::addMyLayer(QString myfname)
+void dxf2shpConverter::addMyLayer(QString myfname,QString mytitle)
-  mQGisIface->addVectorLayer(myfname, "Converted_Layer", "ogr");
+  mQGisIface->addVectorLayer(myfname, mytitle, "ogr");
@@ -126,8 +126,8 @@
- * Required extern functions needed  for every plugin
+ * Required extern functions needed for every plugin
  * These functions can be called prior to creating an instance
  * of the plugin class
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.h
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.h	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconverter.h	2008-08-23 13:54:45 UTC (rev 9132)
@@ -34,8 +34,8 @@
 class dxf2shpConverter: public QObject, public QgisPlugin
-  Q_OBJECT;
-  public:
+  Q_OBJECT
+public:
@@ -62,7 +62,7 @@
   //! show the help document
   void help();
-  void addMyLayer(QString);
+  void addMyLayer(QString,QString);
   private:
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp	2008-08-23 13:54:45 UTC (rev 9132)
@@ -26,89 +26,81 @@
 #include <QFile>
 #include <QDir>
 dxf2shpConverterGui::dxf2shpConverterGui(QWidget *parent, Qt::WFlags fl):
   QDialog(parent, fl)
   setupUi(this);
-dxf2shpConverterGui::~dxf2shpConverterGui(){}
+dxf2shpConverterGui::~dxf2shpConverterGui()
 void dxf2shpConverterGui::on_buttonBox_accepted()
-  QString inf = nomein->text();
+  QString inf = name->text();
   QString outd = dirout->text();
   if (inf.size() > 1)
+    int type = SHPT_POINT;
+    bool convtexts = convertTextCheck->checkState();
-    int type = 1;
-    bool convtexts;
+    if (polyline->isChecked())
+      type = SHPT_ARC;
-    if(convertTextCheck->checkState())
-      convtexts = true;
-    else
-      convtexts = false;
+    if (polygon->isChecked())
+      type = SHPT_POLYGON;
-    if (zero->isChecked())
-      type = 0;
+    if (point->isChecked())
+      type = SHPT_POINT;
-    if (uno->isChecked())
-      type = 2;
+    InsertRetrClass *insertRetr = new InsertRetrClass();
-    if (due->isChecked())
-      type = 1;
+    DL_Dxf *dxf_inserts = new DL_Dxf();
-    InsertRetrClass * insertRetr = new InsertRetrClass();
-    DL_Dxf * dxf_inserts = new DL_Dxf();
-    if (!dxf_inserts->in((string)(inf.toLatin1()), insertRetr)) { // if file open failed
-      cout << "Aborting: The input file could not be opened.\n";
+    if ( !dxf_inserts->in(inf.toStdString(), insertRetr) )
+      // if file open failed
+      QgsDebugMsg( "Aborting: The input file could not be opened." );
       return ;
-    Builder * parserClass = new Builder();
-    parserClass->initBuilder((string)(outd.toLatin1()), type, insertRetr->XVals, insertRetr->YVals, insertRetr->Names,
-        insertRetr->countInserts, convtexts);
+    Builder *parser= new Builder(
+                       outd.toStdString(),
+                       type,
+                       insertRetr->XVals, insertRetr->YVals,
+                       insertRetr->Names,
+                       insertRetr->countInserts,
+                       convtexts);
-    cout << "Finished getting insertions. Count: " << insertRetr->countInserts <<"\n";
+    QgsDebugMsg( QString("Finished getting insertions. Count: %1").arg( insertRetr->countInserts ) );
-    DL_Dxf * dxf_Main = new DL_Dxf();
+    DL_Dxf *dxf_Main = new DL_Dxf();
-    if (!dxf_Main->in((string)(inf.toLatin1()), parserClass)) { // if file open failed
-      return ;
+    if ( !dxf_Main->in( inf.toStdString(), parser) )
+      return;
     delete insertRetr;
     delete dxf_inserts;
     delete dxf_Main;
-    parserClass->print_shpObjects();
-    bool textsPresent;
-    if(parserClass->ret_textObjectsSize() > 0)
-      textsPresent = true;
-    else
-      textsPresent = false;
+    parser->print_shpObjects();
-    QString mystring = QString((parserClass->ret_outputshp()).c_str());
+    emit createLayer( QString((parser->outputShp()).c_str()), QString("Data layer") );
-    emit(createLayer(mystring));
-    if((convertTextCheck->checkState()) && (textsPresent)) {
-      mystring =  QString((parserClass->ret_outputtshp()).c_str());
+    if( convtexts && parser->textObjectsSize()>0 )
+      emit createLayer( QString((parser->outputTShp()).c_str()), QString("Text layer") );
-    delete parserClass;
+    delete parser;
   else
@@ -125,8 +117,8 @@
 void dxf2shpConverterGui::on_buttonBox_helpRequested()
-  QString s = "Fields description:\n"
-  "* Input DXF file: path to the DXF file to be converted\n"
+  QString s = tr("Fields description:\n"
+  "* Input DXF file: path to the DXF file to be converted\n"
