[QGIS Commit] r8119 - trunk/qgis/src/plugins/quick_print
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Feb 8 06:17:27 EST 2008
Author: timlinux
Date: 2008-02-08 06:17:27 -0500 (Fri, 08 Feb 2008)
New Revision: 8119
   trunk/qgis/src/plugins/quick_print/quickprintguibase.ui
Saved dialog using qt4.2.x
Modified: trunk/qgis/src/plugins/quick_print/quickprintguibase.ui
--- trunk/qgis/src/plugins/quick_print/quickprintguibase.ui	2008-02-08 11:06:49 UTC (rev 8118)
+++ trunk/qgis/src/plugins/quick_print/quickprintguibase.ui	2008-02-08 11:17:27 UTC (rev 8119)
@@ -16,100 +16,44 @@
    <iconset resource="quickprint.qrc" >:/quickprint/quickprint.png</iconset>
   </property>
   <layout class="QGridLayout" >
-   <item row="0" column="0" >
-    <widget class="QLabel" name="txtHeading" >
-     <property name="sizePolicy" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
-       <horstretch>0</horstretch>
-       <verstretch>0</verstretch>
-      </sizepolicy>
+   <property name="margin" >
+    <number>9</number>
+   </property>
+   <property name="spacing" >
+    <number>6</number>
+   </property>
+   <item row="11" column="0" >
+    <widget class="QDialogButtonBox" name="buttonBox" >
+     <property name="orientation" >
+      <enum>Qt::Horizontal</enum>
      </property>
-     <property name="font" >
-      <font>
-       <family>Sans Serif</family>
-       <pointsize>24</pointsize>
-       <weight>75</weight>
-       <italic>false</italic>
-       <bold>true</bold>
-       <underline>false</underline>
-       <strikeout>false</strikeout>
-      </font>
+     <property name="standardButtons" >
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
      </property>
-     <property name="text" >
-      <string>Quick Print</string>
-     </property>
-     <property name="alignment" >
-      <set>Qt::AlignCenter</set>
-     </property>
     </widget>
    </item>
-   <item row="1" column="0" >
-    <widget class="QLabel" name="lblMapTitle" >
+   <item row="10" column="0" >
+    <widget class="QLabel" name="label" >
-      <string>Map Title e.g. ACME inc.</string>
+      <string>Note: If you want more control over the map layout please use the map composer function in QGIS.</string>
      </property>
-     <property name="buddy" >
-      <cstring>leMapTitle</cstring>
+     <property name="wordWrap" >
+      <bool>true</bool>
      </property>
     </widget>
    </item>
-   <item row="2" column="0" >
-    <widget class="QLineEdit" name="leMapTitle" />
-   </item>
-   <item row="3" column="0" >
-    <widget class="QLabel" name="lblMapName" >
-      <string>Map Name e.g. Water Features</string>
-     </property>
-      <cstring>leMapName</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="0" >
-    <widget class="QLineEdit" name="leMapName" />
-   </item>
-   <item row="5" column="0" >
-    <widget class="QLabel" name="lblCopyright" >
-      <string>Copyright</string>
-     </property>
-      <cstring>teCopyright</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="6" column="0" >
-    <widget class="QTextEdit" name="teCopyright" />
-   </item>
-   <item row="7" column="0" >
-    <widget class="QLabel" name="label_2" >
-      <string>Page Size</string>
-     </property>
-    </widget>
-   </item>
-   <item row="8" column="0" >
-    <widget class="QComboBox" name="cboPageSize" />
-   </item>
    <item row="9" column="0" >
     <widget class="QGroupBox" name="grpOuput" >
      <property name="title" >
       <string>Output</string>
      </property>
-      <property name="leftMargin" >
        <number>11</number>
       </property>
-      <property name="topMargin" >
-       <number>11</number>
       </property>
-      <property name="rightMargin" >
-      </property>
-      <property name="bottomMargin" >
-      </property>
        <widget class="QRadioButton" name="radUseIncrementedFileName" >
@@ -140,26 +84,84 @@
      </layout>
     </widget>
    </item>
-   <item row="10" column="0" >
-    <widget class="QLabel" name="label" >
+   <item row="8" column="0" >
+    <widget class="QComboBox" name="cboPageSize" />
+   </item>
+   <item row="7" column="0" >
+    <widget class="QLabel" name="label_2" >
-      <string>Note: If you want more control over the map layout please use the map composer function in QGIS.</string>
+      <string>Page Size</string>
      </property>
-     <property name="wordWrap" >
-      <bool>true</bool>
+    </widget>
+   </item>
+   <item row="6" column="0" >
+    <widget class="QTextEdit" name="teCopyright" />
+   </item>
+   <item row="5" column="0" >
+    <widget class="QLabel" name="lblCopyright" >
+     <property name="text" >
+      <string>Copyright</string>
      </property>
+     <property name="buddy" >
+      <cstring>teCopyright</cstring>
+     </property>
     </widget>
    </item>
-   <item row="11" column="0" >
-    <widget class="QDialogButtonBox" name="buttonBox" >
-     <property name="orientation" >
-      <enum>Qt::Horizontal</enum>
+   <item row="4" column="0" >
+    <widget class="QLineEdit" name="leMapName" />
+   </item>
+   <item row="3" column="0" >
+    <widget class="QLabel" name="lblMapName" >
+      <string>Map Name e.g. Water Features</string>
      </property>
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+      <cstring>leMapName</cstring>
      </property>
     </widget>
    </item>
+   <item row="2" column="0" >
+    <widget class="QLineEdit" name="leMapTitle" />
+   </item>
+   <item row="1" column="0" >
+    <widget class="QLabel" name="lblMapTitle" >
+      <string>Map Title e.g. ACME inc.</string>
+     </property>
+      <cstring>leMapTitle</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="0" column="0" >
+    <widget class="QLabel" name="txtHeading" >
+     <property name="sizePolicy" >
+      <sizepolicy>
+       <hsizetype>0</hsizetype>
+       <vsizetype>0</vsizetype>
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
+     <property name="font" >
+      <font>
+       <family>Sans Serif</family>
+       <pointsize>24</pointsize>
+       <weight>75</weight>
+       <italic>false</italic>
+       <bold>true</bold>
+       <underline>false</underline>
+       <strikeout>false</strikeout>
+      </font>
+     </property>
+      <string>Quick Print</string>
+     </property>
+     <property name="alignment" >
+      <set>Qt::AlignCenter</set>
+     </property>
+    </widget>
+   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11" />
More information about the QGIS-commit mailing list
