[QGIS Commit] r8135 - in trunk/qgis: python/core src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Feb 11 05:39:40 EST 2008
Author: timlinux
Date: 2008-02-11 05:39:40 -0500 (Mon, 11 Feb 2008)
New Revision: 8135
   trunk/qgis/python/core/qgsmaprender.sip
   trunk/qgis/python/core/qgsscalecalculator.sip
   trunk/qgis/src/core/qgsmaprender.cpp
   trunk/qgis/src/core/qgsmaprender.h
   trunk/qgis/src/core/qgsscalecalculator.cpp
   trunk/qgis/src/core/qgsscalecalculator.h
Make maprender able to tell us the map size and dpi (there were previously no accessors for this)
Modified: trunk/qgis/python/core/qgsmaprender.sip
--- trunk/qgis/python/core/qgsmaprender.sip	2008-02-10 21:14:32 UTC (rev 8134)
+++ trunk/qgis/python/core/qgsmaprender.sip	2008-02-11 10:39:40 UTC (rev 8135)
@@ -48,6 +48,11 @@
     void setOutputSize(QSize size, int dpi);
+    //!accessor for output dpi
+    int outputDpi();
+    //!accessor for output size
+    QSize outputSize();
     //! transform extent in layer's SRS to extent in output SRS
     QgsRect layerExtentToOutputExtent(QgsMapLayer* theLayer, QgsRect extent);
Modified: trunk/qgis/python/core/qgsscalecalculator.sip
--- trunk/qgis/python/core/qgsscalecalculator.sip	2008-02-10 21:14:32 UTC (rev 8134)
+++ trunk/qgis/python/core/qgsscalecalculator.sip	2008-02-11 10:39:40 UTC (rev 8135)
@@ -31,6 +31,12 @@
     void setDpi(int dpi);
+     * Accessor for dpi used in scale calculations
+     * @return int the dpi used for scale calculations.
+    int dpi();
      * Set the map units
      * @param mapUnits Units of the data on the map. Must match a value from the
Modified: trunk/qgis/src/core/qgsmaprender.cpp
--- trunk/qgis/src/core/qgsmaprender.cpp	2008-02-10 21:14:32 UTC (rev 8134)
+++ trunk/qgis/src/core/qgsmaprender.cpp	2008-02-11 10:39:40 UTC (rev 8135)
@@ -118,6 +118,14 @@
   mScaleCalculator->setDpi(dpi);
   adjustExtentToSize();
+int QgsMapRender::outputDpi()
+  return mScaleCalculator->dpi();
+QSize QgsMapRender::outputSize()
+  return mSize;
 void QgsMapRender::adjustExtentToSize()
Modified: trunk/qgis/src/core/qgsmaprender.h
--- trunk/qgis/src/core/qgsmaprender.h	2008-02-10 21:14:32 UTC (rev 8134)
+++ trunk/qgis/src/core/qgsmaprender.h	2008-02-11 10:39:40 UTC (rev 8135)
@@ -79,6 +79,11 @@
     void setOverview(bool isOverview = true) { mOverview = isOverview; }
+    int outputDpi();
Modified: trunk/qgis/src/core/qgsscalecalculator.cpp
--- trunk/qgis/src/core/qgsscalecalculator.cpp	2008-02-10 21:14:32 UTC (rev 8134)
+++ trunk/qgis/src/core/qgsscalecalculator.cpp	2008-02-11 10:39:40 UTC (rev 8135)
@@ -35,6 +35,10 @@
   mDpi = dpi;
+int QgsScaleCalculator::dpi()
+  return mDpi;
 void QgsScaleCalculator::setMapUnits(QGis::units mapUnits)
Modified: trunk/qgis/src/core/qgsscalecalculator.h
--- trunk/qgis/src/core/qgsscalecalculator.h	2008-02-10 21:14:32 UTC (rev 8134)
+++ trunk/qgis/src/core/qgsscalecalculator.h	2008-02-11 10:39:40 UTC (rev 8135)
@@ -51,6 +51,11 @@
      * @param dpi Dots per inch of monitor resolution
+    int dpi();
      * Set the map units
@@ -70,7 +75,7 @@
     double calculate(QgsRect &mapExtent, int canvasWidth);
-     * Calculate the distance between to points in geographic coordinates.
+     * Calculate the distance between two points in geographic coordinates.
      * Used to calculate scale for map views with geographic (decimal degree)
      * data.
      * @param mapExtent QgsRect containing the current map extent
More information about the QGIS-commit mailing list
