[QGIS Commit] r9203 - in trunk/qgis/src: app core/raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Aug 28 11:27:55 EDT 2008
Author: ersts
Date: 2008-08-28 11:27:55 -0400 (Thu, 28 Aug 2008)
New Revision: 9203
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.h
-updated rendering methods
-single band with color map now uses the previously unused method drawPalettedSingleBandColor
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-08-28 15:25:01 UTC (rev 9202)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-08-28 15:27:55 UTC (rev 9203)
@@ -480,6 +480,16 @@
       cboxContrastEnhancementAlgorithm->setEnabled( false );
       labelContrastEnhancement->setEnabled( false );
       break;
+    case QgsRasterLayer::PALETTED_COLOR:
+      rbtnThreeBand->setEnabled( false );
+      rbtnSingleBand->setEnabled( true );
+      rbtnSingleBand->setChecked( true );
+      rbtnThreeBandMinMax->setEnabled( false );
+      rbtnThreeBandStdDev->setEnabled( false );
+      pbtnLoadMinMax->setEnabled( false );
+      cboxContrastEnhancementAlgorithm->setEnabled( false );
+      labelContrastEnhancement->setEnabled( false );
+      break;
     case QgsRasterLayer::PALETTED_SINGLE_BAND_GRAY:
       rbtnThreeBand->setEnabled( true );
@@ -575,6 +585,7 @@
   QgsDebugMsg( "colorShadingAlgorithm = " + QString::number( mRasterLayer->getColorShadingAlgorithm() ) );
   if ( mRasterLayer->getDrawingStyle() == QgsRasterLayer::SINGLE_BAND_PSEUDO_COLOR ||
+       mRasterLayer->getDrawingStyle() == QgsRasterLayer::PALETTED_COLOR ||
        mRasterLayer->getDrawingStyle() == QgsRasterLayer::PALETTED_SINGLE_BAND_PSEUDO_COLOR ||
        mRasterLayer->getDrawingStyle() == QgsRasterLayer::MULTI_BAND_SINGLE_BAND_PSEUDO_COLOR )
@@ -963,23 +974,29 @@
     else if ( mRasterLayer->getRasterLayerType() == QgsRasterLayer::PALETTE )
-      if ( cboxColorMap->currentText() != tr( "Grayscale" ) )
+      if ( cboxColorMap->currentText() == tr( "Grayscale" ) )
-        QgsDebugMsg( "Setting Raster Drawing Style to :: PALETTED_SINGLE_BAND_PSEUDO_COLOR" );
-        mRasterLayer->setDrawingStyle( QgsRasterLayer::PALETTED_SINGLE_BAND_PSEUDO_COLOR );
+        QgsDebugMsg( "Setting Raster Drawing Style to :: PALETTED_SINGLE_BAND_GRAY" );
+        QgsDebugMsg( QString( "Combo value : %1 GrayBand Mapping : %2" ).arg( cboGray->currentText() ).arg( mRasterLayer->
+                     getGrayBandName() ) );
+        mRasterLayer->setDrawingStyle( QgsRasterLayer::PALETTED_SINGLE_BAND_GRAY );
-      else
+      else if ( cboxColorMap->currentText() == tr( "Colormap" ) )
-        QgsDebugMsg( "Setting Raster Drawing Style to :: PALETTED_SINGLE_BAND_GRAY" );
-#ifdef QGISDEBUG
+        QgsDebugMsg( "Setting Raster Drawing Style to :: PALETTED_COLOR" );
-#endif
-        mRasterLayer->setDrawingStyle( QgsRasterLayer::PALETTED_SINGLE_BAND_GRAY );
+        mRasterLayer->setDrawingStyle( QgsRasterLayer::PALETTED_COLOR );
+      else
+        QgsDebugMsg( "Setting Raster Drawing Style to :: PALETTED_SINGLE_BAND_PSEUDO_COLOR" );
+        mRasterLayer->setDrawingStyle( QgsRasterLayer::PALETTED_SINGLE_BAND_PSEUDO_COLOR );
     // Mutltiband
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-28 15:25:01 UTC (rev 9202)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-28 15:27:55 UTC (rev 9203)
@@ -560,7 +560,7 @@
     mGrayBandName = getRasterBandName(1);  //sensible default
     QgsDebugMsg(mGrayBandName);
-    drawingStyle = PALETTED_SINGLE_BAND_PSEUDO_COLOR; //sensible default
+    drawingStyle = PALETTED_COLOR; //sensible default
     //Load the color table from the band
     QList<QgsColorRampShader::ColorRampItem> myColorRampList;
@@ -784,6 +784,10 @@
     drawingStyle = SINGLE_BAND_PSEUDO_COLOR;
+  else if ( theDrawingStyleQString == "PALETTED_COLOR" )//no need to tr() this its not shown in ui
   else if ( theDrawingStyleQString == "PALETTED_SINGLE_BAND_GRAY" )//no need to tr() this its not shown in ui
     drawingStyle = PALETTED_SINGLE_BAND_GRAY;
@@ -1221,6 +1225,22 @@
                                    theQgsMapToPixel, getRasterBandNumber( mGrayBandName ) );
         break;
+      // a single band with a color map
+    case PALETTED_COLOR:
+      //check the band is set!
