[QGIS Commit] r9193 - trunk/qgis/src/plugins/ogr_converter
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Aug 27 16:45:57 EDT 2008
Author: timlinux
Date: 2008-08-27 16:45:53 -0400 (Wed, 27 Aug 2008)
New Revision: 9193
   trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
Gui tidy ups:
- use buddies
- set tab order
- get rid of superfluos layouts
- remove colons from labels for sonsistency with other qgis dialogs
- adjust sizing behaviour a little
Modified: trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
--- trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui	2008-08-27 15:49:46 UTC (rev 9192)
+++ trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui	2008-08-27 20:45:53 UTC (rev 9193)
@@ -5,374 +5,314 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>521</width>
-    <height>450</height>
+    <width>491</width>
+    <height>400</height>
    </rect>
   </property>
   <property name="sizePolicy" >
-   <sizepolicy vsizetype="MinimumExpanding" hsizetype="MinimumExpanding" >
+   <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
     <horstretch>0</horstretch>
     <verstretch>0</verstretch>
    </sizepolicy>
   </property>
   <property name="minimumSize" >
    <size>
-    <width>520</width>
+    <width>400</width>
    </size>
   </property>
   <property name="windowTitle" >
    <string>OGR Layer Converter</string>
   </property>
   <property name="windowIcon" >
-   <iconset>
-    <normaloff/>
-   </iconset>
+   <iconset/>
   </property>
-  <layout class="QGridLayout" name="gridLayout" >
+  <layout class="QGridLayout" >
    <item row="0" column="0" >
     <widget class="QGroupBox" name="srcGroupBox" >
+     <property name="sizePolicy" >
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
      <property name="title" >
       <string>Source</string>
      </property>
-     <widget class="QWidget" name="" >
-      <property name="geometry" >
-       <rect>
-        <x>20</x>
-        <y>30</y>
-        <width>461</width>
-        <height>28</height>
-       </rect>
-      </property>
-      <layout class="QHBoxLayout" name="horizontalLayout" >
-       <item>
-        <widget class="QLabel" name="labelSrcFormat" >
-         <property name="minimumSize" >
-          <size>
-           <width>52</width>
-           <height>22</height>
-          </size>
-         </property>
-         <property name="text" >
-          <string>Format:</string>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QComboBox" name="comboSrcFormats" >
-          <size>
-           <width>200</width>
-           <height>0</height>
-          </size>
-         </property>
-         <property name="maxCount" >
-          <number>200</number>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <spacer name="horizontalSpacer_3" >
-         <property name="orientation" >
-          <enum>Qt::Horizontal</enum>
-         </property>
-         <property name="sizeHint" stdset="0" >
-          <size>
-           <width>40</width>
-           <height>20</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-      </layout>
-     </widget>
-       <rect>
-        <x>20</x>
-        <y>70</y>
-        <height>21</height>
-       </rect>
-      </property>
-      <layout class="QHBoxLayout" name="horizontalLayout_4" >
-       <item>
-        <widget class="QRadioButton" name="radioSrcFile" >
-          <string>File</string>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QRadioButton" name="radioSrcDirectory" >
-          <string>Directory</string>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QRadioButton" name="radioSrcProtocol" >
-          <string>Remote source</string>
-         </property>
-        </widget>
-       </item>
-      </layout>
-     </widget>
-       <rect>
-        <x>21</x>
-        <y>140</y>
-       </rect>
-      </property>
-      <layout class="QHBoxLayout" name="horizontalLayout_2" >
-       <item>
-        <widget class="QLabel" name="labelSrcLayer" >
-          <size>
-           <width>52</width>
-          </size>
-         </property>
-          <string>Layer:</string>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QComboBox" name="comboSrcLayer" >
-          <size>
-           <width>300</width>
-          </size>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <spacer name="horizontalSpacer_2" >
-         </property>
-          <size>
