[QGIS Commit] r8714 - trunk/qgis/tests/src/core
    svn_qgis at osgeo.org
    Sun Jul  6 07:46:51 EDT 2008
Author: timlinux
Date: 2008-07-06 07:46:51 -0400 (Sun, 06 Jul 2008)
New Revision: 8714
   trunk/qgis/tests/src/core/testqgsrenderers.cpp
Use new mechanism to find path. Test still fails due to small differences in rendered output
Modified: trunk/qgis/tests/src/core/testqgsrenderers.cpp
--- trunk/qgis/tests/src/core/testqgsrenderers.cpp	2008-07-06 11:41:07 UTC (rev 8713)
+++ trunk/qgis/tests/src/core/testqgsrenderers.cpp	2008-07-06 11:46:51 UTC (rev 8714)
@@ -40,7 +40,6 @@
   Q_OBJECT;
   private slots:
-    QString getQgisPath(); // Gets the path to QGIS installation
     void initTestCase();// will be called before the first testfunction is executed.
     void cleanupTestCase();// will be called after the last testfunction was executed.
     void init(){};// will be called before each testfunction is executed.
@@ -61,25 +60,13 @@
     QString mReport;
-QString TestQgsRenderers::getQgisPath()
-#ifdef Q_OS_LINUX
-  QString qgisPath = QCoreApplication::applicationDirPath () + "/../";
-#else //mac and win
-  QString qgisPath = QCoreApplication::applicationDirPath () ;
-#endif
-  return qgisPath;
 void TestQgsRenderers::initTestCase()
   // init QGIS's paths - true means that all path will be inited from prefix
-  //QString qgisPath = QCoreApplication::applicationDirPath ();
-  QgsApplication::setPrefixPath(getQgisPath(), TRUE);
-#ifdef Q_OS_LINUX
-//  QgsApplication::setPkgDataPath(qgisPath + "/../share/qgis");
-//  QgsApplication::setPluginPath(qgisPath + "/../lib/qgis");
-#endif
+  QString qgisPath = QCoreApplication::applicationDirPath ();
+  QgsApplication::setPrefixPath(INSTALL_PREFIX, true);
+  QgsApplication::showSettings();
   // Instantiate the plugin directory so that providers are loaded
   QgsProviderRegistry::instance(QgsApplication::pluginPath());
