[QGIS Commit] r9166 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Aug 25 09:59:17 EDT 2008
Author: leolami
Date: 2008-08-25 09:59:17 -0400 (Mon, 25 Aug 2008)
New Revision: 9166
Added:
   trunk/qgis/src/plugins/grass/modules/v.outlier.1.png
   trunk/qgis/src/plugins/grass/modules/v.outlier.2.png
   trunk/qgis/src/plugins/grass/modules/v.outlier.qgm
   trunk/qgis/src/plugins/grass/modules/db.login.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm
Update v.in.ogr, v.in.ogr.loc, v.db.droptable, db.login and add v.outlier
Modified: trunk/qgis/src/plugins/grass/modules/db.login.qgm
--- trunk/qgis/src/plugins/grass/modules/db.login.qgm	2008-08-25 13:10:42 UTC (rev 9165)
+++ trunk/qgis/src/plugins/grass/modules/db.login.qgm	2008-08-25 13:59:17 UTC (rev 9166)
@@ -2,8 +2,6 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
 <qgisgrassmodule label="Set user/password for driver/database" module="db.login">
-	<option key="driver" answer="dbf" hidden="no"/>
-	<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" hidden="no"/>
 	<option key="user"/>
 	<option key="password"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm	2008-08-25 13:10:42 UTC (rev 9165)
+++ trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm	2008-08-25 13:59:17 UTC (rev 9166)
@@ -2,7 +2,6 @@
 <qgisgrassmodule label="Remove existing attribute table of a vector map" module="v.db.droptable">
-	<option key="map" />
+	<option key="map"  layeroption="layer"/>
 	<option key="table" />
-	<option key="layer" answer="1" hidden="no" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm	2008-08-25 13:10:42 UTC (rev 9165)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm	2008-08-25 13:59:17 UTC (rev 9166)
@@ -5,8 +5,7 @@
 	<flag key="o" answer="off" hidden="yes" />
 	<flag key="z" answer="off" hidden="no" />
 	<flag key="e" answer="off" hidden="no" />
-	<option key="dsn" label="Path to the OGR data source" />
-	<option key="layer" label="OGR layer name" />
+	<file key="dsn" type="old" label="OGR file" />
 	<option key="output" />
 	<option key="location" />
 	<option key="type" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm	2008-08-25 13:10:42 UTC (rev 9165)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm	2008-08-25 13:59:17 UTC (rev 9166)
@@ -5,8 +5,7 @@
 	<flag key="o" answer="on" hidden="yes" />
 	<flag key="r" answer="off" hidden="no" />
 </qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules/v.outlier.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules/v.outlier.1.png
___________________________________________________________________
   + application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules/v.outlier.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules/v.outlier.2.png
Added: trunk/qgis/src/plugins/grass/modules/v.outlier.qgm
--- trunk/qgis/src/plugins/grass/modules/v.outlier.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/v.outlier.qgm	2008-08-25 13:59:17 UTC (rev 9166)
@@ -0,0 +1,12 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Remove outliers from vector point data" module="v.outlier">
+	<option key="input" />
+	<option key="soe" ansewr="10" />
+	<option key="son" ansewr="10" />
+	<option key="lambda_i" ansewr="0.1" />
+	<option key="thres_o" ansewr="50" />
+	<option key="output" />
+	<option key="outlier" />
+</qgisgrassmodule>
\ No newline at end of file
More information about the QGIS-commit mailing list