-           <width>88</width>
-           <height>17</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-      </layout>
-     </widget>
-       <rect>
-        <x>21</x>
-        <y>100</y>
-        <width>457</width>
-        <height>34</height>
-       </rect>
-      </property>
-      <layout class="QHBoxLayout" name="horizontalLayout_6" >
-       <item>
-        <widget class="QLabel" name="labelSrcDataset" >
-          <string>Dataset:</string>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QLineEdit" name="inputSrcDataset" >
-          <size>
-          </size>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QPushButton" name="buttonSelectSrc" >
-          <size>
-           <width>90</width>
-          </size>
-         </property>
-          <string>Browse</string>
-         </property>
-        </widget>
-       </item>
-      </layout>
-     </widget>
+      <item row="0" column="0" >
+       <widget class="QLabel" name="labelSrcFormat" >
+        <property name="minimumSize" >
+         <size>
+          <width>52</width>
+          <height>22</height>
+         </size>
+        </property>
+        <property name="text" >
+         <string>Format</string>
+        </property>
+        <property name="buddy" >
+         <cstring>comboSrcFormats</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="0" column="1" colspan="5" >
+       <widget class="QComboBox" name="comboSrcFormats" >
+         <size>
+          <width>200</width>
+          <height>25</height>
+         </size>
+        </property>
+        <property name="maxCount" >
+         <number>200</number>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="0" colspan="2" >
+       <spacer>
+        <property name="orientation" >
+         <enum>Qt::Horizontal</enum>
+        </property>
+        <property name="sizeHint" >
+         <size>
+          <width>40</width>
+          <height>20</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
+      <item row="1" column="2" >
+       <widget class="QRadioButton" name="radioSrcFile" >
+         <string>File</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="3" >
+       <widget class="QRadioButton" name="radioSrcDirectory" >
+         <string>Directory</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="4" colspan="2" >
+       <widget class="QRadioButton" name="radioSrcProtocol" >
+         <string>Remote source</string>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="0" >
+       <widget class="QLabel" name="labelSrcDataset" >
+         <string>Dataset</string>
+        </property>
+         <cstring>inputSrcDataset</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" colspan="4" >
+       <widget class="QLineEdit" name="inputSrcDataset" >
+         <size>
+         </size>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="5" >
+       <widget class="QPushButton" name="buttonSelectSrc" >
+         <string>Browse</string>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="0" >
+       <widget class="QLabel" name="labelSrcLayer" >
+         <size>
+          <width>52</width>
+         </size>
+        </property>
+         <string>Layer</string>
+        </property>
+         <cstring>comboSrcLayer</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="1" colspan="5" >
+       <widget class="QComboBox" name="comboSrcLayer" >
+         <size>
+          <width>300</width>
+         </size>
+        </property>
+       </widget>
+      </item>
+     </layout>
     </widget>
    </item>
-   <item row="2" column="0" >
-    <widget class="QDialogButtonBox" name="buttonBox" >
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
-     </property>
-    </widget>
-   </item>
    <item row="1" column="0" >
     <widget class="QGroupBox" name="dstGroupBox" >
+      </sizepolicy>
+     </property>
       <string>Target</string>
      </property>
-       <rect>
-        <x>22</x>
-        <y>33</y>
-        <width>454</width>
-       </rect>
-      </property>
-      <layout class="QHBoxLayout" name="horizontalLayout_3" >
-       <item>
-        <widget class="QLabel" name="labelDstFormat" >
-          <size>
-           <width>52</width>
-          </size>
-         </property>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QComboBox" name="comboDstFormats" >
-          <size>
-          </size>