   "* Output Shp file: desired filename of the ShapeFile to be created\n"
   "* Shp output file type: specifies the type of the output shapefile\n"
   "* Export text labels checkbox: if checked, an additional shp points layer will be created, "
@@ -135,7 +127,7 @@
   "---\n"
   "Developed by Paolo L. Scala, Barbara Rita Barricelli, Marco Padula\n"
   "CNR, Milan Unit (Information Technology), Construction Technologies Institute.\n"
-  "For support send a mail to scala at itc.cnr.it\n";
+  "For support send a mail to scala at itc.cnr.it\n");
   QMessageBox::information(this, "Help", s);
@@ -156,20 +148,20 @@
   QSettings settings;
-  QString s = QFileDialog::getOpenFileName(this, tr(
-        "Choose a delimited text file to open"), settings.value(
-          "/Plugin-DelimitedText/text_path", "./").toString(), "Files DXF (*.dxf)");
+  QString s = QFileDialog::getOpenFileName(this,
+                                           tr("Choose a DXF file to open"),
+                                           settings.value("/Plugin-DXF/text_path", "./").toString(),
+                                           "Files DXF (*.dxf)");
-  nomein->setText(s);
+  name->setText(s);
 void dxf2shpConverterGui::getOutputDir()
-  QSettings settings;
+  QString s = QFileDialog::getSaveFileName(this,
+                                           tr("Choose a filename to save to"),
+					   "output.shp",
+					   "Shapefile (*.shp)");
-  QString s = QFileDialog::getSaveFileName(this,
-      "Choose a filename to save under", "output.shp", "Shapefile (*.shp)");
   dirout->setText(s);
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.h
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.h	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.h	2008-08-23 13:54:45 UTC (rev 9132)
@@ -23,22 +23,27 @@
 class dxf2shpConverterGui: public QDialog, private Ui::dxf2shpConverterGui
-  Q_OBJECT public:
-    dxf2shpConverterGui(QWidget *parent = 0, Qt::WFlags fl = 0);
+  Q_OBJECT
+public:
+  dxf2shpConverterGui(QWidget *parent = 0, Qt::WFlags fl = 0);
   ~dxf2shpConverterGui();
-  private:
+private:
   static const int context_id = 0;
   void getInputFileName();
   void getOutputFileName();
   void getOutputDir();
-  private slots: void on_buttonBox_accepted();
+private slots:
+  void on_buttonBox_accepted();
   void on_buttonBox_rejected();
   void on_buttonBox_helpRequested();
   void on_btnBrowseForFile_clicked();
   void on_btnBrowseOutputDir_clicked();
-signals: void createLayer(QString);
+signals:
+  void createLayer(QString,QString);
 #endif
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui	2008-08-23 13:54:45 UTC (rev 9132)
@@ -36,7 +36,7 @@
     </widget>
    </item>
    <item row="0" column="1" colspan="2" >
-    <widget class="QLineEdit" name="nomein" />
+    <widget class="QLineEdit" name="name" />
    </item>
    <item row="0" column="3" >
     <widget class="QToolButton" name="btnBrowseForFile" >
@@ -84,7 +84,7 @@
      </property>
      <layout class="QGridLayout" >
       <item row="0" column="0" >
-       <widget class="QRadioButton" name="zero" >
+       <widget class="QRadioButton" name="polyline" >
         <property name="text" >
          <string>Polyline</string>
         </property>
@@ -94,14 +94,14 @@
        </widget>
       </item>
       <item row="0" column="1" >
-       <widget class="QRadioButton" name="uno" >
+       <widget class="QRadioButton" name="polygon" >
          <string>Polygon</string>
         </property>
        </widget>
       </item>
       <item row="0" column="2" >
-       <widget class="QRadioButton" name="due" >
+       <widget class="QRadioButton" name="point" >
          <string>Point</string>
         </property>
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp	2008-08-23 13:54:45 UTC (rev 9132)
@@ -58,7 +58,7 @@
 void DL_WriterA::dxfReal(int gc, double value) const {
     char str[256];
-    sprintf(str, "%.16lf", value);
+    sprintf(str, "%.16f", value);
 	// fix for german locale:
 	strReplace(str, ',', '.');
Modified: trunk/qgis/src/plugins/dxf2shp_converter/getInsertions.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/getInsertions.cpp	2008-08-23 13:22:02 UTC (rev 9131)
+++ trunk/qgis/src/plugins/dxf2shp_converter/getInsertions.cpp	2008-08-23 13:54:45 UTC (rev 9132)
@@ -29,9 +29,6 @@
-#include <stdio.h>
 InsertRetrClass::InsertRetrClass()
   Names = new string[MaxInserts];
@@ -69,6 +66,4 @@
     YVals[countInserts] = data.ipy;
   countInserts++;
More information about the QGIS-commit mailing list
