[QGIS Commit] r8146 - branches/ogr-plugin-branch/src/ui
svn_qgis at osgeo.org
Tue Feb 12 16:10:07 EST 2008
Author: gcontreras
Date: 2008-02-12 16:10:07 -0500 (Tue, 12 Feb 2008)
New Revision: 8146
Added:
branches/ogr-plugin-branch/src/ui/qgsnewogrgenericconnectionbase.ui
branches/ogr-plugin-branch/src/ui/CMakeLists.txt
added dialog for ogr database generic connections
Modified: branches/ogr-plugin-branch/src/ui/CMakeLists.txt
--- branches/ogr-plugin-branch/src/ui/CMakeLists.txt 2008-02-12 20:06:12 UTC (rev 8145)
+++ branches/ogr-plugin-branch/src/ui/CMakeLists.txt 2008-02-12 21:10:07 UTC (rev 8146)
@@ -33,6 +33,7 @@
qgsmessageviewer.ui
qgsnewconnectionbase.ui
qgsnewhttpconnectionbase.ui
+ qgsnewogrgenericconnectionbase.ui
qgsoptionsbase.ui
qgspastetransformationsbase.ui
qgspatterndialogbase.ui
Added: branches/ogr-plugin-branch/src/ui/qgsnewogrgenericconnectionbase.ui
--- branches/ogr-plugin-branch/src/ui/qgsnewogrgenericconnectionbase.ui (rev 0)
+++ branches/ogr-plugin-branch/src/ui/qgsnewogrgenericconnectionbase.ui 2008-02-12 21:10:07 UTC (rev 8146)
@@ -0,0 +1,260 @@
+<ui version="4.0" >
+ <class>QgsNewOgrGenericConnectionBase</class>
+ <widget class="QDialog" name="QgsNewOgrGenericConnectionBase" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>487</width>
+ <height>152</height>
+ </rect>
+ </property>
+ <property name="sizePolicy" >
+ <sizepolicy>
+ <hsizetype>3</hsizetype>
+ <vsizetype>3</vsizetype>
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="windowTitle" >
+ <string>Create New Ogr Database Connection</string>
+ </property>
+ <property name="sizeGripEnabled" >
+ <bool>true</bool>
+ </property>
+ <property name="modal" >
+ <bool>true</bool>
+ </property>
+ <layout class="QHBoxLayout" >
+ <property name="margin" >
+ <number>9</number>
+ </property>
+ <property name="spacing" >
+ <number>6</number>
+ </property>
+ <item>
+ <widget class="Q3GroupBox" name="GroupBox1" >
+ <property name="title" >
+ <string>Connection Information</string>
+ </property>
+ <property name="orientation" >
+ <enum>Qt::Vertical</enum>
+ </property>
+ <layout class="QVBoxLayout" >
+ <number>0</number>
+ </property>
+ </property>
+ <item>
+ </property>
+ </property>
+ <item>
+ <layout class="QGridLayout" >
+ </property>
+ </property>
+ <item row="1" column="1" >
+ <widget class="QLineEdit" name="txtUri" />
+ </item>
+ <item row="0" column="1" >
+ <widget class="QLineEdit" name="txtName" >
+ <property name="toolTip" >
+ <string>Name of the new connection</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QLabel" name="TextLabel1" >
+ <property name="text" >
+ <string>URI</string>
+ </property>
+ <property name="buddy" >
+ <cstring>txtUri</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="0" >
+ <widget class="QLabel" name="TextLabel1_2" >
+ <string>Name</string>
+ </property>
+ <cstring>txtName</cstring>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ </property>
+ </property>
+ <item>
+ <spacer>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>20</width>
+ <height>40</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ </property>
+ </property>
+ <item>
+ <spacer>
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <size>
+ <width>111</width>
+ <height>30</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QPushButton" name="btnConnect" >
+ <string>Test Connect</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item>
+ <widget class="QFrame" name="frame" >
+ <property name="frameShape" >
+ <enum>QFrame::NoFrame</enum>
+ </property>
+ <property name="frameShadow" >
+ <enum>QFrame::Raised</enum>
+ </property>
+ </widget>
+ </item>
+ <item>
+ </property>
+ </property>
+ <item>
+ <widget class="QPushButton" name="btnOk" >
+ <string>OK</string>
+ </property>
+ <property name="shortcut" >
+ <string/>
+ </property>
+ <property name="autoDefault" >
+ <bool>true</bool>
+ </property>
+ <property name="default" >
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="btnCancel" >
+ <string>Cancel</string>
+ </property>
+ <string/>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="btnHelp" >
+ <property name="enabled" >
+ <bool>true</bool>
+ </property>
+ <string>Help</string>
+ </property>
+ <string>F1</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer>
+ </property>
+ <property name="sizeType" >
+ <enum>QSizePolicy::Expanding</enum>
+ </property>
+ <size>
+ <width>87</width>
+ <height>150</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ <layoutdefault spacing="6" margin="11" />
+ <pixmapfunction>qPixmapFromMimeSource</pixmapfunction>
+ <customwidgets>
+ <customwidget>
+ <class>Q3GroupBox</class>
+ <extends>QGroupBox</extends>
+ <header>Qt3Support/Q3GroupBox</header>
+ <container>1</container>
+ </customwidget>
+ </customwidgets>
+ <tabstops>
+ <tabstop>txtName</tabstop>
+ <tabstop>txtUri</tabstop>
+ <tabstop>btnConnect</tabstop>
+ <tabstop>btnOk</tabstop>
+ <tabstop>btnCancel</tabstop>
+ <tabstop>btnHelp</tabstop>
+ </tabstops>
+ <resources/>
+ <connections/>
+</ui>