-         </property>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <spacer name="horizontalSpacer" >
-         </property>
-          <size>
-           <width>88</width>
-          </size>
-         </property>
-        </spacer>
-       </item>
-      </layout>
-     </widget>
-       <rect>
-        <x>20</x>
-        <y>71</y>
-       </rect>
-      </property>
-      <layout class="QHBoxLayout" name="horizontalLayout_7" >
-       <item>
-        <widget class="QLabel" name="labelDstDataset" >
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QLineEdit" name="inputDstDataset" >
-          <size>
-          </size>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QPushButton" name="buttonSelectDst" >
-          <size>
-           <width>90</width>
-          </size>
-         </property>
-         </property>
-        </widget>
-       </item>
-      </layout>
-     </widget>
-       <rect>
-        <x>20</x>
-        <y>110</y>
-        <width>451</width>
-        <height>24</height>
-       </rect>
-      </property>
-      <layout class="QHBoxLayout" name="horizontalLayout_8" >
-       <item>
-        <widget class="QLabel" name="labelDstLayer" >
-          <size>
-           <width>52</width>
-          </size>
-         </property>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <widget class="QLineEdit" name="inputDstLayer" >
-          <size>
-          </size>
-         </property>
-        </widget>
-       </item>
-       <item>
-        <spacer name="horizontalSpacer_5" >
-         </property>
-          <size>
-           <width>40</width>
-          </size>
-         </property>
-        </spacer>
-       </item>
-      </layout>
-     </widget>
+       <widget class="QLabel" name="labelDstFormat" >
+         <size>
+          <width>52</width>
+         </size>
+        </property>
+        </property>
+         <cstring>comboDstFormats</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="0" column="1" colspan="2" >
+       <widget class="QComboBox" name="comboDstFormats" >
+         <size>
+         </size>
+        </property>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="0" >
+       <widget class="QLabel" name="labelDstDataset" >
+        </property>
+         <cstring>inputDstDataset</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1" >
+       <widget class="QLineEdit" name="inputDstDataset" >
+         <size>
+         </size>
+        </property>
+       </widget>
+      </item>
+       <widget class="QPushButton" name="buttonSelectDst" >
+        </property>
+       </widget>
+      </item>
+       <widget class="QLabel" name="labelDstLayer" >
+         <size>
+          <width>52</width>
+          <height>0</height>
+         </size>
+        </property>
+        </property>
+         <cstring>inputDstLayer</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" colspan="2" >
+       <widget class="QLineEdit" name="inputDstLayer" >
+         <size>
+         </size>
+        </property>
+       </widget>
+      </item>
+     </layout>
     </widget>
    </item>
+    <widget class="QDialogButtonBox" name="buttonBox" >
+     <property name="standardButtons" >
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11" />
  <tabstops>
+  <tabstop>comboSrcFormats</tabstop>
+  <tabstop>radioSrcFile</tabstop>
+  <tabstop>radioSrcDirectory</tabstop>
+  <tabstop>radioSrcProtocol</tabstop>
   <tabstop>inputSrcDataset</tabstop>
   <tabstop>buttonSelectSrc</tabstop>
+  <tabstop>comboSrcLayer</tabstop>
+  <tabstop>comboDstFormats</tabstop>
+  <tabstop>inputDstDataset</tabstop>
+  <tabstop>buttonSelectDst</tabstop>
+  <tabstop>inputDstLayer</tabstop>
+  <tabstop>buttonBox</tabstop>
  </tabstops>
  <resources/>
- <connections/>
+ <connections>
+  <connection>
+   <sender>buttonBox</sender>
+   <signal>accepted()</signal>
+   <receiver>OgrConverterGuiBase</receiver>
+   <slot>accept()</slot>
+   <hints>
+    <hint type="sourcelabel" >
+     <x>424</x>
+     <y>322</y>
+    </hint>
+    <hint type="destinationlabel" >
+     <x>481</x>
+     <y>297</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <signal>rejected()</signal>
+   <slot>reject()</slot>
+   <hints>
+     <x>365</x>
+     <y>323</y>
+    </hint>
+     <x>281</x>
+     <y>339</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
 </ui>
More information about the QGIS-commit mailing list
