[QGIS Commit] r9840 - in docs/trunk/english_us/user_guide: .
plugins_raster_algebra_images plugins_table_manager_images
svn_qgis at osgeo.org
Wed Dec 17 13:55:51 EST 2008
Author: dassau
Date: 2008-12-17 13:55:51 -0500 (Wed, 17 Dec 2008)
New Revision: 9840
Added:
docs/trunk/english_us/user_guide/plugins_raster_algebra.tex
docs/trunk/english_us/user_guide/plugins_raster_algebra_images/
docs/trunk/english_us/user_guide/plugins_raster_algebra_images/Makefile
docs/trunk/english_us/user_guide/plugins_raster_algebra_images/ftoolslogo.png
docs/trunk/english_us/user_guide/plugins_table_manager.tex
docs/trunk/english_us/user_guide/plugins_table_manager_images/
docs/trunk/english_us/user_guide/plugins_table_manager_images/Makefile
docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_1downarrow.png
docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_1uparrow.png
docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_sum.png
docs/trunk/english_us/user_guide/plugins_table_manager_images/tableManagerIcon.png
docs/trunk/english_us/user_guide/plugins_table_manager_images/tableManagerIcon3.png
docs/trunk/english_us/user_guide/Makefile
docs/trunk/english_us/user_guide/external_plugins.tex
docs/trunk/english_us/user_guide/plugins_ftools.tex
docs/trunk/english_us/user_guide/user_guide.tex
started with sections for more external plugins
Modified: docs/trunk/english_us/user_guide/Makefile
--- docs/trunk/english_us/user_guide/Makefile 2008-12-17 11:06:13 UTC (rev 9839)
+++ docs/trunk/english_us/user_guide/Makefile 2008-12-17 18:55:51 UTC (rev 9840)
@@ -83,6 +83,8 @@
(cd ./plugins_spit_images && make)
(cd ./plugins_screenies && make)
(cd ./plugins_ftools_images && make)
+ (cd ./plugins_table_manager_images && make)
+ (cd ./plugins_raster_algebra_images && make)
(cd ./plugins_python_images && make)
(cd ./getting_started_screenies && make)
(cd ./working_with_vector_screenies && make)
@@ -133,6 +135,8 @@
(cd ./plugins_spit_images && make clean)
(cd ./plugins_python_images && make clean)
(cd ./plugins_ftools_images && make clean)
+ (cd ./plugins_table_manager_images && make clean)
+ (cd ./plugins_raster_algebra_images && make clean)
(cd ./plugins_screenies && make clean)
(cd ./getting_started_screenies && make clean)
(cd ./working_with_vector_screenies && make clean)
Modified: docs/trunk/english_us/user_guide/external_plugins.tex
--- docs/trunk/english_us/user_guide/external_plugins.tex 2008-12-17 11:06:13 UTC (rev 9839)
+++ docs/trunk/english_us/user_guide/external_plugins.tex 2008-12-17 18:55:51 UTC (rev 9840)
@@ -4,10 +4,49 @@
% comment out the following line:
\updatedisclaimer
-External QGIS plugins are currently all written in python. They are stored
-in external svn repositories and maintained by the individual author. They
-can be added to the QGIS \filename{Plugin Manager} with the
-\filename{Plugin installer} plugin, described in Section
-\ref{sec:external_plugins}.
+External QGIS plugins are all written in python. They are stored in
+an official, moderated svn repository and maintained by the individual
+author. Table \ref{tab:external_plugins} shows a list of plugins
+currently available. All these plugins are descibed in this manual.
+\begin{table}[H]
+\centering
+\caption{QGIS moderated external Plugins}\label{tab:external_plugins}\medskip
+\small
+ \begin{tabular}{|l|l|p{4in}|}
+\hline \textbf{Icon} & \textbf{external Plugin} & \textbf{Description}\\
+\hline
+\includegraphics[width=0.7cm]{ftoolslogo}
+ & fTools \index{plugins!fTools} & Vector analysis and data management tools\\
+\hline
+\includegraphics[width=0.7cm]{tableManagerIcon}
+ & Table Manager \index{plugins!Table Manager}& Manage attribute tables \\
+\hline
+ & Raster Algebra \index{plugins!Raster Algebra}& Basic raster algebra
+for GDAL supported raster layer\\
+\hline
+\end{tabular}
+\end{table}
+A detailed install description for external python plugins can be found in
+Section \ref{sec:load_external_plugin}.