+      if ( mGrayBandName == TRSTRING_NOT_SET )
+        break;
+      else
+        QgsDebugMsg( "PALETTED_COLOR drawing type detected..." );
+        drawPalettedSingleBandColor( theQPainter, theRasterViewPort,
+                                    theQgsMapToPixel, getRasterBandNumber(mGrayBandName ));
+        break;
       // a "Palette" layer drawn in gray scale (using only one of the color components)
     case PALETTED_SINGLE_BAND_GRAY:
@@ -1520,7 +1540,7 @@
- * This method is used to render a paletted raster layer as a colour image.
+ * This method is used to render a single band with a color map.
  * @param theQPainter - pointer to the QPainter onto which the layer should be drawn.
  * @param theRasterViewPort - pointer to the ViewPort struct containing dimensions of viewable area and subset area to be extracted from data file.
  * @param theGdalBand - pointer to the GDALRasterBand which should be rendered.
@@ -1535,6 +1555,11 @@
     return;
+  if ( NULL == mRasterShader )
+    return;
   GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
   GDALDataType myDataType = GDALGetRasterDataType( myGdalBand );
   void *myGdalScanData = readData( myGdalBand, theRasterViewPort );
@@ -1545,8 +1570,6 @@
     return;
-  QgsColorTable *myColorTable = colorTable( theBandNo );
   QImage myQImage = QImage( theRasterViewPort->drawableAreaXDim, theRasterViewPort->drawableAreaYDim, QImage::Format_ARGB32 );
   myQImage.fill( qRgba( 255, 255, 255, 0 ) ); // fill transparent
@@ -1554,17 +1577,15 @@
   int myRedValue = 0;
   int myGreenValue = 0;
   int myBlueValue = 0;
-  bool found = false;
   int myAlphaValue = 0;
   for ( int myColumn = 0; myColumn < theRasterViewPort->drawableAreaYDim; ++myColumn )
     for ( int myRow = 0; myRow < theRasterViewPort->drawableAreaXDim; ++myRow )
-      //Reinitalize values;
       myRedValue = 0;
       myGreenValue = 0;
       myBlueValue = 0;
-      found = false;
       myPixelValue = readValue( myGdalScanData, ( GDALDataType )myDataType,
                                 myColumn * theRasterViewPort->drawableAreaXDim + myRow );
@@ -1579,19 +1600,23 @@
         continue;
-      found = myColorTable->color( myPixelValue, &myRedValue, &myGreenValue, &myBlueValue );
-      if ( !found ) continue;
+      if ( !mRasterShader->generateShadedValue( myPixelValue, &myRedValue, &myGreenValue, &myBlueValue ) )
+        continue;
       if ( mInvertPixelsFlag )
-        myRedValue = 255 - myRedValue;
-        myGreenValue = 255 - myGreenValue;
-        myBlueValue = 255 - myBlueValue;
+        //Invert flag, flip blue and read
+        myQImage.setPixel( myRow, myColumn, qRgba( myBlueValue, myGreenValue, myRedValue, myAlphaValue ) );
-      myQImage.setPixel( myRow, myColumn, qRgba( myRedValue, myGreenValue, myBlueValue, myAlphaValue ) );
+      else
+        //Normal
+        myQImage.setPixel( myRow, myColumn, qRgba( myRedValue, myGreenValue, myBlueValue, myAlphaValue ) );
   CPLFree( myGdalScanData );
   //render any inline filters
@@ -1717,12 +1742,7 @@
     return;
-  QgsRasterBandStats myRasterBandStats;
-  //If there is a color ramp, i.e., a paletted layer, then no need to generate stats
-  if(COLOR_RAMP != mColorShadingAlgorithm)
-    myRasterBandStats = getRasterBandStats( theBandNo );
+  QgsRasterBandStats myRasterBandStats = getRasterBandStats( theBandNo );
@@ -1811,7 +1831,7 @@
+ * This method is used to render a paletted raster layer as a colour image -- currently not supported
@@ -1819,106 +1839,7 @@
 void QgsRasterLayer::drawPalettedMultiBandColor( QPainter * theQPainter, QgsRasterViewPort * theRasterViewPort,
     const QgsMapToPixel* theQgsMapToPixel, int theBandNo )
-  QgsDebugMsg( "entered." );
-  //Invalid band number, segfault prevention
-  if ( 0 >= theBandNo )
-    return;
-  GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
-  GDALDataType myDataType = GDALGetRasterDataType( myGdalBand );
-  void *myGdalScanData = readData( myGdalBand, theRasterViewPort );
-  /* Check for out of memory error */
