[QGIS Commit] r8720 - in trunk/qgis: resources src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jul 7 03:40:11 EDT 2008
Author: mhugent
Date: 2008-07-07 03:40:10 -0400 (Mon, 07 Jul 2008)
New Revision: 8720
   trunk/qgis/resources/srs.db
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsoptions.cpp
   trunk/qgis/src/app/qgsoptions.h
   trunk/qgis/src/app/qgsserversourceselect.cpp
New srs.db and code changes to save settings by proj4 string instead of qgis srsid number
Modified: trunk/qgis/resources/srs.db
(Binary files differ)
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-07-07 02:25:54 UTC (rev 8719)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-07-07 07:40:10 UTC (rev 8720)
@@ -265,13 +265,17 @@
     //it in the ctor of the layer projection selector
     QgsLayerProjectionSelector * mySelector = new QgsLayerProjectionSelector();
-    long myDefaultSRS =
-        QgsProject::instance()->readNumEntry("SpatialRefSys","/ProjectSRSID",GEOSRS_ID);
-    mySelector->setSelectedSRSID(myDefaultSRS);
+    proj4String = QgsProject::instance()->readEntry("SpatialRefSys","//ProjectSRSProj4String",GEOPROJ4);
+    QgsSpatialRefSys defaultSRS;
+    if(defaultSRS.createFromProj4(proj4String))
+	mySelector->setSelectedSRSID(defaultSRS.srsid());
     if(mySelector->exec())
       QgsDebugMsg("Layer srs set from dialog: " + QString::number(mySelector->getCurrentSRSID()));
-      srs->createFromSrsId(mySelector->getCurrentSRSID());
+      srs->createFromProj4(mySelector->getCurrentProj4String());
       srs->debugPrint();
     else
@@ -290,10 +294,7 @@
   else ///Projections/defaultBehaviour==useGlobal
-    // XXX TODO: Change global settings to store default CS as 'defaultSRS' not 'defaultProjectionWKT'
-    int srs_id = mySettings.value("/Projections/defaultProjectionSRSID",(int)GEOSRS_ID).toInt();
-    QgsDebugMsg("Layer srs set from global: " + proj4String);
-    srs->createFromSrsId(srs_id);
+    srs->createFromProj4(mySettings.value("/Projections/defaultProjectionString",GEOPROJ4).toString());
     srs->debugPrint();
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp	2008-07-07 02:25:54 UTC (rev 8719)
+++ trunk/qgis/src/app/qgsoptions.cpp	2008-07-07 07:40:10 UTC (rev 8720)
@@ -84,11 +84,9 @@
     radUseGlobalProjection->setChecked(true);
-  mGlobalSRSID = settings.value("/Projections/defaultProjectionSRSID",(int)GEOSRS_ID).toInt();
-  //! @todo changes this control name in gui to txtGlobalProjString
-  QString myProjString = QgsSpatialRefSys::getProj4FromSrsId(mGlobalSRSID);
-  txtGlobalWKT->setText(myProjString);
+  txtGlobalWKT->setText(settings.value("/Projections/defaultProjectionString",GEOPROJ4).toString());
   // populate combo box with ellipsoids
   getEllipsoidList();
   QString myEllipsoidId = settings.value("/qgis/measure/ellipsoid", "WGS84").toString();
@@ -293,8 +291,9 @@
     settings.setValue("/Projections/defaultBehaviour", "useGlobal");
-  settings.setValue("/Projections/defaultProjectionSRSID",(int)mGlobalSRSID);
+  settings.setValue("/Projections/defaultProjectionString", txtGlobalWKT->toPlainText());
   settings.setValue("/qgis/measure/ellipsoid", getEllipsoidAcronym(cmbEllipsoid->currentText()));
   //set the colour for selections
@@ -367,13 +366,19 @@
   QSettings settings;
   QgsLayerProjectionSelector * mySelector = new QgsLayerProjectionSelector(this);
-  mySelector->setSelectedSRSID(mGlobalSRSID);
+  //find out srs id of current proj4 string
+  QgsSpatialRefSys refSys;
+  if(refSys.createFromProj4(txtGlobalWKT->toPlainText()))
+      mySelector->setSelectedSRSID(refSys.srsid());
 #ifdef QGISDEBUG
     std::cout << "------ Global Default Projection Selection Set ----------" << std::endl;
-#endif
-    mGlobalSRSID = mySelector->getCurrentSRSID();
+#endif
     txtGlobalWKT->setText(mySelector->getCurrentProj4String());
 #ifdef QGISDEBUG
Modified: trunk/qgis/src/app/qgsoptions.h
--- trunk/qgis/src/app/qgsoptions.h	2008-07-07 02:25:54 UTC (rev 8719)
+++ trunk/qgis/src/app/qgsoptions.h	2008-07-07 07:40:10 UTC (rev 8720)
@@ -97,8 +97,11 @@
     QWidget *qparent;
     //!Global default projection used for new layers added that have no projection
-    long mGlobalSRSID;
+    //long mGlobalSRSID;
+    //!Default proj4 string used for new layers added that have no projection
+    QString mGlobalProj4String;
 #endif // #ifndef QGSOPTIONS_H
Modified: trunk/qgis/src/app/qgsserversourceselect.cpp
--- trunk/qgis/src/app/qgsserversourceselect.cpp	2008-07-07 02:25:54 UTC (rev 8719)
+++ trunk/qgis/src/app/qgsserversourceselect.cpp	2008-07-07 07:40:10 UTC (rev 8720)
@@ -434,10 +434,13 @@
   mySelector->setOgcWmsCrsFilter(crsFilter);
-  long myDefaultSRS = QgsProject::instance()->readNumEntry("SpatialRefSys", "/ProjectSRSID", GEOSRS_ID);
+  QString myDefaultProjString = QgsProject::instance()->readEntry("SpatialRefSys", "/ProjectSRSProj4String", GEOPROJ4);
+  if(defaultSRS.createFromProj4(myDefaultProjString))
   if (mySelector->exec())
     m_Epsg = mySelector->getCurrentEpsg();
More information about the QGIS-commit mailing list