+\minisec{Unofficial Python Plugin repository}
+Apart from the moderated external plugins there exist another unofficial
+Python Plugin repository. It contains of plugins that are not yet stable
+enough...
+ADD MORE INFO HERE
+\begin{Tip} \caption{\textsc{Add more external Plugins}}
+\qgistip{Apart from the official QGIS plugin repository you can add
+more external repositories. Therefore select the Repositories tab in
+the Python Plugins Installer
+\end{Tip}
Modified: docs/trunk/english_us/user_guide/plugins_ftools.tex
--- docs/trunk/english_us/user_guide/plugins_ftools.tex 2008-12-17 11:06:13 UTC (rev 9839)
+++ docs/trunk/english_us/user_guide/plugins_ftools.tex 2008-12-17 18:55:51 UTC (rev 9840)
@@ -12,8 +12,8 @@
\minisec{Install the fTools Plugin}
To use the functionalities in QGIS, you must install the fTool python plugin
-with the \mainmenuopt{Fetch Python Plugins} Installer from Carson Farmers
-Repository (see Section \ref{sec:external_plugins}). Then select and load it
+with the \mainmenuopt{Fetch Python Plugins} Installer (see
+Section \ref{sec:load_external_plugin}). Then select and load it
with the Plugin Manager. Therefore click the menu \mainmenuopt{Plugins} >
\mainmenuopt{Manage Plugins}, select \dropmenuopt{fTools} and click
\button{OK}. A new menu \mainmenuopt{Tools} occurs in the menu bar with
Added: docs/trunk/english_us/user_guide/plugins_raster_algebra.tex
--- docs/trunk/english_us/user_guide/plugins_raster_algebra.tex (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_raster_algebra.tex 2008-12-17 18:55:51 UTC (rev 9840)
@@ -0,0 +1,18 @@
+\subsection{Raster Algebra Plugin}\label{sec:ftools}
+% when the revision of a section has been finalized,
+% comment out the following line:
+\updatedisclaimer
+\minisec{Install the Raster Algebra Plugin}
+To use the functionalities in QGIS, you must install the Raster Algebra
+python plugin with the \mainmenuopt{Fetch Python Plugins} Installer
+(see Section \ref{sec:load_external_plugin}). Then select and load it
+with the Plugin Manager. Therefore click the menu \mainmenuopt{Plugins} >
+\mainmenuopt{Manage Plugins}, select \dropmenuopt{Raster Algebra} and click
+\button{OK}. A new \toolbtntwo{copyright_label}{Raster Algebra} icon occurs
+in the toolbar.
