[QGIS Commit] r8723 - trunk/qgis/doc
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jul 7 04:24:10 EDT 2008
Author: timlinux
Date: 2008-07-07 04:24:10 -0400 (Mon, 07 Jul 2008)
New Revision: 8723
   trunk/qgis/doc/index.html
Updated version number, requirements and whats new
Modified: trunk/qgis/doc/index.html
--- trunk/qgis/doc/index.html	2008-07-07 08:18:37 UTC (rev 8722)
+++ trunk/qgis/doc/index.html	2008-07-07 08:24:10 UTC (rev 8723)
@@ -21,39 +21,43 @@
 <!-- This documentation describes the Quantum GIS (QGIS) application. More
 information on QGIS is available on the web page at http://qgis.org. -->
-<h2>Whats new in Version 0.10.0?</h2>
+<h2>Whats new in Version 0.11.0?</h2>
 <p>
 </p>
-This release includes over 120 bug fixes and enchancements
-over the QGIS 0.9.1 release. In addition we have added
+This release includes over 60 bug fixes and enchancements
+over the QGIS 0.10.0 release. In addition we have added
 the following new features:
-<ul><li>
-Improvements to digitising capabilities.
-</li>
-<li>
-Supporting default and defined styles (.qml) files for file based
-vector layers. With styles you can save the symbolisation
-and other settings associated with a vector layer and they
-will be loaded whenever you load that layer.
-</li>
-<li>
-Improved support for transparency and contrast stretching
-in raster layers. Support for color ramps in raster layers.
-Support for non-north up rasters. Many other raster
-improvements 'under the hood'.
-</li>
-<li>
-Updated icons for improved visual consistancy.
-</li>
-<li>
-Support for migration of old projects to work in newer QGIS versions.
-</li>
+<ul>
+  <li>
+  Revision of all dialogs for user interface consistancy
+  </li>
+  <li>
+  Improvements to unique value renderer vector dialog
+  </li>
+  <li>
+  Symbol previews when defining vector classes
+  </li>
+  <li>
+  Separation of python support into its own library
+  </li>
+  <li>
+  List view and filter for GRASS toolbox to find tools more quickly
+  </li>
+  <li>
+  List view and filter for Plugin Manager to find plugins more easily
+  </li>
+  <li>
+  Updated Spatial Reference System definitions
+  </li>
+  <li>
+  QML Style support for rasters and database layers
+  </li>
 </ul>
 <dl><dt><span class="subheader">Special Requirements
     <ul class="normal">
-      <li><a href="http://www.trolltech.com/developer/downloads/qt/index">Qt 4.2.2</a> is required.
+      <li><a href="http://www.trolltech.com/developer/downloads/qt/index">Qt 4.3.0</a> is required.
     <li>The <a href="http://expat.sourceforge.net/">Expat XML Parser</a> is required for the GPS plugin. This vastly improves the speed and memory management when loading GPX files.
     <li>The raster georeferencer plugin requires the <a href="http://www.gnu.org/software/gsl/">GNU Scientfic Library</a> (GSL).
     </ul>
@@ -80,7 +84,7 @@
     <dd>
     Windows
     <ul class="normal">
-      <li> GRASS included with windows build is from : GRASS 6.3 rc6
+      <li> GRASS included with windows build is from : GRASS 6.3
     </ul>
     </dd>
     </dt>
More information about the QGIS-commit mailing list