-  if ( myGdalScanData == NULL )
-    return;
-  QImage myQImage = QImage( theRasterViewPort->drawableAreaXDim, theRasterViewPort->drawableAreaYDim, QImage::Format_ARGB32 );
-  myQImage.fill( qRgba( 255, 255, 255, 0 ) ); // fill transparent
-  double myPixelValue = 0.0;
-  int myRedLUTValue = 0;
-  int myGreenLUTValue = 0;
-  int myBlueLUTValue = 0;
-  int myRedValue = 0;  //color 1 int
-  int myGreenValue = 0;  //color 2 int
-  int myBlueValue = 0; //color 3 int
-  int myAlphaValue = 0;
-  for ( int myColumn = 0; myColumn < theRasterViewPort->drawableAreaYDim; ++myColumn )
-    for ( int myRow = 0; myRow < theRasterViewPort->drawableAreaXDim; ++myRow )
-      myRedLUTValue = 0;
-      myGreenLUTValue = 0;
-      myBlueLUTValue = 0;
-      myRedValue = 0;
-      myGreenValue = 0;
-      myBlueValue = 0;
-      myPixelValue = readValue( myGdalScanData, ( GDALDataType )myDataType,
-                                myColumn * theRasterViewPort->drawableAreaXDim + myRow );
-      if ( mValidNoDataValue && ( myPixelValue == mNoDataValue || myPixelValue != myPixelValue ) )
-        continue;
-      myAlphaValue = mRasterTransparency.getAlphaValue( myPixelValue, mTransparencyLevel );
-      if ( 0 == myAlphaValue )
-        continue;
-      bool found = myColorTable->color( myPixelValue, &myRedLUTValue, &myGreenLUTValue, &myBlueLUTValue );
-      //check for alternate color mappings
-      if ( mRedBandName == "Red" )
-        myRedValue = myRedLUTValue;
-      else if ( mRedBandName == "Green" )
-        myRedValue = myGreenLUTValue;
-      else if ( mRedBandName == "Blue" )
-        myRedValue = myBlueLUTValue;
-      if ( mGreenBandName == "Red" )
-        myGreenValue = myRedLUTValue;
-      else if ( mGreenBandName == "Green" )
-        myGreenValue = myGreenLUTValue;
-      else if ( mGreenBandName == "Blue" )
-        myGreenValue = myBlueLUTValue;
-      if ( mBlueBandName == "Red" )
-        myBlueValue = myRedLUTValue;
-      else if ( mBlueBandName == "Green" )
-        myBlueValue = myGreenLUTValue;
-      else if ( mBlueBandName == "Blue" )
-        myBlueValue = myBlueLUTValue;
-      if ( mInvertPixelsFlag )
-  CPLFree( myGdalScanData );
-  //render any inline filters
-  filterLayer( &myQImage );
-  paintImageToCanvas( theQPainter, theRasterViewPort, theQgsMapToPixel, &myQImage );
+  QgsDebugMsg( "Not supported at this time" );
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-08-28 15:25:01 UTC (rev 9202)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-08-28 15:27:55 UTC (rev 9203)
@@ -641,8 +641,8 @@
       SINGLE_BAND_PSEUDO_COLOR,// a "Gray" or "Undefined" layer drawn using a pseudocolor algorithm
       PALETTED_COLOR, //a "Palette" image drawn using color table
       PALETTED_SINGLE_BAND_GRAY,// a "Palette" layer drawn in gray scale (using only one of the color components)
-      PALETTED_SINGLE_BAND_PSEUDO_COLOR, // a "Palette" layer having only one of its color components rendered as psuedo color --PJE20080827 this is no longer accurate as it is used to shade the color ramp as well
-      PALETTED_MULTI_BAND_COLOR, // a "Palette" image is decomposed to 3 channels (RGB) and drawn --PJE20080827 this is no longer accurate
+      PALETTED_SINGLE_BAND_PSEUDO_COLOR, // a "Palette" layer having only one of its color components rendered as psuedo color
+      PALETTED_MULTI_BAND_COLOR, // currently not supported
       // as multiband
       MULTI_BAND_SINGLE_BAND_GRAY, // a layer containing 2 or more bands, but using only one band to produce a grayscale image
       MULTI_BAND_SINGLE_BAND_PSEUDO_COLOR, //a layer containing 2 or more bands, but using only one band to produce a pseudocolor image
@@ -930,7 +930,7 @@
     // Paletted Layers
-    /** \brief Drawing routine for paletted image, rendered as a single band image in color.  */
+    /** \brief Drawing routine for single band with a color map.  */
     void drawPalettedSingleBandColor( QPainter * theQPainter,
More information about the QGIS-commit mailing list