Added: docs/trunk/english_us/user_guide/plugins_raster_algebra_images/Makefile
--- docs/trunk/english_us/user_guide/plugins_raster_algebra_images/Makefile (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_raster_algebra_images/Makefile 2008-12-17 18:55:51 UTC (rev 9840)
@@ -0,0 +1,41 @@
+# makefile to convert figures into eps format for the book
+# Comments from Michel Wurtz:
+# You will notice that the list given is the list of targets. "all" just
+# refer to this list. The most important rule is the next rule, that give
+# the generic rule for transforming a .fig into a .eps file. Note the use
+# of % (define the couple target:source) and the use of
+# $< (source postfix, here .fig) and $@ (target postfix, here .eps)
+# with .eps extension:
+# JPG=qgis_icon_new_verylarge.eps\
+# nextfile.eps
+PNG=ftoolslogo.eps\
+##### TARGETS #####
+all: $(PNG) $(JPG)
+ if [ ! -d ../finalpix/ ]; then mkdir ../finalpix; fi
+ #do not use move (mv):
+ cp *.eps ../finalpix/
+#$(EPS): %.eps: %.fig
+# fig2dev -L eps $< > $@
+#$(FIGPNG): %.png: %.fig
+# fig2dev -L png -m 2 $< > $@
+$(PNG): %.eps: %.png
+ # Workaround for PDF
+ #convert -geometry 300x -depth 1 $< $@
+ convert $< $@
+$(JPG): %.eps: %.jpg
+ convert $< $@
+clean:
+ rm -f *.bak *~ *.pdf $(PNG) $(JPG)
Added: docs/trunk/english_us/user_guide/plugins_raster_algebra_images/ftoolslogo.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_raster_algebra_images/ftoolslogo.png
___________________________________________________________________
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/plugins_table_manager.tex
--- docs/trunk/english_us/user_guide/plugins_table_manager.tex (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_table_manager.tex 2008-12-17 18:55:51 UTC (rev 9840)
@@ -0,0 +1,26 @@
+\subsection{Table Manager Plugin}\label{sec:ftools}
+\updatedisclaimer
+This plugin provides tools for managing attribute tables. It provides the
+possibility of managing attribute fields directly from QGIS. At the moment
+this includes to insert, delete, move and clone fields and save the results
+as new shapefile. This plugin does not yet write anything to the original
+table. All changes are exported to a new shapefile layer for safety reasons.
+\minisec{Install the Table Manager Plugin}
+To use the functionalities in QGIS, you must install the Table Manager python
+plugin with the \mainmenuopt{Fetch Python Plugins} Installer (see Section
+\ref{sec:load_external_plugin}). Then select and load it with the Plugin Manager.
+Therefore click the menu \mainmenuopt{Plugins} >
+\mainmenuopt{Manage Plugins}, select \dropmenuopt{Table Manager} and click
+\button{OK}. A new \toolbtntwo{tableManagerIcon}{Table Manager} icon occurs
+in the toolbar. icon appears in the toolbar menu.
Added: docs/trunk/english_us/user_guide/plugins_table_manager_images/Makefile
--- docs/trunk/english_us/user_guide/plugins_table_manager_images/Makefile (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_table_manager_images/Makefile 2008-12-17 18:55:51 UTC (rev 9840)
@@ -0,0 +1,45 @@
+# nextfile.eps
+PNG=crystalsvg_1downarrow.eps\
+ crystalsvg_1uparrow.eps\
+ tableManagerIcon3.eps\
+ crystalsvg_sum.eps\
+ tableManagerIcon.eps\
+all: $(PNG) $(JPG)
+ convert $< $@
+ convert $< $@
+clean:
Added: docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_1downarrow.png
Property changes on: docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_1downarrow.png
Added: docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_1uparrow.png
Property changes on: docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_1uparrow.png
Added: docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_sum.png
Property changes on: docs/trunk/english_us/user_guide/plugins_table_manager_images/crystalsvg_sum.png
Added: docs/trunk/english_us/user_guide/plugins_table_manager_images/tableManagerIcon.png
Property changes on: docs/trunk/english_us/user_guide/plugins_table_manager_images/tableManagerIcon.png
Added: docs/trunk/english_us/user_guide/plugins_table_manager_images/tableManagerIcon3.png
Property changes on: docs/trunk/english_us/user_guide/plugins_table_manager_images/tableManagerIcon3.png
Modified: docs/trunk/english_us/user_guide/user_guide.tex
--- docs/trunk/english_us/user_guide/user_guide.tex 2008-12-17 11:06:13 UTC (rev 9839)
+++ docs/trunk/english_us/user_guide/user_guide.tex 2008-12-17 18:55:51 UTC (rev 9840)
@@ -37,6 +37,8 @@
\include{plugins_ogr_converter}
\include{external_plugins}
\include{plugins_ftools}
+\include{plugins_table_manager}
+\include{plugins_raster_algebra}
\include{plugins_writing_in_cpp}
\include{plugins_writing_in_python}
%end of plugin docs
